Old 11-05-09, 10:07 PM   #1 (permalink)
crank no start help please
I just changed the fusible links today thinking for sure that was the problem because the old one's insulation was all cracked and peeling, but still cns! Shows no spark with timing gun, but I don't know if I'm doing it right. I didn't have anyone to help me so I couldn't do the pull spark plug test. No fuel when I pull the return line from the pressure regulator, but when I short the fuel relay plug I definitely hear the fuel in the rail. I do not have check engine light when I turn the key, but I don't remember having it before. I'm thinking no power to the ECU. How do I diagnose this? Any other ideas? Thanks.
kjishikawa@msn.com is online now   Reply With Quote
Old 11-06-09, 03:03 AM   #2 (permalink)
this is a 95 by the way
Old 11-06-09, 06:18 AM   #3 (permalink)
ThinkTank Waterboy
landtank's Avatar
this problem can be related to the alternator. No output or at least a bad connection between the alternator and battery will cause this problem. If it is this, most of the time it's the large wire that is lugged down on the alternator post. Another possibility is bad brushes which are easily replaced.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-06-09, 06:26 AM   #4 (permalink)
Photoman's Avatar
Under the hood should be a fuse box on the US drivers side. Check the EFI fuse.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 11-06-09, 08:18 AM   #5 (permalink)
re_guderian's Avatar
Where are you located? The factory Electrical Wiring Diagram is indispensable in troubleshooting these types of problems. You're welcome to borrow my '95 EWD if you're anywhere close... I wouldn't rule out fuel pump relay circuit issues based on your description either. It runs the pump (or not, if you have problems) at one of 2 voltages depending on demand from the ECU. You have a lot more diagnosing to do before buying parts, unless of course, you have more cash than time...
Rob G
1995 FZJ80 2000 UZJ100
AZ
Copper State Cruisers #046
re_guderian is offline   Reply With Quote
Old 11-06-09, 04:17 PM   #6 (permalink)
Hey guys thanks for the replies. I'm at work today so I can't tinker with it but at least I'll have some ideas to try tomorrow. Rick, won't alternator problems give me a click no start problem? The engine cranks but won't start. Bill, sorry I forgot to mention I checked the the fuses under hood and near driver's knee and all appear fine. Rob, I'd love to take you up on that offer. Do you mind driving it over to Kauai for me? Is there a way to test the relays? The fuses can be checked visually but how do you check the relays?
After searching and searching I was almost certain that it was the fusible links, I guess that would have been to easy. I have no CEL when I turn the key to the on position which is supposed to mean no power to ECU. Is this why I am not getting spark or fuel? Is power needed to ECU to get spark and fuel? I'm assuming by shorting the fuel relay plug I am bypassing the ECU to get fuel.
Again thanks for the ideas and keep them coming so I have more ammo to throw at her tomorrow.
Old 11-06-09, 04:36 PM   #7 (permalink)
Also the shifter is stuck in park
Old 11-06-09, 05:13 PM   #8 (permalink)
Photoman's Avatar
This can be caused by a blown brake light fuse or short in that circuit.
In an emergency you can pop the little cover and use a screwdriver to get it out of park.
Bill
97 40th
Old 11-06-09, 05:42 PM   #9 (permalink)
Photoman's Avatar
Related to what Rick said in Post 3; at the alternator is a large connector post. In this ring terminal connector is the large wire from the battery positive to the alternator. In addition with the ring terminal, there is a feed wire that goes to the under hood fuse panel and to the inside fuse panel. Since the brake circuit is now involved it would seem that the connection at the alternator has gotten hot or corroded and now these fuse panel feed wires are not getting full or any power. Disconnect the battery positive first before working on the terminal since it will be "hot".
Bill
97 40th
Old 11-06-09, 06:25 PM   #10 (permalink)
KliersLC's Avatar
Isn't there a comprehensive no start thread that we did couple years ago?
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 11-06-09, 06:43 PM   #11 (permalink)
jonheld's Avatar
TLCA# 5980
Check fuses with a meter, not an eyeball. Eyeball=primrose path.
If the CEL is not on, the EFI circuit is not energized=no spark.
I don't have an FZJ80 schematic in front of me nor one in my driveway, but I can't imagine the troubleshooting procedure is much different from the older vehicles.
Jon Held
1991 FJ80 "Lumbering White Rhino"
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
http://www.sdsysdesign.com/tlc/
Buy your FJ80 FSM here:
http://www.sdsysdesign.com/tlc/fsm.html
jonheld is offline   Reply With Quote
Old 11-07-09, 01:57 AM   #12 (permalink)
I'll start with the alternator connections tomorrow and also recheck fuses especially brake light fuse. Any way to check relays? KliersLC, any link to that thread? I've checked the emergency startup in the FAQ and also found a bunch of stuff when I searched cns(crank no start). Others have had similar problems but don't seem to post up their solutions. Thanks again and I'll keep you guys posted.
Old 11-07-09, 09:58 PM   #13 (permalink)
KliersLC's Avatar
The one in the FAQ was the one I was thinking of.
