Old 11-04-09, 04:45 PM   #1 (permalink)
harrydunn's Avatar
Garage
Thermostat and Rad. Cap
Are most of you guys replacing both of these with a coolant flush? OEM or is that necessary?
My base-lining continues...going well so far. Thanks for the help.
--Mark
1993 FZJ80 | Factory Lockers | 155K | PHH
2001 Grand Prix GTP Coupe | Supercharged | 58K | DD
"If the wings are traveling faster than the fuselage, it's probably a helicopter, and therefore, unsafe."
harrydunn is offline   Reply With Quote
Old 11-04-09, 05:01 PM   #2 (permalink)
I'm still in the baselining process with you, so here goes:
If you're getting good back pressure on the rad cap, it can probably stay. Of course, it's a cheap easy replacement if you so desire. I would replace the thermo; it's also a cheap easy job and gives you the peice of mind that you have a fresh one opening at the right temp. They are less than $20 from CDan.
1997 FJ80 40th edition with stuff
luk4mud is offline   Reply With Quote
Old 11-04-09, 05:08 PM   #3 (permalink)
Ebag333's Avatar
TLCA# 18864
What he said.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 11-04-09, 05:32 PM   #4 (permalink)
harrydunn's Avatar
Garage
I'll have cdan toss in a t-stat with the front axle kit.
Thanks.
Old 11-04-09, 07:23 PM   #5 (permalink)
badmuthatrucka's Avatar
TLCA# 18360
I should have done my thermostat when I redid the HG last year. Oh well... Probably do it sometime soon. Thanks for the reminder!
93 FZJ80, locked, slider-ed, with 35" TRXus MTs. Warn 9.5XP.
badmuthatrucka is offline   Reply With Quote
Old 11-04-09, 07:33 PM   #6 (permalink)
:)A YELLOW MAN(:
hatman406080's Avatar
$14.24/gasket $3.24(cdan)
hat..celestials..
1989 Fj62 190,000MiFor sale
hatman406080 is offline   Reply With Quote
