Cruiserdrew
On the way there
I developed a leak between my third member and the front axle while travelling home from Death Valley. Other than stopping every 50 miles to add gear oil-thanks Echo29 and Darwood- it went fine and I didn't cook my R&P. I only had to work until 2pm today and so got a chance to tear into it so I could pull the third member. I found this failure of the outer bearing race on the driver's side. The wheel was spinning freely, made no noise and was normal in all other respects. This picture is of the race, the bearing itself looks normal, and if it were not for the race, I would reuse it with no question.
I had called CDan this morning to overnight me the knuckle rebuild parts (since it would be apart anyway) and he said "Do you want wheelbearings too?" Of course I said no thinking they would be fine. Shait-now I have to scramble around town tomorrow and find at least the outer bearing. If AutoZone has the Timkins all in stock, I'm buying a full set. Otherwise it's more overnight parts from Dan the man. So the moral is that if Dan asks do you also want any other part, just say yes.
The maintanence history is that these are OEM Timkin wheel bearings, repacked at 45k, and 70k. The 70k grease was Amsoil, so I'm going back to Mobil1. I now have 93K on the 80 series. I guess I'm curious if anyone else has had a similar failure, and what the cause might be.
