09-14-09, 11:19 PM
Supporting Vendor
Stock subwoofer replacement
Who would be interested in a subwoofer that is a direct fit for the stock location but performs better?
09-14-09, 11:27 PM
I'll bite......whatcha got?
09-14-09, 11:30 PM
Supporting Vendor
Going to be testing a handful of subwoofers we have access to over the next couple weeks to see what performs better on the OEM setup without touching anything except the subwoofer itself. No additional amps/wiring/etc...
We've had some really good luck on other Toyota platforms with OEM replacement subwoofers. I'm guessing the results will be pretty nice on the 80 series as well. I'll update as we test.
09-14-09, 11:33 PM
09-14-09, 11:35 PM
1997 FZJ80, 148k, locked n stock w/ the happy dial & magic switch. Desert Dune Metallic / Collector's Edition, build date 10/97
1967 VW Type 3 Fasty, original w/ papers & plenty of patina
Bikes: Speedvagen CX / Ventana El Padrino 29er / Bontrager, Kirk, and DeSalvo road
09-14-09, 11:38 PM
09-15-09, 04:50 AM
Very interested.
96 LX450; Locked; 2.5" OME; 4.88; Nitto 295/75/16 TerraG; CDL Pin 7; Second battery; Slee's light harness and sliders; IPOR skid, ARB, M12000.
09-15-09, 05:01 AM
Location: recently moved to houston (Vidor, TX is home)
Are you testing with an LX and LC?
96 LX450 factory locked; Procomp 14" aux fan; aluminum roof rack; a few scratches. 98 Cobra DD.
Republican because everybody can't be on welfare. "The best social program is a job." - Ronald Reagan
09-15-09, 07:18 AM
LX interest
I'd be interested in an LX version.
1975 FJ40 - Stock with factory PTO - Never Should have sold
1988 FJ62 - Stock - Sold to fund purchase of pink panties
1996 LX450 - Stock, previous owner welded on damage muliplier
09-15-09, 08:21 AM
#10 (permalink)
Cars&Guitars, Pedal Down!
Pound that. I'd be interested to know what will fit, even if it requires an aux amp.
09-15-09, 09:49 AM
#11 (permalink)
Sho'Nuff
me too
96 LX450 SLEE 4" Metaltech Sliders LandTanks MAF ARB front bumper 315 Toyos Trailgear 1.5 spacers 4.88 gears Bud built TRE w/OEM ends Safari Snorkel Hanna bumper on order KI6RGS
09-15-09, 09:59 AM
#12 (permalink)
Supporting Vendor
If someone can find a center console out of an LX that I can get here for testing I can make sure it will work in the LX as well. I'll pay for it of course, just haven't been able to find one yet.
09-15-09, 10:02 AM
#13 (permalink)
I want to know whats a good replacement SUB WOOF for my 96' LX-450........? The stock one sounds cheeeeezey man!.....help.....
96' lx-450, factory E-lock, 2.5 OME, 285-75-16 cooper STT's, 7pin, CDL,.....
"Gods country is addicting, its easy to get hooked"
09-15-09, 10:14 AM
#14 (permalink)
Isn't part of the issue there with the amp that drives it?
You probably will need a small amp to drive a reasonable sub to get good response there. When I removed my sub, it had hardly any sound coming out of it, which I determined was the amp. When I unplugged it, the headliner speakers started working. I just replaced with a small self-contained unit that fit in there.
That being said, if you can get something together that will work in there, that would be great!
'97 80 - Now with some stuff  , and still hungry.
'01 4runner - Girlfriends, but mine to service.
09-15-09, 10:16 AM
#15 (permalink)
Supporting Vendor
If your amp is working, it will do fine. If your amp is not working, then that's a whole other story.
09-15-09, 10:59 AM
#16 (permalink)
Would be interested in options for the 80 (blown)
Would be interested in options for the LX for better sound (still working for now)
Don't have one to send you but I have a pic of what it looks like...Not that it will help much but...
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
09-15-09, 12:06 PM
#17 (permalink)
I think most people would agree the factory sub amp is underpowered and a hassle to fool with when doing audio installs and would probably be up for replacing it with something that will help deliver some meaningful bass notes.
If I can assist by taking measurements (no, you can't have my console!  ) then I'd be happy to do that in the meantime.
Let me know.
