Old 03-28-05, 01:07 PM   #1
beno's Avatar
TLCA# 14607
Rear axle job and pics.
Hey all:
Rook2 and I are working on a rear axle job/rear brake job write-up and I just wanted to post some pics. of the job that I took last week.
The full write-up is in the works and will be done soon--promise--with the requisite pics. and explanations.
Here are some of the trucks--Rook's got a LX and mine is a regular LC.
Best.
-onur
Akron, OH
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
It is what it is....
beno is offline   Reply With Quote
Old 03-28-05, 01:10 PM   #2
beno's Avatar
TLCA# 14607
Some more pics...
Before the job, hammer to hub to break loose the cone washers, and the axle coming out...
Old 03-28-05, 01:12 PM   #3
beno's Avatar
TLCA# 14607
And some more...
pic. of the lock nuts that you use the SST for and that you adjust for the pre-load at the end, a pic. without the rotor, and a pic. after the hub is off (note the e-brake mechanism inside--mine is due for a rebuild...talk to you soon Dan!!)...
Old 03-28-05, 01:14 PM   #4
beno's Avatar
TLCA# 14607
And some more...
Pic. of the dirty hub, hub without bearings, and of all the parts after the removal
Old 03-28-05, 01:17 PM   #5
beno's Avatar
TLCA# 14607
yet more pics...
Hubs packed with M1 synthetic grease and the bearings, hub re-attached to brake rotor, hub w/new rotor back on spindle with the grease inside...
Old 03-28-05, 01:19 PM   #6
beno's Avatar
TLCA# 14607
yet some more...
Rook2 checking the preload with a fish scale, with the new gasket placed on the hub, and Rook2 pushing his axle back into the housing--carefully!!
Old 03-28-05, 01:20 PM   #7
beno's Avatar
TLCA# 14607
last ones--promise
and the final look of the rear axle all put back together sans tire...hopefully a write up coming soon....
Best regards.
-onur
Akron, OH
Old 03-28-05, 02:32 PM   #8
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
Awesome. Thanks for the pics. I'll be doing this in the next few weeks.
Ken
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline   Reply With Quote
Old 03-28-05, 02:42 PM   #9
Looks great. One comment would be to use caution with a hammer that big to get the tapered washers free. Better to use a smaller hammer and pounding repeatedly as you could concievably flat spot the wheel bearings with that sledge.
DougM
'93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter
IdahoDoug is offline   Reply With Quote
Old 03-28-05, 03:03 PM   #10
concretejungle's Avatar
TLCA# 14646
Thanks for the pics dudes! I was going to tackle this very job pretty soon, and i learn best from pictures!
I second what doug said about the hammer. Also one other note,.....i thought i remember hearing speak that when you pull the axles out, to be sure if you have a locker to engage it....i think engage, otherwise something about the spider gear falling down and having to take the rear end apart to get it lined back up. Someone, know what i'm trying to talk about here?
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is offline   Reply With Quote
Old 03-28-05, 03:15 PM   #11
I'd heard that, too. I haven't studied the third member(s) enough to know if this is an issue. I have lockers and didn't even know about this, yet my axles slid in and engaged in seconds at all four corners. I have a bit of a hard time thinking that there's a part in there that's going to fall off without the axle. The third member would be a complete unit that goes into the diff housing and its side gears and spiders would be self contained - ie it's not a pile of loose gears but an assembly.
Dunno for sure, but worth a conversation/thread with someone who's put in a third member to regear or for repair. Christo? Robbie?
DougM
Old 03-28-05, 03:16 PM   #12
beno's Avatar
TLCA# 14607
Hey CJ: Yeah, I engaged the rear lockers before I pulled the axles--that way the spider thing doesn't get all squirrely on ya and make it a very difficult time getting the axle back in. Rook2 didn't have rear lockers so he didn't have to worry about them.
Doug--just two decent hits with the hammer did the job. No flat spots at all. I did the same for the front end job and one hit above and one hit from below worked just fine...the hammer isn't a BFH (it's a small BFH... ). I was very careful in hitting it square on, with not too much force, just enough to pop the cone washers out.
Best.
-onur
Akron, OH
Old 03-28-05, 04:07 PM   #13
bjowett's Avatar
Nice write up and PICS!
