Old 04-26-05, 09:06 PM   #1 (permalink)
elmariachi's Avatar
TLCA# 6760
Rear Cargo Light Install
Rather than bury this at the end of previous threads on the subject, I am posting this fresh. Here's a link to my quickie install of a center dome light assembly in the rear cargo area above the hatch.
http://www.jimreiss.com/landcruisers/
FYI per CDan, oak assemblies are now out of production, gray are still available. I picked up a couple oak ones from online salvage yards.
Houston, TX
1997 FZJ-80, factory lockers, OEM 13L subtank, OME-Js, BFG's, ARB, dual batteries, rear seat DVD. Lone Star Land Cruisers
elmariachi is offline   Reply With Quote
Old 04-26-05, 09:49 PM   #2 (permalink)
97 FZJ80's Avatar
Thanks Jim! I'm looking forward to mounting my light following your instructions this weekend.
John
97 LX450 - Plano, TX
ARB winch bumper - OME 851/852 - Bilsteins - triple lockers - center d/l switch - reclining mid/rear seats - HIDs - map/domes/doors/cargo/tail LEDs - crystal clear lights - aux fuse block - power outlets - lots of cupholders - PriorityStart! - Optima - exact mats - Waeco fridge - xfer case cover
To be installed: dual batteries w/Optima D31M, JDM condensor fan, JDM fog lights, Rear bumper with tire and fuel carriers, snorkel
"Today is yesterday's tomorrow"
97 FZJ80 is offline   Reply With Quote
Old 04-26-05, 09:52 PM   #3 (permalink)
turbocruiser's Avatar
Very cool write up man, thanks for this!
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 9.5psi and climbing, My Rocky Mountain Mojo Mobile!
turbocruiser is offline   Reply With Quote
Old 04-26-05, 09:53 PM   #4 (permalink)
beno's Avatar
TLCA# 14607
Nice Jim. Thanks for sharing. ANother thing to put on the list.
Junk, make it a FAQ...
-onur
Akron, OH
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
beno is offline   Reply With Quote
Old 04-26-05, 10:04 PM   #5 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
Nice detailed write up
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 04-26-05, 10:14 PM   #6 (permalink)
Unleash the Beast
LX_TREME's Avatar
TLCA# 4500
Nice... very detailed oriented you should post with George LED on the last pics
LX_TREME is offline   Reply With Quote
Old 04-27-05, 12:50 PM   #7 (permalink)
97 FZJ80's Avatar
How about adding this thread to the 80 tech section?
Old 04-27-05, 01:34 PM   #8 (permalink)
Heffenoche's Avatar
Thanks for the write-up. I have light assembly, still need to get the led and I'm all set to go. I'll have to see if I can find the wiring harness since mine is a 94.
94 FZJ80 134k Locked, ARB Front, OME heavy, Warn 12000, TJM Rear. 285 MTRs, LED's & rear cargo light.
85 FJ60 98k, ARB front, 3"lift, 32" BFG AT
Heffenoche is offline   Reply With Quote
Old 04-27-05, 02:20 PM   #9 (permalink)
tucker74's Avatar
Sweet - good thing my interior is gray!
Tucker
'94 FZJ80
'76 FJ40
www.walcs.com
tucker74 is offline   Reply With Quote
Old 04-29-05, 04:34 PM   #10 (permalink)
97 FZJ80's Avatar
Jim,
Why did you cut the 4 molded standoff? I would think that the 4 standoffs would help prevent the light from mounting too far in crushing the headliner.
The light I have is probably from a 93/94 model as it has the additional metal back covers and does not have the 4 standoffs.
John
Old 04-29-05, 06:07 PM   #11 (permalink)
elmariachi's Avatar
TLCA# 6760
Originally Posted by 97 FZJ80
Jim,
After sticking it up in there is seemed that the standoffs were going to keep it from mounitng flush against the headliner, so I whacked them off. I have another one non-whacked and I may try it when I get some time. Post up a pic when you get yours in.
Houston, TX
Old 05-01-05, 09:18 AM   #12 (permalink)
97 FZJ80's Avatar
I will post pictures when I have it done. I'm losing the 80 for a week as the minivan is down.
I'll do a writeup later on why the 80 trumps the Honda Odyssey in performing minivan duties.
Old 05-23-05, 08:32 AM   #13 (permalink)
stayalert's Avatar
Thanks! Becasue of your post I pursued and completed this mod. Havn't tried it yet in the dark but it was pretty easy and straighforward to do......And CDan once again has demonstrated a level of service which I wish were more common.
