Old 10-25-09, 09:27 PM   #1 (permalink)
IdahoDoug's Avatar
Near disaster wrenching tonight...
So I'm finally getting time to put the head back on my wife's 80 today. It was tough walking past that pristine head sitting on the workbench all shined up and wrapped in plastic from the machine shop all week. My brother in law walked over to help me get the head set in place on the new gasket and hung around to yak for a minute. Good thing, too.
While putting washers on head bolts and dropping them into the bolt holes, I picked up a washer and another stuck to it briefly. It fell off, bounced off the radiator tank and landed right in the timing chain opening. We listened as it ricocheted its way down into the bowels of the engine. You could have heard a pin drop. I deadpanned "Well, guess you're about to see me pull the front of the engine off rather than put the head back on...". Unbelievable - the odds that it fell off at just the right moment, then bounced the right direction and went right down that slot.
I couldn't see it looking down through the head slot, so we pulled the few bolts and lifted the head back off the engine and put it on the bench. I could then see the washer precariously balanced against the timing chain down near the lower timing gear. I extended my little magnet retriever thing fully and was just able to get it. Then just a bit of drama as it kept grabbing onto every steel projection on the way up, including the chain. I got it back out and I don't think I've held my breath that long in a while.
I was planning to button it up tonight but friends stopped by unexpectedly for dinner so I had to put the tools down and get cleaned up. Got the cams installed, so now it's just assemble a bunch of bolts and set the timing tomorrow. A big "WHEWWWWWWWW!!!....." here in N. Idaho tonight.
IdahoDoug is offline   Reply With Quote
Old 10-25-09, 09:33 PM   #2 (permalink)
TLCA# 2432
Bad luck turned into good luck. Mike
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
Michael Hanson is offline   Reply With Quote
Old 10-25-09, 09:34 PM   #3 (permalink)
kup99's Avatar
Glad you were able to fish it out and the story has a happy ending.... almost.... it's not put together yet, but at least it will be now!!
Good Luck!
Darren
97 FZJ80,OME J's, ARB, SLEE with Gas Carrier Swing Out, 38 Gal. Fuel Cell, Warn 8K, CDL & Pin7, 285 BGF AT's, Hella Lights, AO Roof Rack, Water On Board
1999 Ford Mustang SVT Cobra
Calgary, Ab. Canada
kup99 is offline   Reply With Quote
Old 10-25-09, 09:42 PM   #4 (permalink)
beno's Avatar
TLCA# 14607
About time you got working on that "pristine" head....
Good stuff Doug.
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
beno is offline   Reply With Quote
Old 10-25-09, 09:49 PM   #5 (permalink)
IdahoDoug's Avatar
Yeah, it is. It's been killing me walking past it and all my tools laid out, favorite CDs ready to jam, etc.
I'm just glad someone was there to witness the incredible "hole in one" of a lifetime!
DougM
Old 10-25-09, 10:09 PM   #6 (permalink)
firetruck41's Avatar
TLCA# 14300
Now remember to be careful with those washers when you reassemble... again.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is offline   Reply With Quote
Old 10-25-09, 10:21 PM   #7 (permalink)
Ebag333's Avatar
TLCA# 18864
Pics or it didn't happen.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is online now   Reply With Quote
Old 10-25-09, 10:48 PM   #8 (permalink)
IdahoDoug's Avatar
Those washers are currently pinned in place with about 125lb-ft of torque so they're not going anywhere. Ever.
DougM
Old 10-25-09, 11:26 PM   #9 (permalink)
medtro's Avatar
Will this be added to the tips for DVD?
Copper State Cruisers #005
medtro is online now   Reply With Quote
Old 10-26-09, 12:05 AM   #10 (permalink)
I had the nut off of a feeler gauge pop off at the same, inappropriate moment and it did the pin-ball ricochet all the way down the timing chain opening too... i must have spent hours fishing from the top, and from the bottom with my magnet... no luck. I finally turned the motor over by hand a couple of times to make sure nothing was binding up, buttoned it back up and fired it up with a baited breath...
Only the sound of a smooth running motor...
I've been running it for about 3 months now and have done 2 oil changes... It's still down there somewhere! Talk about avoiding disaster!
tdkhelene is offline   Reply With Quote
Old 10-26-09, 12:33 AM   #11 (permalink)
arndog123's Avatar
I dropped a feeler gauge down my '86 22RE while doing a valve clearance check. Tried using a magnet for about an hour and gave up. The next day I had to drop the front diff in order to get the oil pan off.