Brian
Western Massachusetts
08 Tundra Double Cab 5.7 TRD
93 FZJ80, locked, 4.6L, 6 speed, Orion <- now driving!
04 VW Touareg V8 w/ locker (hers)
80 FJ40 , 83k, PS and AC
05 Yamaha RS Rage Snowmobile
06 Suzuki King Quad
93 VW Corrado Syncro AWD 3.0L
51 Jowett Jupiter Roadster
bjowett is offline   Reply With Quote
Old 03-28-05, 04:31 PM   #14
Tube is your buddy!
helocat's Avatar
TLCA# 1137
Good photos. How many neighbors made comment about the “Cruiser” repair shop! What was the total time wheels up/wheels down?
Mark
Metal Tech supports the efforts of http://anysoldier.com go to this site to learn how to send a care package to a US Solider in the hot zone.
93' FZJ80 (aka: NEWPIG) - 97' FZJ80 - 79' FJ40 - 78' FJ40
helocat is offline   Reply With Quote
Old 03-28-05, 04:42 PM   #15
Rookie2's Avatar
DougM
IIRC, in an old post Christo referred to it as a lock sleeve or dog gear.
See this thread for more discussion on this, doesn't sound like a route you want to temp faith with:
http://forum.ih8mud.com/80-series-tech/13104-rear-axle-service-ff.html
Beno: Did you get any pics through the axle for both rigs?
Rookie2
1997 LX-450, 109k, Stocker.
Shaa laa lalalala live for todayyy... and don't worry bout tomorrow heeeeyy hey eyyy.
Rookie2 is offline   Reply With Quote
Old 03-28-05, 04:46 PM   #16
sjcruiser's Avatar
Great pics! (except the one that had the aftermarket pads; or at least looks like it)
Edit: On a second thought, it might be the anti-squeal goop overdosed
'97 LX450 - Triple locks - fully loaded
2.5" lift OME851/860 springs + Bilstein B46-1477/1478 shocks - 285/75/16 Bridgestone AT Revo - 3M lense protectors - Hella 100FF driving lights - blinking side markers
sjcruiser is offline   Reply With Quote
Old 03-28-05, 04:57 PM   #17
Rookie2's Avatar
Mark
Hehe... no doubt. I've had her up on jack stands doing one thing or another every few weeks, since I got it. Not many comments about it, other than "what's wrong with it today?" This was on Monday, so not much traffic in and out.
Total time: We started jacking them up about 8:30 and finished cleaning the grease off our hands at about 6:00. Looking back, I'm not quite sure what took us so long, but that was pretty much straight through. I guess cleaning everything up good.
Rookie2
Old 03-28-05, 05:47 PM   #18
You want to do what...?
e9999's Avatar
so this would be the one time when the lockerless guys actually have one over the rest of us lockerfulls?
Bah, let them have their simple pleasures....
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD Accord
souped up DR650
Old 03-28-05, 08:24 PM   #19
Onur,
I wasn't worried so much about flat spots on the housing, but on the bearings which you wouldn't be able to see. The kind of shock you can deliver to the wheel bearings like that is WAY more than even hitting a square edged curb at road speed. Once you've hit it a time or two, the umoving bearings may have displaced their grease and then it's metal to metal from then on. They're designed to roll and spread the load and move grease all at the same time. I'd recommend hard tapping all around more vs hard blows. I'm a little paranoid as I carry an enormous amount of weight back there quite a bit, so.....
Just pointing it out, sounds like you have things under control.
DougM
Old 03-28-05, 08:32 PM   #20
Junk's Avatar
Thanks for the write up guys. Great pics too and will add this to the faq list. Looks like we need to have tech faqs versus other faqs soon.
Are we required to wear ugly shirts like that or was that just for romantic ambience?
Junk is offline   Reply With Quote
Old 03-28-05, 08:47 PM   #21
Rookie2's Avatar
D'oh.. After seeing that picture, I wondered how long it would take before a shirt comment came up. That's my "Jamaica Me Crazy" wrenching shirt man .
Note to self, do a fashion check if "Onur the picture man is coming to town".
Honestly though, kudos to Onur. I get into wrenching, and the last thing on my mind is snapping pictures. I was to busy trying to keep him away from my axles with that BFH... .
R2
Old 03-28-05, 09:29 PM   #22
beno's Avatar
TLCA# 14607
Yuppers...a bit too much.
Thanks for the explanation Doug. I wasn't aware the of the possible damage...now I know. I'll try it with a smaller hammer next time with more hits rather than a few hard blows. BTW, I had two extra inner and outer bearings/races from Dan, just in case they looked bad or for what you were describing with the metal-to-metal hits.