Cheers
Rob M
Concord, MA '94 fz80
stayalert is online now   Reply With Quote
Old 07-04-05, 10:20 PM   #14 (permalink)
97 FZJ80's Avatar
I finally got the light installed in the 100F+ heat this weekend. The standoffs behind the 4 screw holes did not interfere with the light sitting flush with the headliner as they are only about 1/8 inch tall.
I do have the following notes to add to Jim's excellent installation instructions.
* I did not have to remove the seatbelt anchor on the D-pillar. I pulled the black rubber gasket out enough to allow the upper part of the D-pillar plastic cover pull out. This in turn allow me to access the hatch-to- headliner trim gasket under the D-pillar plastic trim.
* I did not cut off the 4 standoffs behind the 4 screw holes of the light. The light still fit flush
* I used 1" screw (factory screws were 3/4") to mount the light. Like Jim, my headliner were still pushed in just a bit. I might go back and replace the screws with 1-1/4" ones.
* The back of my dome light was significantly different than the light shown on Jim's website. In addition, the light I have has a metal shield behind the bulb.
* I used George's LED in place of the bulb.
* I did not remove the metal shield behind the bulb. As it is, the shield forced the LED to sit at an angle. This suited my use as I wanted the LED light to focus more light down/rear ward towards the tailgate. I did put electral tape around the metal shield to prevent the LED from shoring out.
* I purchase the light along with the electrical connector pigtail and about 6" of wires. It simplified things as I did not have to fabricate the light connector.
* I opted to tap the wiring at second row light with vampire taps for 18-22 gauge wires. I did not feel comfortable soldering wires within 6" of the headliner.
Here are the pictures of my installs.
Old 07-05-05, 07:04 AM   #15 (permalink)
Cool write up Jim.
Thanks Dude!
Bryan E.
Emerald Green 94, Lifted w/J OME springs, L shocks, 315 MTR's, Snorkel, ARB bumper, etc. etc...
Richardson, Texas
Bryan E. is offline   Reply With Quote
Old 11-29-06, 08:09 PM   #16 (permalink)
Central Scrutinizer
MoGas's Avatar
TLCA# 17188
One thing I would like to add is that there is a wiring harness with the appropriate connector for a cargo area light in the top of the liftgate pillar on the US Driver's side. It is taped in there. Models that do not have factory 3rd row have a light back there and Toyota did not make a different harness just for non 3rd row vehicles. I found this out while removing my light that is designated for this mod from a salvage yard donor that had the headliner torn in the back. You just have to pull the windlass off and reach in there for it.
Dave
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
MoGas is offline   Reply With Quote
Old 04-10-08, 02:43 PM   #17 (permalink)
-250 Club
cool breeze's Avatar
Link doesn't work anymore... is there a new page?
-Josh-
'94 FJZ80 2nd owner 188k
BUY MY 80 STUFF:
http://forum.ih8mud.com/sale-parts/293267-1994-80-parts-lights-such.html
http://forum.ih8mud.com/sale-parts/3...l-springs.html
http://forum.ih8mud.com/sale-parts/3...bs-sensor.html
http://forum.ih8mud.com/parting-out/...ser-so-tx.html
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth."
cool breeze is offline   Reply With Quote
Old 04-10-08, 06:52 PM   #18 (permalink)
Falco80's Avatar
TLCA# 18832
Garage
Dave
Yep, like Dave said, the plug is already waiting for you...
A few of us guys in oz have done this mod and it works a treat. Myself and a few others have used a 48 Led light, picked up from a boating accesories store. I also replaced all the other interior lights with Led's and would recommend it to anyone interested. Cost me about $140 Aus, but it's nice and bright inside at night!
Nice work Jim using the factory light, looks the goods!
Cheers,
Dan
79 BJ40 3rd owner!
97 HDJ80R 1HD-FT Multivalve Turbo-Diesel P-O-W-E-R !!
Falco80 is offline   Reply With Quote
Old 05-29-08, 01:36 AM   #19 (permalink)
NLXTACY's Avatar
TLCA# 19015
Ugh ok I was just about to do this mod because I scored two OAK lights and when I go to the link, Jim's site is down. Being as this is directly connected to the FAQ section, any way to get the link working again? Especially since I would like to do this mod
ふざけんなよ!
