As was the case with my 100 series https://forum.ih8mud.com/100-series-cruisers/327860-door-panel-removal-process.html, I performed a search for "door panel removal" on my 80, and although I came up with bits and pieces on several threads, they all left out steps that I needed to know. Therefore, on the chance that someone needs to know how to do this from beginning to end (the front doors on a 95 FZJ80, anyway), the following is a rundown:
1. Locate the small, black "finishing" plastic triangle on the top of the door panel (at the leading edge of the window - see the upper right side of photo 1), and pry it off. (Photo number 2 will show you the back side - just so you'll know how it's affixed to the door). It would probably be pretty hard to do so, but be sure not to break off the little plastic connector on the top.
