10-28-09, 07:15 PM
62 TCase In A 95
Can a FJ62 tcase be installed in an 80? Probably need adapters.
Thank you,
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
10-29-09, 04:35 PM
OHV Trail Patrol
In my limitied knowledge, there is not an adapter made for this. However, it seems like the you should be able to bolt it up to an early 440 auto... Maybe swap tailshafts on the 440 to the 62's tail? I really wish someone would start playing with these things...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
10-29-09, 06:03 PM
always broke
Amen to that Chad, I want a split case...NOW. Aussie lock'd front and rear now and it just don't feel right running with the hubs unlocked and everything else spinning. It works....but just doesn't feel right.
10-29-09, 08:40 PM
livin a poor college life
What about a front driveshaft disconnect? I've looked those up, why is the typical price over $500??
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
'04 Crate 4-string bass, Ernie Ball Slinks, stock
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
10-29-09, 10:16 PM
always broke
Plus I'd have to modify the front shaft....
10-29-09, 10:39 PM
Brian at ACC Toyota made his own parttime for his 80. Its holdin up to some serious abuse. Were gonna part time my dads 80 as well. Im sure he could do yours too.
Will
Will
Samurai, locked, swamped (38.5s) and rolled
10-30-09, 04:45 PM
OHV Trail Patrol
Will
Details needed! My Longfields would love you...
KE7VSA - MetalTech
10-30-09, 05:24 PM
more info on this
11-05-09, 03:43 PM
always broke
...bump
11-06-09, 07:43 AM
#10 (permalink)
Need more info
91 FJ80, 3" OME, 35 BFG AT, ARB, T-Maxx 10K, 5:29's, Aussie Rear, Dual Optimas, 1" Body, Homemade Rear Tire Carrier.
11-06-09, 11:01 AM
#11 (permalink)
A case out of an FJ-62 will obviously not bolt up to a FZJ tranny. And I doubt that anyone will ever offer an adapter, I hope somebody would. I have an FJ-80 and I plan on installing an A440F out of a 62 with the 62 split case when the driveline goes back in. But after the FJ-80 I don't think an A440F from a 62 will work with the FZJ, isn't the ECU connected somehow to the tranny in the FZJ? Next will be to put an H55 into the 80. In my FJ-60 the 3FE + H55 work well togther, too bad they nevfer offered the 80s in stick here.
Andrew
75' FJ-55 (SOLD)
87' FJ-60 (3FE-H55-Marks gears)
92' FJ-80 (next project)
01' Taco (stock)
11-06-09, 03:39 PM
#12 (permalink)
OHV Trail Patrol
IIRC, 80's had the A440 trans til '95... What is the difference between those and the A440 in the 62?
KE7VSA - MetalTech
11-06-09, 03:56 PM
#13 (permalink)
Electronic solenoid control.
Which makes them REALLY cool. only the coolest kids have them.
I would think it would be easiest if one wants a split case to start at the Engine fan and work back...
LS1, 4l60E, split case
LT1, TH400, Split case
4BT. Th400, split case
You get the idea.
93 FZJ80 Locked OME 2.5" ARB Non-winch "My greatest fear is that when I die, my wife sell all my s--t for what I said I paid for it."
11-06-09, 03:58 PM
#14 (permalink)
OHV Trail Patrol
I ment about the case and tail shafts... Could you mix and match parts to make an A440E that bolts to a split case?
KE7VSA - MetalTech
11-06-09, 04:06 PM
#15 (permalink)
As far as I know, they are the same case and tailshaft, but I could be wrong.