Old 05-29-08, 07:47 AM   #20 (permalink)
I-HEART-DIRT
Bluetribal's Avatar
I think I have the info you are looking for saved in a word doc. at home. On projects I plan to do I typically copy all the info to a word doc. so things like that don't happen. So if you don't get any further help today, PM me your e-mail address and I will send you what I have this evening......
Mark
96' LC - All my Mods, Trips & Videos
Check out my ROTF & the SoCal 80's
09' Subaru Forester
Bluetribal is offline   Reply With Quote
Old 05-29-08, 08:14 AM   #21 (permalink)
cruisertom911's Avatar
TLCA# 10508
Cool write. Inspired me to pick one up from the junkyard while I was gettin some stuff for my Hilux. Found one in in the same color as the rest of 'em. Got the LED coming to me so I'm gonna get out today and see if I can find the wire up in the pillar and get this light mounted. Thanks
'89 Hilux really not stock
'97 FZJ80 not stock
'00 UZJ100 mostly stock
cruisertom911 is offline   Reply With Quote
Old 05-29-08, 12:10 PM   #22 (permalink)
not an addict
nuclearlemon's Avatar
TLCA# 1431
it's a very simple mod. i did mine a couple weeks ago. mine was from some other toyota, but it was free. same idea though. i just pressed the light against the headliner to figure out where to cut the headliner (only a small center section has to be cut out to clear the back of the light assy). there is a recessed area in the rear body area.
i didn't know about the plug, but with a coat hanger, i pulled wires from the center domelight back and used heatshrinkable crimp connectors. my dome light was only two bolt hole, so drilled the holes and installed sheemetal screws. install led bulb. done.
"to learn is to teach someone else"
only four cruisers left
nuclearlemon is offline   Reply With Quote
Old 06-03-08, 07:46 AM   #23 (permalink)
RescueU's Avatar
Jim,
The link to your website is dead. Is there an updated link or did you post your write-up somewhere else on Mud?
Thanks.
- Sean
97' FZJ80 "Fire Engine" Red/ARB winch bar & M8000 /OEM Lockers/OME 850/863 & OME shocks/285-REVOs/Custom welded roof rack on factory rails (Blackout special)/XTVA & XTS5000 radio/Yaesu 8900/CB WX/custom storage drawers/
'88 4Runner
RescueU is offline   Reply With Quote
Old 06-03-08, 07:52 AM   #24 (permalink)
I-HEART-DIRT
Bluetribal's Avatar
Ahh crap, My Bad NL I totally forgot to e-mail you my info for this project. I have it on a sticky note now so I will send it this evening. Sean (RescueU), if you would like the info I could e-mail it to you as well if you PM me your e-mail address.
Mark
09' Subaru Forester
Old 06-03-08, 08:54 AM   #25 (permalink)
NLXTACY's Avatar
TLCA# 19015
No love. No love
Why not post it up so that everyone can enjoy it?
ふざけんなよ!
Old 06-03-08, 12:06 PM   #26 (permalink)
I-HEART-DIRT
Bluetribal's Avatar
I have a whole write-up planned but I was waiting till' I re-built my website. And I have been totally slacking on that. I will post them in my Mud album tonight and share the link.....
Mark
09' Subaru Forester
Old 06-03-08, 08:25 PM   #27 (permalink)
I-HEART-DIRT
Bluetribal's Avatar
OK here is the link of my install along with some tips.
Cargo Light Album
Mark
09' Subaru Forester
Old 06-10-08, 12:55 AM   #28 (permalink)
Hulk's Avatar
TLCA# 4189
Looks good. I have an extra oak light that I need to get installed. Thanks for sharing all the information and pictures!
Matt Farr, TLCA #4189 · WØRDY
Webmaster, Rising Sun 4WD Club of Colorado · my Facebook page
1981 FJ-40 "The Hulk" + 1996 FZJ-80
Hulk is offline   Reply With Quote
Old 06-10-08, 10:00 AM   #29 (permalink)
overhanger's Avatar
TLCA# 10222
Matt, if you need a reference to follow, check out my 80 the next time we get together. It's the prototype install, afterall!
Steve Crase TLCA 10222
1988 FJ62 - Bart
1997 FZJ80 40th Anniversary #3727 - Sandy
overhanger is offline   Reply With Quote
Old 06-10-08, 01:30 PM   #30 (permalink)
corsair23's Avatar
Matt, you lead, I'll follow - I picked up a light some time ago. Maybe have a light install party?
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
corsair23 is offline   Reply With Quote
