I'd like any advice on this the board can provide.
I had a shop install 4.88 gears and ARB air lockers front and rear for my '97 FZJ80. I took the 3rd members to them for the work and I did the remainder of the work. Everything works well with one exception...
I first noticed it after I reinstalled the 3rd member and before plumbing the air line or actuator. After driving at highway speed the rear unit pumps a small amount of oil out of the air fitting on the 3rd member casting (enough to fill the cup of your hand). It does this after a drive at 60+ mph once it's parked. I don't think it's pumping oil while driving because I don't find oil blown around the rear end of the truck - only after parking.
I've checked the rear axle vent thinking it was blocked and allowing air pressure to force the oil out. Not so. The air line is fully open and I can blow compressed air in through the axle fill plug and it blows out the vent. No restriction.
I've since plumbed the air line. The ARB engages and disengages just fine. There are no air leaks into the rear diff from the pump when it's engaged. I thought maybe the air ring actuator was torn and allowing oil to be pumped out there. Not so. It's working fine.
It took the truck back to the shop that did the 3rd member work and they are talking with ARB. No answer from them so far. Another shop in the area said they had a similar issue with ARB air lockers with 4.88's. Something about the gear ratio and locker combo in late model FZJ80.
ARB apparently has some sort of pressure release valve to install inline near the rear 3rd member that in someway addresses this. Although I don't have the details on this yet.
Any ideas out there? I'd appreciate to know if anyone else has this gear ratio and ARB air locker combo in a late model 80 with simialr problems? Or any ideas for troubleshooting?
Thanks for your help!
