I purchased a 5lb ABC Fire Extinguisher and started thinking of a safe, and easily accessible location to mount it. This is what I came up with.
Went to a local shop and purchased a car mount bracket. This bracket is MUCH better than the wall mount version that came with the FE. I bent and welded two tabs to the bracket making a very secure, low profile mount. The front trim panel in the picture is notched just a little bit in order for the bracket to mount to the body. You can see where i notched it with the green marks in the first picture. The rear (larger) trim panel overlaps the front piece, so if I decide to move it later, you wont even know it was there. I hate cutting up perfectly good panels cause it creates an eye sore if you ever have to move it later.
The bottom bracket mounts to the lower bolt of the seat belt mechanism, and the top is mounted on the body (had to drill a hole.)
Hopefully this will give others a better option for mounting their 5lb extinguisher.
