Toyota OEM PS Pump PSI and GPM Ratings & Hydraulic Winch
[FONT=Calibri, Verdana, Helvetica, Arial]I saw a thread on Hydro Winches and the rating of PS Pumps. I thought those considering a MM Hydraulic Winch might want this info.
I called Toyota North America today. Lucked out and got a guy who owns an 80 Series and is building it I told him about IH8MUD and may have sold him on an IBS Dual Battery or Perfect Switch Dual Battery system over a National Luna and a MM Hydro Winch over an Warn Electric...
He stated the manual states 1,351 PSI at Idle with the Valve closed. This is the Minimum Specification. He claims Toyota is conservative with their ratings. This spec indicates that the PS Pump will operate reliably all the way down to this pressure.
Toyota does not seem to publish a maximum rating but based on the way Toyota rates things, he was confident it would put out more than the minimum rating.
In discussing this with both Toyota & Mile Marker, everything seems to indicate 1,500psi / 4gpm is most likely what the pump is putting out ... or at the very least the rating closer to the desired spec verses the lower Minimum Spec.
The Minimum Spec is where you start having trouble and the pump and it would be declared “defective” ... Hope this info helps.[/FONT]
