Old 10-31-09, 01:52 AM   #1 (permalink)
GAS-A-LOT!'s Avatar
91 FJ80 She wont turn back on when hot?
A few days ago, I tried to turn her on and she turned but did not run. I was like....OH no! Ignition coil? loose hose?
After like 4 minutes I tried again and she worked! Then the next day it happened again! And, again, a few minutes latter, She turned on after one try............. I check the engine bay but nothing seems a-miss.... Anyone have an past experience similar to mine? could the computer be acting up?
Ron
HELO?....is this thing on?
1991 fj80 's but I drive it, suspension air bags, roof rack, trailer 8pin connection, 7 pin mod, hood spacers & stolen radio. 1985 fj60 (DD)HID-xenon retrofit projectors, tailgate storage, rear seat shoulder belts, 62 rear sway bar, & roof rack. 1987 4runner, seat bracket spacers(4crawler.com), driver side battery, HID-xenon retrofit projectors, & modified/upgraded intake, rancho shocks.
WWW.RONSERRANO.COM
GAS-A-LOT! is offline   Reply With Quote
Old 10-31-09, 05:44 AM   #2 (permalink)
TLCA# 2432
efi relay under hood in black fuse box. Mike
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
Michael Hanson is online now   Reply With Quote
Old 10-31-09, 06:47 AM   #3 (permalink)
Snowtire's Avatar
Pressure relief valve in fuel pump can generate symptoms like this, too.
1991 FJ80, 235K, (paraphrasing Elwood) It's got a tractor motor, it's got tractor tires, tractor suspension, tractor shocks. It's got no catalytic converters so it'll run good on regular gas.
1997 40th Anniversary #0030. Grocery getter.
Snowtire is offline   Reply With Quote
Old 10-31-09, 07:41 AM   #4 (permalink)
jonheld's Avatar
TLCA# 5980
If she cranks without firing only when hot you need to look at your CHECK ENGINE light. If the key is in the ON position and the CE light is off then it is EFI circuit related. If the CE light is on then it is most likely fuel related.
Jon Held
1991 FJ80 "Lumbering White Rhino"
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
http://www.sdsysdesign.com/tlc/
Buy your FJ80 FSM here:
http://www.sdsysdesign.com/tlc/fsm.html
jonheld is offline   Reply With Quote
