11-05-09, 11:20 AM
100 Series Pads with DBA 4000 Series Rotors?
Before I order the 100 series break pads for my 1996 FZJ80 and it's brake/front end overhaul I wanted to ask if the 100 series pads fit with the DBA 4000 series discs? I thought I remember reading somewhere that the DBA rotors are thicker ( 1.265") than the stock OEM discs and with the thicker 100 series pads there are fitment issues? Is anyone running DBA 4000 series discs with OEM 100 series brake pads on an 80 series?
1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust.
11-05-09, 12:08 PM
I'm running that exact setup. The 100's pads will fit.
11-05-09, 12:24 PM
<100K club
Are the DBA rotors clearly better than OEM or is it just preference? Not sure what to do.
1997 LX 450, no lockers (yet), 98,000 miles, custom front bumper, OME 850+1/863, FJC steelies, 285's
1987 BJ 74 - Bone stock (A/C, PTO) gone
2001 Tacoma quad cab gone
1987 4Runner (sold at 320,000 Km's .. still driving around town!)
11-05-09, 01:13 PM
Don't know. From reading here on Mud, the factory rotors are fine. I went with the DBA hoping that the slots would help improve brake feel and I liked the idea of slotted rotors. I also had a serious problem with the rotors that were on the truck when I got it warping. A lot. Honestly I got the most improvement in brake feel when I replaced the brake booster. I would say that this is a personal preference and so long as you use quality parts you will be fine.
11-05-09, 03:13 PM
Matt - what did you replace the factory booster with? I just installed new factory 80 series rotors on my '94 with the 100 pads (no chatter shims - won't fit until the pads wear) and I can feel a bit of improvment. The lifespan I'm told is 3x over the 80 pads. What personal preference were you looking for in the brake feel with the new booster?
11-05-09, 05:38 PM
I ordered an OE replacement from CDan which turned out to be a Bosch. I did not replace the booster to improve pedal feel but because it had failed. However when I replaced it I noticed that the pedal was firmer. The braking has always been good, it just didn't feel good. The only time I have ever doubted the brakes is when the booster failed. If you are looking to replace your booster just for pedal feel that is a very expensive thing to do as new ones from Toyota are pricey. However there are aftermarket alternatives, but I don't know anything about them.
11-05-09, 05:48 PM
I am running that set up as well, happy happy joy joy, the truck stops well now. ( 37" XTerrains)
11-05-09, 08:21 PM
Are OEM pads the way to go or are there others that work just as well. I hear OEM last 3 or 4 times longer, but does that mean they are harder and wearing the discs faster? I know everything is a compromise. I'm looking for better breaking, pad life, if a lifetime pad sourced locally wears faster so be it, I'd rather replace pads than discs. brake dust isn't that bif of a concern...
Organic, semi-metalic, metalic, ceramic?
Any other brands or is OEM best? OEM are pricey, though maybe for a reason.
EBC
NAPA
Autozone
1997 FZJ80 40th
11-05-09, 08:33 PM
I seriously doubt that OEM pads will cause the rotor to wear faster. Remember these are the pads the manufacturer specified, and we're talking Toyota, not GM. The 100 series pads are larger than the stock 80 series pads and so far have been holding up well. Remember that its the pad that wears, not the rotor. Me and many others are using these pads and have been for years. AFAIK no one is reporting lower rotor life.
11-06-09, 08:49 PM
#10 (permalink)
What are the prices of the DBA rotors compared to OEM?
Has anyone had this set up on the same truck for a good comparasion of both in terms of longevity, feel, and stopping distance?
John
97 TRD SCHARGED & LOCKED 80 SERIES 89K, ARB FRONT, SLEE REAR, FULL LENGTH OUTBACK RACK, WARN WINCH & 210 LIGHTS, 4" SLEE LIFT, TOYO M/T 315'S ETC.
87 FJ 60 Rebuild in progress
86 4Runner 22re downey/NWOR lift Detroit rear/TruTrac front
KNOXVILLE, TN
11-07-09, 05:53 PM
#11 (permalink)
I paid $311.11 including shipping from the West coast to the East coast.
1997 FZJ80 40th
