10-31-09, 08:27 AM
Turn carpet into rubber mat?
I've been anxious to get rid of the carpeting inside my FJ80. So far in my search for a rubber mat to replace it, I haven't been too impressed. I remember that someone had a brilliant idea buried within one of the threads....why not just coat the existing carpet with some rubber, bedliner or similar paint? Seems like a great solution since you know you the fit will be perfect. Has anyone given this a try? Any recommendations on what to use as the coating?
-- OC
1994 FJ80
1979 FJ40
10-31-09, 10:32 AM
I don't know what to coat the carpet with. I would think any kind of coating would crack if used on carpet.
My work van has a full length rubber mat with a "jute" backing, this is a nice setup. If you spill something just wipe it. Same thing with muddy boots. I think the FJ cruisers have a similar setup. The aftermarket needs to jump on this. Probably not enough interest to be profitable.
Good luck with this project, keep us posted on what you find.
Brad
91 FJ80 AKA- Landsnoozer
George's front and rear dome lights
Slee headlight harness and aux. harness
Mot's fog lights
285/75/16 BFG AT
10-31-09, 02:17 PM
10-31-09, 02:50 PM
I was on a quest for just such a thing myself. Maybe other countries, AU, SA, UAE, etc... where cruisers are less of a luxury vehicle would be a source.
1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust.
10-31-09, 03:10 PM
Originally Posted by Ebag333
Those look nice. Do you have any pics. of them in your 80?
My 80 came with some Husky liners and they did not fit very well. The PO had to cut them to make them fit better, which is still not good. They could be for another vehicle. I have not shopped them in several years.
Brad
Mot's fog lights
285/75/16 BFG AT
10-31-09, 04:55 PM
Hmm, doesn't sound like a good idea to me. The rug part would still soak up water, which is often why the rug needs to go from what I've seen in reading the posts here.
I think you'd be better off going with some of that bedliner stuff, which would tend to trap water less and prevent further rusting of the floor underneath.
My first Landcruiser was a FJ55 and it came with rubber, not carpet. It did have some sound-deadening on the back, but it was loud. But I'm sure you're anticipating that if you're going this way. Personally, that's why I like our new/used 80. It's so much quieter than the old ride.
Mike
'97 FZJ80 The Sacred Cow
143k, CDL switch w/ 7-pin mod, cupholders!  , PHH, 400-watt inverter, working power antenna, other electric stuff, ye olde SSB CB, PO-crappy tires and rims
10-31-09, 10:29 PM
I don't have any in my truck. TOY350 has them and they fit just about perfect. Obviously designed for the 80's, though there is a bit of play in them.
Cool part of them is that they all have lips, so if you get water, mud, sand, etc in them, it stays in there (until you pull it out). TOY350 really likes his, and I would get a set if I didn't intend to bedline the floor of my truck.
10-31-09, 11:18 PM
I have the Huskies and they fit great. The second row seat liner blocks the rear heat a little.
Or try E9999's idea: http://forum.ih8mud.com/80-series-te...-more-$14.html
1996 T O Y O T A LAND CRUISER FZJ-80
132K, Locked, Snorkeled, Pin7+CDL, ARB front Hella'd, IPOR rear and skid plate, Metal Tech Sliders, Slee 4", 4.88's, 35" Cooper STT's, 17" Sequoia wheels, Line-X'd roof Warfield Storage System
11-01-09, 07:36 AM
Just keep checking ebay. I saw an OEM molded rubber replacement for the carpet not too long ago when I was pricing Husky mats. I just tried searching completed listings but couldn't find it again.
11-01-09, 07:37 AM
#10 (permalink)
11-01-09, 10:06 AM
#11 (permalink)
flooring
if i was going to go through the hassle of pulling all the carpet and sound deadening material from my 80's I would just take it and have it Line-X'ed or have some type of bedliner sprayed in. If you're that concerned about ditching the carpet, seems that it would be in your better interest to ditch it all. I've seen the PVC floor coverings that you can get, they're not bad, but you would need to put down a mild adhesive to prevent them from moving around. Even then, you chance moisture getting caught under it..
just my $.02
11-01-09, 10:28 AM
#12 (permalink)
floor mats
You might want to look at these
Mats Floor Aussie
Mike El Paso, TLCA 8009
1985 FJ-60,
M-416 trailer.
1977 FJ-40, BDS. Metal Tech, lock rite
2005 Ural Gear Up
http://community.webshots.com/user/mep1811
We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm. George Orwell
11-02-09, 11:34 AM
#13 (permalink)
OHV Trail Patrol
I run Huskey Liners and they are great... I don't have any pics of mine in the rig, but this is what they are.
HUSKY-LINERS-64001-BL-R126831 Husky Liners 64001 Black Rear Floor Liner
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
11-02-09, 12:39 PM
#14 (permalink)
I am contemplating pulling my carpet from the rear and replacing it with this Diamond-Grip (Diamond Steel Deck Pattern) Rubber Mats and Runners.
I have sound-deadening already installed and will just lay it on top.
I'm not lost......I'm exploring! ‹
97' LC 40th AE #2722, Slee Rear bumper, Hanna Sliders [KJ6BDJ]
11-02-09, 12:47 PM
#15 (permalink)
Pronounced Cal-Dee-In
In my old '88 FJ-62, I painted the carpet in the cargo area with Herculiner (bought at Autozone) and it came out great.
I only had the vehicle for a year after Herculining the carpet, but it held up pretty well during that period.
I think a small can was $30 or so; not too expensive if you wanted to experiment on some scrap carpet or floor mats.
1997 LX450 Factory Locks, de-racked, OME 2.5", 285/75 BFG, MetalTech Sliders, Cobra CB, PHH, HG, Blue Fan Mod, Cup Holder, Slee Shortbus, Mile Marker 12K Hydraulic
1988 FJ62 - R.I.Pieces due to frame rust
11-05-09, 02:33 PM
#16 (permalink)
Guess I should have thought it through more to begin with. Less than 6 months ago I completely sound-deadened my FJ80. Otherwise, the bedliner route is probably the way I would go if I could be convinced that it dampens noise fairly well. But after the fairly large investment, I certainly don't want to tear it all out and start over. This is why I primarily looking for something to lay over it now.
-- OC
1994 FJ80
1979 FJ40