1997 CE Land Cruiser: Locked, ARB w/ M12000
1996 LX450: Locked, ARB w/ no winch yet
1990 XtraCab 4x4 pickup: ARB w/ M8000
1986 Standard cab 4x4 pickup: Locked, ARB w/ XD9000
1985 XtraCab 4x4 pickup: ARB w/ M8000
1995 Acura Integra (Daily Driver)
arndog123 is offline   Reply With Quote
Old 10-26-09, 05:54 AM   #12 (permalink)
ThinkTank Waterboy
landtank's Avatar
any chance you got those measurements for me?
Rick Bigelow
'96 215k
Groveland MA 01834
Old 10-26-09, 11:08 AM   #13 (permalink)
alia176's Avatar
Doug,
I'm not in the loop. Why did you have to pull the head? Didn't you go through both engines couple of years back?
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 10-27-09, 03:46 AM   #14 (permalink)
KliersLC's Avatar
X2 /\
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 10-27-09, 10:40 PM   #15 (permalink)
IdahoDoug's Avatar
Rick,
I got a note on the head from the shop that the head bolt washers are 920 thousandths of an inch outside diameter (OD) and that they could not get a measurement on the recess the washers sit in because of the depth. I have a head sitting here now, so if you can think of an instrument that would be able to measure something down 6" into the head I'll see if I can locate one and get the measurement.
Alia/Dan/others:
The 97 which we bought used and had the cracked head (fiasco thread a few years ago) started drinking coolant again a few weeks ago after 58,000 miles. Pulled the head and the head was cracked in the identical spot one cylinder over (#4). So, rather than work on an obviously stressed head, I got a used one from Beno and had it rebuilt and milled by the same shop here that's done such a great job on 80 heads. Got it back a week ago and finally had time to put it together. Started it this evening and it's humming nicely. Will drive it tomorrow, then flush the coolant system and oil change. Whew. I'm tired, but glad it's all together. Did a bunch of things while in there, and learned that if you want to clean the head bolt threads on your 80 block you need a 1.25 pitch which nobody around has. 'Cept me, now....
Also discovered the entire fuel system can remain intact - I just shoved the entire intake manifold and EFI system out of the way and yanked the hread. Limited usefulness as if you're up in miles it makes sense to renew the injector seals but big time saver in right circumstances (like if you've just done it 58,000 miles ago...).
DougM
Old 10-28-09, 03:34 AM   #16 (permalink)
KliersLC's Avatar
Sorry to hear about that Doug, but I am glad you got it back together. Perhaps this was a result of all of your April Fools threads claiming "another head gasket blew" j/k
-Dan
01 Sequoia Limited
Old 10-28-09, 06:05 AM   #17 (permalink)
ThinkTank Waterboy
landtank's Avatar
thanks Doug!
Rick Bigelow
'96 215k
Groveland MA 01834
Old 10-28-09, 10:38 PM   #18 (permalink)
IdahoDoug's Avatar
She's running better than ever. Took the opportunity to replace the fusible links as I had the battery connections off, and a couple other little things along the way. Added several more items to the Tip Sheet that goes out with each Head Gasket DVD. Like finally noticing that the exhaust manifolds each have one set of tighter holes when you install studs. Do them first and all is well. Don't and you'll be puzzled why it was such a fight to get the others aligned....
Got new winter Michelins ready to put on and I'm going to flush the coolant before giving her back to my wife again. I'm driving it for a few days. Engine seems inordinately smooth now and starts instantly.
DougM
Old 11-09-09, 02:33 PM   #19 (permalink)
The quick brown fox .....
Beowulf's Avatar
Just caught this thread and was wondering the same thing. Thanks for filling us in.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 11-09-09, 04:21 PM   #20 (permalink)
freshspecbluegt's Avatar
I read this two weeks ago when you posted this and though wow that was lucky.
Fast forward to Saturday. I'm rebuilding a 3.slow and have it on a stand, I was putting the driver side head on and my finger retaining the washer on the headbolt slipped and and washer fell right off bounced and went right through the oil return on the head through the block and into the pan. Then I got the end of my magnet stuck in there trying to fish it out. Now I get to take the pan off and clean up all that FIPG again. Wish my luck had been as good as yours!
Ross
1995 TLC, 145K, Nightshadow Pearl, Factory Locked, 285's, Metal Tech Sliders, ScangaugeII, baselining almost done, 850/860 sitting in boxes waiting to be installed....
freshspecbluegt is offline   Reply With Quote
