Old 11-07-09, 03:38 PM   #1 (permalink)
Where are the best locations to lift using a floor jack??
Newb question; Where is the best place to lift on the front axle when using a floor jack? I found a slightly used Allied 3 1/2 ton floor jack at a Garage sale along with a unused 20 ton bottle jack ($60 for both). As suggested by fellow mudders I went for this one as it looked sturdy with a wide base, probably weighs around 100 lbs. I tried it and it held the front off the ground without leaking down although I had to use both arms when I pumped it up, is that normal? I'm not sure however if I lifted it in the correct spot on the axle, and don't have an FSM yet but recall seeing a lift point diagram somewhere and IIRC the lift points are under the diff or at the ends of the axle?? Can we safely lift near the center of the axle on the long side of the housing??
Kernal is offline   Reply With Quote
Old 11-07-09, 03:56 PM   #2 (permalink)
firetruck41's Avatar
TLCA# 14300
I think anywhere along the axle tube should be ok, as long as it isn't pushing on any lines/bolts/small brackets... You can lift under the pumpkin, but since it is offset, it is hard to get both wheels off the ground. Plan your lift so that you will be able to place the jackstands. Make sure you use jackstands if you, or any part of your appendages, will be under the vehicle, or under the wheel/axle.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is offline   Reply With Quote
Old 11-07-09, 04:10 PM   #3 (permalink)
Yeah, won't get under it until I get some jack stands. The lady at the garage sale today said she had just sold a new unused set of 6 ton ACDelco jack stands before I got there . Tried to order a set of 12 ton ACDelco jack stands from O'Reillys but they said that product has been discontinued. The ACDelco's seem well made. Might just go with the 6 ton set.
Old 11-07-09, 05:48 PM   #4 (permalink)
Marc311's Avatar
I have lifted it at the axle and at the frame before the bend. The frame is less than ideal given how far back you have to put it, but it will work.
x1000 on the jackstands. Just a hydraulic seal between you and severe injury or death. If I'm doing something with the tire off, I usually throw that under the frame/axle as well.
1995 Locked FZJ80
2007 BMW XChallenge
Marc311 is offline   Reply With Quote
Old 11-07-09, 06:10 PM   #5 (permalink)
Ebag333's Avatar
TLCA# 18864
Especially when lowering the axle, watch out for it slipping.
I almost took out my front e-locker that way.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 11-07-09, 07:45 PM   #6 (permalink)
I might get one of those rubber saddle pads that they sell at HF. Yeah, first time I tried to let it down it dropped, kerplunk, luckily it was only up in the air a few inches, so I practiced a few more times to learn how to feather the release handle.
Old 11-07-09, 09:22 PM   #7 (permalink)
greentruck's Avatar
If garage sales or the local CL doesn't yield the appropriate jackstands, just keep an eye on the ads in the paper and at the local partshouses. This time of year and with the economy, there will be deals.
Whatever you get, be sure to get them so that they go tall enough to get the truck off the floor. Usually anything that tall will be heavy enough to hold an 80 up. Best to get ones that have a good wide base if you have a choice.
Mike
'97 FZJ80 The Sacred Cow
143k, CDL switch w/ 7-pin mod, cupholders!, PHH, 400-watt inverter, working power antenna, other electric stuff, ye olde SSB CB, PO-crappy tires and rims
greentruck is offline   Reply With Quote
Old 11-07-09, 09:41 PM   #8 (permalink)
Northern Tool sells a set of Torin 12 ton double lock jack stands with a lift range of 18 in. to 27 in. IIRC, and a base of 12x10 in. The pair weighs about 60 lbs.
Old 11-08-09, 05:33 AM   #9 (permalink)
CJF
Look in your owner's manual.
CJF is offline   Reply With Quote
Old 11-08-09, 08:15 AM   #10 (permalink)
Anyone use one of these crossbeam adaptors?
Old 11-08-09, 09:27 AM   #11 (permalink)
Ebag333's Avatar
TLCA# 18864
That would be cool, but make sure that your jack is rated to lift half the weight of your cruiser instead of just a quarter.
'97 LX450
'96 LX450
Old 11-08-09, 02:23 PM   #12 (permalink)
TLCA# 14300
If you want to use it on the axle, the diff/pumpkin is still going to be in the way.
Ben Silva
My writeups:
Old 11-08-09, 04:42 PM   #13 (permalink)
Yeah, was thinking that if those support pads could be adjusted, like one under the diff and the other under the long arm of the axle, probably not.
