10-30-09, 08:36 AM
Washer Bottle Relocation?
Is Slee the only company that makes a prefabbed washer bottle relocation kit?
Locating parts before I attack my dual battery install and I just wanna weigh my options before making my own bracket
10-30-09, 08:41 AM
I think so. I recall reading a thread where a guy made some brackets for 95-97 models to use an earlier FJ80 bottle inboard of the 95-97 stock fuse box too.
1996 FZJ80, Elec. Lockers, Center Diff Button, OME 850/863 2.5", 305 BFG MT's, ARB, Warn 9k, Slee Rear Bumper w/ Tire carrier, LightForce 240's, George's LEDs *In progress* Aussie Sub Tank, Dual Battery & Aux. Fan
2005 Audi A4 UltraSport S-Line Quattro, 6 speed manual - bone stock and quick!
10-30-09, 08:45 AM
ThinkTank Waterboy
I made a bracket that allows you to use a 91/92 washer bottle in a later 93-97 truck. It's more of a charcoal canister relocater as that is what is in the way.
But this doesn't relocate the existing washer bottle, it totally eliminates it. It was done to allow a dual battery setup with a super charged engine.
Rick Bigelow
'96 215k
Groveland MA 01834
10-30-09, 08:49 AM
Yeah, I was reading through that thread earlier.
Nice clean setup, but I don't want to replace the OEM bottle.
10-30-09, 10:45 AM
Landtank - Didn't you put the bottle in between the fuse box and charcol canister?
10-30-09, 11:06 AM
Here's my original pre-supercharger install:
And here's with a Corolla bottle post-supercharger install:
Washer Relocation
No, I don't make sell them. I no longer have the wood template to make the Corolla relocation bracket.
cheers,
george.
where ever you go, there you are....
'97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx
http://www.george4wd.taskled.com
10-30-09, 11:07 AM
ThinkTank Waterboy
Originally Posted by S.CarolinaFZJ80
Landtank - Didn't you put the bottle in between the fuse bow and charcol canister?
the earlier bottle bolts to the fender and has a second bladder that is inside the fender for increased capacity. So the fuse block needs to go where the charcoal canister is and the charcoal canister needs to move out to make room for the fuse block.
The other option was to go with a Camry or similar washer bottle and wedge it up against the fire wall where the Slee bracket moves the factory one. That works but it is rather small and with our rear window washer setup it would run dry kind of quickly in dirty environments.
Rick Bigelow
'96 215k
Groveland MA 01834
11-03-09, 08:34 AM
I did my own - it's not hard to make, and it seems about 1/2 the people using the Slee one have issues with fit, so if you're going to have to goof with it anyway....
edit - here's the link to issues w/ slee's mount
http://forum.ih8mud.com/80-series-te...eeded-pls.html
like my sig says, I prefure to build if I can
http://forum.ih8mud.com/80-series-te...ters-plus.html
It could be done w/o welding if need be.
'97 LX450 - locked, Mickey Thompson MTZ 315's, J's, Rancho RS9000XL 14" shocks, RSC remote shock control 3" front drop brackets, 1" body lift, FOR custom front bumper, and a plethoria of rock lights
Owner fabed rotating slider steps, rear bumper / winch and hitch, front and rear extended shock mounts, front spring spacers 1.375", front swaybar drops, rear bumpstop drops, rear swaybar extensions - 'If I can fab it, I won't buy it!'
11-03-09, 08:40 AM
On the Golf Course!
IPOR used to have one they sold as part of a complete dual battery set up. Don't know if he still does or not.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
11-03-09, 09:38 AM
#10 (permalink)
I made my own mounts on my 97 LX out of some scrap alum pieces. I used the stock tank, and rerouted the plumbing. It sits behind and next to the cruise control module. Used existing threaded holes and bolts for my mounts.
97 LX-450, 119k, Dual Batteries, Pin7/CDL mod, Slee harness/HIR's, LED's inside, no factory roof rack, some other homebrew mods, Airlift helper bags, and 285/75/16 geolander II's.
11-03-09, 02:06 PM
#11 (permalink)
If you are not adding a supercharger then you will have space to relocate the original.
If you plan on adding one later go ahead and find a Corolla bottle as prat of the relocation.
96 LX450 factory triple locked, 285/75/16 BFG A/T, Metaltech sliders, OME 850/860, ARB w/ Warn XD9000i, Slee rear, Kenwood 5120 NAV/DVD, CDL+7 Pin, Dual 31M Marine Platinums, OEM aux tank installed (plumbing in progress), used SC still siting in my garage.
11-06-09, 07:13 PM
#12 (permalink)
11-06-09, 10:08 PM
#13 (permalink)
As Brent mentioned Lance at IPOR does have a bracket that is an easy install. You'll have to call as it hasn't been listed on the web site for some time.
1994 80 - Some stuff
1988 4runner - cute little brown thing affectionately known as "sh*t stain"
Those who can, do; those who can't, criticize - Unknown
Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough.
Sir Henry Royce
Co-founder, Rolls Royce
11-07-09, 10:13 AM
#14 (permalink)
Pinoy 4WD Journey
I fabricated my own washer bottle relocation bracket using George design  .
Snake eater, what color is your valve cover? Nice paint though.
Noel
97 LX450 unlock, IH8MUD decals, CDL/Pin7, HIRs, Cup Holder, 100 pads, GS LEDs, OEM grab bar, sidemarkers, ARB bar/XD9000, PIAA 520, 295/75R16 NTG, Kaymar Deluxe/tire carrier, OME850J/863, Slee speedo gear/SS brakelines/caster plates, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter, auto up and H2O temp mods. Need install: OEM subtank, BIC 95300B dual batt, blue fan clutch, OEM rear locker, 2.2kw...
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, sliders
11-07-09, 11:34 AM
#15 (permalink)
It's Pontiac Engine Blue (I had some leftover when I changed the valve cover gasket/seals)