01 Sequoia Limited
Old 11-08-09, 01:19 AM   #14 (permalink)
No luck today guys. The wire and connections from the altenator to the fuse box look clean. I'm thinking that I am not getting power to the ECU. Followed directions on this link http://gclcny.com/jh/images/Strife/3FE%20EFI%20Diag.pdf and had power all the way to step 4. No power to pin +B on check connector so I'm figuring some where between the fuse box and check connector I have a problem. That's a long way across the engine bay, any ideas where to start? There's a ton of wires coming into the ECU, any body know which one is supposed to bring the power in so I can test it?
I did replace a fuse that took care of the shifter problem.
I don't know if it helps, but I was driving in wet weather when the engine died and couldn't be restarted.
Old 11-09-09, 03:17 PM   #15 (permalink)
This is driving me nuts. I'm contemplating dealership. I've been concentrating on the CEL or lack of it. I pulled the instrument cluster to make sure it wasn't burned out and find out it isn't even there! Replaced the bulb and still no CEL. Checking wires and find that I'm not getting power to the 7.5A ignition fuse. Maybe an ECM problem? I can't pull codes or diagnose without a CEL right? Help please.
Old 11-09-09, 03:42 PM   #16 (permalink)
Have you checked/changed the EFI relay?
Something I have written down when I had CNS: Check the EB1 connection with the yellow/red wire coming from the relay.
mkfour is offline   Reply With Quote
Old 11-10-09, 02:40 AM   #17 (permalink)
Yes swapped out the EFI relay. Does the factory rs3000 alarm have a disable switch? Last thing I did recently was get a new FOB, cut a new key and program it.
Old 11-10-09, 09:23 PM   #18 (permalink)
I think I just screwed up big time! After checking wires again I found I wasn't getting power through one of the fusible links, the one with the plug which I think is the ignition circuit. The links are brand new and I should have known better, but out of frustration and reading threads of others using a jumper, I jumped this fusible link. Jumped in the car and tried to crank it. Smoke started pouring around the hood as I ran and yanked the ground wire off the battery. The jumper wire's insulation was fried. So how much damage do you think I've done? I also saw smoke coming out from the harness near the glovebox area. Do you think I fried my computer?
Old 11-10-09, 09:44 PM   #19 (permalink)
Your '95 should have an OBD-II port in the fuse panel under the dash to pull the codes (even though OBD-II compliance wasn't "official" in the LC until the '96 model year - my 12/94 build has OBD-II). A $40 code reader from Harbor Freight (or equivalent) should help with the codes.
As to the smoking wire harness...... I don't know... what guage jumper did you use?
one other thought on the lack of codes (besides getting screwed on having the CEL bulb removed) is that if you've had the battery disconnect to replace the FL's, you might have reset the codes? If an issue is present, they should return shortly?
Rob G
AZ
Old 11-11-09, 03:33 AM   #20 (permalink)
ThinkTank Waterboy
landtank's Avatar
I think there hsas been reported problem with the engine harness as it passes through the firewall. You might pull that out through the wall into the engine bay and see what it looks like. Pretty easy to do actually.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-12-09, 08:44 PM   #21 (permalink)
EWD help please
Pulled the harness like Rick said and found the burnt wire in the first pic. It is black with a red stripe. According to my Chiltons I followed the ignition circuit and checked all switches and everything seemed ok. There is another black with red stripe right next to this one with thicker gauge so now I'm thinking that may be the ignition circuit. The second pic is the harness. The four center ones are the ones I'm looking at. Of the four the bottom right is the one that got fried and the bottom left is the thicker gauge one. Both show continuity to ground. This harness is behind the glove box and connects to go over the dash to the driver side. Chiltons doesn't show the harness plug, can someone with FSM help me please?
Old 11-12-09, 08:48 PM   #22 (permalink)
What happened to my attachments?
Old 11-12-09, 09:54 PM   #23 (permalink)
Attachment 371657
Attachment 371658
ok here they are
Old 11-12-09, 11:07 PM   #24 (permalink)
ThinkTank Waterboy
landtank's Avatar
I'm having issues seeing them
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-12-09, 11:52 PM   #25 (permalink)
http://forum.ih8mud.com/attachment.p...1&d=1258095080
Old 11-12-09, 11:55 PM   #26 (permalink)
http://forum.ih8mud.com/attachment.p...1&d=1258095305
Old 11-12-09, 11:56 PM   #27 (permalink)
Think I got it this time. Help me find my short please.
Old 11-13-09, 10:07 AM   #28 (permalink)
ThinkTank Waterboy
landtank's Avatar
Can you provide the connector number and pin numbers for those wires. I can look it up in my EWD later on.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-13-09, 11:35 AM   #29 (permalink)
informationjunky's Avatar
TLCA# 6149
You might want to check the harness by the EGR pipe also.
Georgia Cruisers
Upstate Cruisers
http://www.upstatecruisers.net/
TLCA 6149
86 FJ60 - first and RIP
95 FZJ 80 - second RIP
97 LX 450 - Current
locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor
98 LX 470 - wifes
informationjunky is offline   Reply With Quote
Old 11-13-09, 01:59 PM   #30 (permalink)
Sorry I don't know the harness and pin numbers. Is it marked on the plug? I know it's not listed in my chiltons
