11-06-09, 04:54 PM
RTH: Key sticks in ignition - Gear Select Lever 100% culprit
Last time this happened was like three months ago, but ever since Tuesday it does this all the time. Anyway:
Whenever I turn the car off the key won't turn past "Acc." and come out of the ignition. Only after running the Gear Select Lever from "P" to "L" and back like 10 times with the shiftlock override can I get the key out.
Can someone point me in the direction of a diagram or something that tells me how to adjust the key lock mechanism thingy? There's nothing in the FSM that addresses this particular issue.
Thanks!
The Page: http://red-eicca.blogspot.com/
1992 FJ80, Light Gold, Stock except nose guard, ~190,000 Miles
Fondly named "Bruce"
_________________
1999 100-Series, Slate Grey, Stock, ~140,000 Miles
"Titan"
11-06-09, 06:52 PM
Did you try graphite or WD-40 in the keyhole?
alco
1993, Stock Unlocked, PHH, PIN 7, OME stock lift kit, BFG 285 AT/KO.
________
93 FZJ80 DD, 04 4x4 Taco sold, 96 Nissan HB 4x4 sold, 86 Nissan PU sold, 85 Cavalier WGN (lemon, sold $75), 79 Dodge van sold, 76 Chevette, 70 Plymouth FURY sold, 1969 Dodge Monaco sold.
11-06-09, 09:47 PM
My 91's done this for ~ 8 years now. I just have to give it an extra slap forward after it is in park to get it to release the key. It just comes natural to me now and will probably never attempt to fix it. Sure messes with people that borrow my truck though.
Greg
'91 FJ80
315/75/16s, OME Heavy/Med lift, 2" Vorfab front spring plate spacers, Dual Batts, Tucked/toughened ARB Bull Bar, 9000 lb T-max, Home brew rear bumper W/2 swingouts, Bored throttle body, '94 FF rear axle, ARB LockeD F&R, 100 Amp Delco Alternator conversion, Dual ODA Electric & Sanden
11-07-09, 06:18 PM
Yup, tried the lube trick, no dice.
Looking to adjust the thingy, would under the center console be a good place to look or would I have to crawl up under the car?
_________________
"Titan"
