I bought my lx about a year ago with 103K. All services were recorded by the Lexus dealer. The PO had flushed the cooling system with green coolant. So two months ago, I flushed my 1996 lx like the FAQ had suggested and switched to Toyota red.
During the flush I found gray sludge....
About a week ago I noticed many slow leaks around the heater core pipes and PHH. Nothing was leaking before the flush. So time to replace heater hoses...
The question is what is the function of the metal coolant pipe that connects the heater bypass valve and to the PHH? The heater bypass valve is attached to the upper firewall and to a short 90 bend heater hose that connects to the metal pipe which is attached to the engine via the PHH. Those hoses must flex allot. It would be understandable for the hoses to leak after 100K miles.
Why should I not replace the entire metal tube and hoses with Silicon heater hoses and constant tension clamps? I also understand that the egr pipe is next to the metal coolant hose. Silicon heater hose should have no problem in that environment. What do you guys think?
Also take a look at
http://www.gates.com/brochure.cfm?br...ocation_id=541
the link is about galvanic corrosion and EPDM heater hoses.... And yes the heater hoses in the FZJ-80 are EPDMK rubber. I am very interested in the condition of the old hoses. The hoses may be the source of the sludge in the cooling system. BTW I am a chemist by profession, may be some testing is in order on the heater hoses.
I wonder if Toyota had changed grades or source of heater hoses from the 93-95 to 96-97 models? Could someone with a 93 original heater hose that attaches to the heater bypass valve snap a pic. There should be a part number and grade of rubber used in the hose.
Dave
