11-09-09, 06:22 PM
| | Forum Regular
| Daddy's home! My poor 80 is squeaky and rattles. My 2 year old can hear me inside the house as I pull up into the drive way. I have a rust belt 80, and was wondering were to start. I've replaced the springs and shocks, the brakes all the way around are in pretty bad shape. I plan on replacing the rotors, calipers in the near future. When I jump out of my rig, I can push the car up and down at a stop and rattles from all directions, Any suggestions, Thanks,
__________________  1995 FZJ80, Locked, OME 2.5" med lift, ironman foam cell shocks, sirus sat radio, Firestone Destination AT 305/70 R16 |
11-09-09, 06:32 PM
| | 250+ Club
| Possibly retirement time? you can find some fairly rust free ones out california way for reasonable dime. and if you have access to a car hauler and have wrenching skills , there are a few i have seen posted cheap with head gasket problems. 2-3g and some work (sounds like less work than u need to put into yours ) would probably net you a better rig.
__________________ 1HD-t tripple locked factory winch = 22+MPG ... |
11-09-09, 10:14 PM
| | Forum Lifer
| x2 on a newer rig.
Shipping cross country is actually pretty cheap. Find a rig with a blown HG and good body, and either do a rebuild or a swap. Part out the leftover rig and you should about break even or maybe even make a few bucks.
__________________ '97 LX450 Mods and Pics
'96 LX450 Mods and Pics Jefferson State Cruisers (A subsiderary of OR/CA TACO) (Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.) |
11-09-09, 10:56 PM
| | Forum Lifer
| Not much info to go on here and no clear question in the thread. What are you asking? People seem to be replying that you should get a new truck, yet in your post I see no operating issues whatsoever - just a few squeaks and rattles. Since the miles and condition of your truck aren't posted, there's no way to know if this is normal or not.
So what's the point of the post and if it's just to say hello from Norfolk, then hello back. No big deal.
DougM
__________________ Buy Head Gasket DVD for you OR for your mechanic HERE
'93 FZJ since new, 2.2kw starter, Revo 275s (Michelin Alpins in winter), locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin X-Ice in winter. |
11-10-09, 01:57 PM
| | Forum Regular
| Rig has 120K miles, mechanically sound, no major mechanical issues other than the brakes, calipers and rotors. I guess my question is for major chasis rattles where do I begin the search for resolution. I'm not a mech.. and I use this site for advice and ideas
11-10-09, 02:16 PM
| | Hill & Gully Rider
| Quote:
Originally Posted by johnsonf18 My poor 80 is squeaky and rattles. My 2 year old can hear me inside the house as I pull up into the drive way. I have a rust belt 80, and was wondering were to start. I've replaced the springs and shocks, the brakes all the way around are in pretty bad shape. I plan on replacing the rotors, calipers in the near future. When I jump out of my rig, I can push the car up and down at a stop and rattles from all directions, Any suggestions, Thanks, | If I'm understanding you correctly, are you bouncing the suspension up and down? Is your driveway paved or is it rough enough to work your suspension? We need some more info. Have you crawled under your rig and had somebody else bounce it while you listen/look? It's kinda hard to help you with the info you've given.
__________________ '94 FZJ80 w/220K+miles; FF & Disc Brake Rear Axle, ARB w/Ramsey8K, Kaymar w/spare pivot, "Redneck Enginuitive Bellypan" skid plate, 2 batts. & isolator, OME 850/863 Springs w/OME N73/N74 Nitro Shocks, SS Brakelines, OME caster kit & steering damper, CDL W/Pin 7 mod., Temp.gauge mod, Amsoil converted, F.O.R. sliders. Green Diamond Tires: Icelander M/T LT265/75R16-E - Tom -- Link to my GDT tire thread
Reason: spelling
11-10-09, 02:29 PM
| | Forum Regular
| I would start at the exhaust. Most of my rattles have come from there. Keep your rig. Don't let the  from areas without rust tell you to ditch it because of a little rust here and there...
__________________ 1973 FJ40 Project: 35" BFG Krawlers, x-over steering, SOA, shackle reversal, saginaw conversion, 4 wheel disc brakes, 2F, 4 spd, 2 Low mod (grinder!) 6" increased wheelbase
1994 FZJ80 green, factory lockers, leather, Slee 4" Front, OME J Rears, OME L Shocks, 315 Yoko Geolander, LX chromies, roof basket |
11-10-09, 02:50 PM
| | On the Golf Course!
| 120K on original shocks and coils? Replace them with either OEM or OME - they're shot from age and mileage. If you are at all interested in any lift at all, this is the time to do it.
Lube the door hinges. Check all the major nuts and bolts on the control arms, steering links, etc. Do the items you want to do you've mentioned.
__________________ Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!, M101CDN
TLCA Member #13420; KI6SGO |
11-10-09, 03:28 PM
| | Forum Regular
Join Date: May 2009 Location: Northfield, New Jersey 08225
| check the o2 sensors they can pop out and sound awful. My rear o2 sensor was out and I was thinking there was something loose in the rear exhaust.
The o2 when loose the wire is keeping it attached so hence it will rattle and bang while driving. And will cause the exhaust to sound squirrely. my .02 and thats about what its worth....
__________________ 96 FZJ80 LC 339,125 k Blackcrow DD beach machine 285s revo 2, OME 2.5 MED.yakimas 97 FZJ80 LX-450 166k wifes DD sweet ride 97 4Runner 109k sold 95 4 runner 156k sold miss that truck it was perfect. One of the worst moves of my short life. I bought a newer nissan....OUCH |
11-10-09, 03:38 PM
#10 (permalink)
| | Forum Lifer
| Just got my new sway bar bushings today from Dan to fix the annoying squeak that has developed. Start with the cheap and easy parts and X2 on getting under it and listening as someone bounces it around. Put a hand on each part and wiggle it, tighten any obvious and reachable bolts. Most my rattles are from aftermarket parts with the exception of the sunroof.
__________________ Jason
__________________________________________________ __________
95 FZJ80 -- Expo Rig
72/4/6/7/8/9 FJ 55 -- Trail Rig
77 FJ-45 -- DD
.................................................. ................officially toyota poor |
11-10-09, 05:04 PM
#11 (permalink)
| | 250+ Club
| You could get under the rig and try to grease and lube all the moving parts.
Also you can check the cats, they are known for rattling and making a bunch of racket while idling in drive.
I like the kick tire method of finding noises.
__________________ 95 FZJ80 188k locked  depo headlamps w/ hid's, Hella 4000 w/ hid's, 295/75/16 bfg at, Kenwood DNX5120, Clifford alarm, Scan Gauge 2, EGR disabled, Yak rack, bunch of stickers, and other ghetto mods 97 Acura SLX(isuzu trooper) 229k Totaled 05 Subaru WRX STi |
11-10-09, 05:09 PM
#12 (permalink)
| | Forum Lifer
| Body bushings is something else to take a gander at + what others have mentioned.
__________________ '94 LC | JEFFERSON STATE CRUISERS |
11-11-09, 02:53 PM
#13 (permalink)
| | Forum Regular
| Thanks, appreciate the input!
| Thread Tools | | | | Display Modes | Linear Mode |
