I haven't seen a picture of the comparison so here it is.
80 series brake pads vs 100 series brake pads
they slide strait in
you do need slotted rotors tho
the extra surfas aria makes excessive heat and tends to warp rotors
installing sloteds fixed the problem and the pads seem to last longer when 4wding in mud
As far as I know... They will not fit the '92 FJ80... only '93 FZJ80 and later 'till '97???
The earlier FJ80 have 15" Wheels and the brakes are diferent... AFAIK...
just use regular rotors and 100 pads, without the no squeal shims.......
I'm about to do this upgrade and need some clarification: I am NOT supposed to use the "no squeal" shims with the 100 pads, right? Do you, instead, recommend using the spray-on anti-squeal stuff?
This thread is perfect timing. I need to replace rear pads and calipers on my 94. If I read this correctly I just need to order 80 series calipers and 100 series pads...or should I order the 100 series calipers as well?
And the 100 series is what years? '98 through . . . ?
Yeah I searched around and couldn't find the specific answer.![]()
'98-XXXX