Rook2: After you and I looked at each other's respective views through the axle I didn't take a picture for I was unsure if the pics. would actually come out alright at all with such little light and I thought the camera flash might have actually made it worse. IIRC, you unlocked LX had an 'x' like piece of metal or two pieces of metal going through when we look into the housing. My LC had what looked like a mesh-metal pattern inside--more than likely the lockers engaged inside--there was a sort of 'x' pattern embedded inside except they were holes diagonal from each other. That's all I can remember about this.
While I'm on this topic, some other observations/hints: Like Gary noted in another thread, both Rook2 and I misread the FSM's we had and took off the half-part of the caliper holding it to the other half--we took out the ones holding the brake pads and the pistons in it, instead of taking the two bolts that hold the entire caliper onto the brake rotor. Easy to do, I think because they are close and look quite similar to each other. It actually worked fine for me as I was changing out the pads and the rotors and it made for easy disassembly/assembly. After I squeezed the brake pads in, I held the caliper and Rook2 used a long screwdriver to depress the piston so that I could fit the caliper back onto the assembly.
Definitely engage the lockers if you have them. I don't even want to think about what I would have to do to stick the axle back in if I hadn't and the gear had fallen out (I guess--others will chime in on this I assume).
Other than that, the job is rather easy going and straight forward--just follow the FSM on assembly afterwards--ie: the order in which to assemble everything back together. Also, the FSM has stud removal and placement back together in the rear axle section. Rook2 and I didn't replace the axle studs so we were able to skip that entire section. The bearing pre-load was pretty decent. I think we were both within specs. on our first tries...on the upper end at least and we tried to bring them down a bit towards the lower end, but ended up someplace in the middle, which was fine for the both of us. Neither of us replaced either inner or outer bearings or races--just cleaned'em out real good by soaking them in parts cleaner (1 gal. style from Advanced Auto I believe).
Keep with the torque ratings and things are all pretty simple after that. If any one has questions, drop a line.
Best regards.
-onur
Akron, OH
Old 03-29-05, 08:27 AM   #23
TLCgrappler's Avatar
I was about to write that the FSM actually specifies to lock the lockers, but after double-checking, it only mentions that in the section on servicing the differential, and is slient about it in both the front and rear axle service sections.
Locking them and making sure the locker is engaged seems like a prudent thing to do, based on experiences noted here.
______________________________
'96 FZJ-80 155K stock w/lockers
'06 UZJ-100 Stock 33K
'07 GSJ15 FJ Cruiser Voodoo Blue 6K
Si fractum non sit, noli id reficere
TLCgrappler is offline   Reply With Quote
Old 07-26-07, 01:43 PM   #24
DanKunz's Avatar
TLCA# 10893
The collar and shift fork in the e-locker are oriented ON the axle. It is possible to have the collar and shift fork to become mis-aligned when you pull the long side axle (rear) or short side axle (front).
The e-locker actuators load a spring that puts tension on the locking collar through the shift fork. When the outer portion of the carrier lines up with the collar, the large teeth engage (CLUNK), and you are locked. To prevent the collar from becoming misaligned locking the diff is a quick and easy step.
I don't see why you can't do it...it prevents a pain the rear upon reinstallation IF things get out of alignment. An ounce of prevention...
Dan Kunz
1996 FZJ-80 "AV0CAD0"
2000 UZJ-100 "T0WCAD0"
Member: TLCA, GA Cruisers, Upstate Cruisers
Donate to SAVE TELLICO!
Originally Posted by eventhough:
"apparently I just need to play with it until it feels right... "
DanKunz is offline   Reply With Quote
Old 10-07-07, 04:15 AM   #25
Bambusiero's Avatar
Here is a picture showing where to position the lock screws, and how to line up the lock ring index marks to the spindle index marks.
Having never been into the rear axle hub before, this was not clear to me even after reading all the FAQs and the FSM. I had to take it back apart the 1st time to figure it out because everything was all gooey with grease. However, once you see the scheme, you can easily find the right holes for the lock screws, even if everything is covered in grease.
The red arrows point to the 4 index notches on the end of the spindle. They are located on the diagonals, at clock positions 1:30, 4:30, 7:30, and 10:30.
The blue arrows point to the 3 index marks on the lock ring.
You line up a lock ring index to a spindle index. Use whichever pair is closest to each other after torquing the lock ring. A new pair is lined up at every 30 degrees of rotation.
Then, the 2 lock screws go in holes at a right angle to the lined up index pair, and you're good to go.
Mark Mir
'97 LX450 w factory lockers
Bambusiero is offline   Reply With Quote
Old 10-07-07, 11:43 AM   #26
Bear80's Avatar
TLCA# 14779
How deep has everyone driven the axle seal into the housing? FSM doesn't specify, and they can be driven in past flush.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