09-15-09, 12:30 PM
#18 (permalink)
Supporting Vendor
Does anyone have more detailed pictures of the LX assembly where the sub actually mounts? Can someone take some photos of the LX sub/assembly with a tape measure or ruler placed along one side of the sub, and then diagonally across the center of the sub?
09-15-09, 12:54 PM
#19 (permalink)
If no one gets to it for you before mid-October I'd be happy to get you what you need...I just won't have time until then. IIRC the sub is just a little 4" one. Some more pics of the console etc. can be found here if you are interested in the time being
http://forum.ih8mud.com/80-series-te...e-removal.html
09-15-09, 01:54 PM
#20 (permalink)
I will be passing through Austin the first weekend of Oct. for a local club run to Marble Falls. You should join us. You could take a look at my console and take all the measurements you like. Depending on how long you need it, I might be able to leave it with you for a bit. Let me know.
09-15-09, 02:08 PM
#21 (permalink)
Do you need an actual console, or will dimensions work?
Good luck finding a 4" sub. I did find one that looked like a good option, but it was only available in the UK for a short while and is no longer produced.
If you could find a sub and amp to replace the existing sub and CD changer (as the changer is useless), I'd bite in a heart beat.
09-15-09, 04:00 PM
#22 (permalink)
Why is the changer useless? Mine works well.
09-15-09, 04:40 PM
#23 (permalink)
Ditto...And I've picked up a couple extra cassettes for cheap on ebay that I've loaded up with CDs. Granted, an Ipod/MP3 ready or capable head unit would be great and negate the need for CDs all together but until then CDs it is for me
09-15-09, 04:55 PM
#24 (permalink)
Neither of mine works. SOMETIMES they'll work. If you're not in motion. And the engine is turned off. And you don't speak. Or move. Or blink.
It's really common for them to be incredibly sensitive to vibrations that render them essentially useless. TBH, I forget they are there.
09-15-09, 05:26 PM
#25 (permalink)
I'm interested, however it would have to be as cost effective & sound as good or better than the Kenwood KSC-SW10 that others have mounted into the LC OEM location. Kenwood powered sub can be had on Ebay for approx $150 shipped.
Kenwood - KSC-SW10
Rising Sun 4 Wheel Drive Club Member
1976 FJ40, A project with little progress.
1985 FJ60, wife wants me to sell it, you want it?
1997 FZJ80 40th Anniversary, daily driver
09-15-09, 05:49 PM
#26 (permalink)
So Baktasht, what have you come up with?
1996 FZJ80, Elec. Lockers, Center Diff Button, OME 850/863 2.5", 305 BFG MT's, ARB, Warn 9k, Slee Rear Bumper w/ Tire carrier, LightForce 240's, George's LEDs *In progress* Aussie Sub Tank, Dual Battery & Aux. Fan
2005 Audi A4 UltraSport S-Line Quattro, 6 speed manual - bone stock and quick!
09-15-09, 06:21 PM
#27 (permalink)
Tarheel Deadhead
Very interested... mine is toast.
Wife
3 Boys
Yellow Lab
1977 FJ40, All Original-Un-Restored, No Rust, Colonial Mustard
1997 LX450, OME 850/860, Aussie Locked, CDL/Pin 7 Mod, Revo 285s, 4xI Sliders, ARB Bull Bar+M12000, Slee Harness+HIRs, aatlas1x's 100% 2-tone leather, ScanGauge II & a bunch of HG PM parts in the Garage!
1989 FJ62 Alum
09-15-09, 11:23 PM
#28 (permalink)
Right now I have a Kicker 6.5" Mid Bass speaker mounted on to the factory bracket. It's powered by my Alpine 5 channel amp. It doesn't produce sub-woofer bass, but fills out the bottom end a little bit and with the bass shakers my stereo sounds pretty decent right now (the factory door locations have the usual Pioneer 2 way replacements).
I'm going to be building a box and mounting a shallow mount 8" Kicker subwoofer in the near future...also in the factory location. I don't want it to look like I have something else in there other than a factory speaker. I'm anticipating the improvement in bass will be significant.
09-16-09, 07:40 AM
#29 (permalink)
Supporting Vendor
[QUOTE=Ebag333;4785754]Do you need an actual console, or will dimensions work?/QUOTE]
Just the dimensions will work for now.
Going to be testing a handful of subwoofers we have access to over the next couple weeks...
Give me a week or so and I'll get back to you with some preliminary results
09-16-09, 09:27 AM
#30 (permalink)
Supporting Vendor
Okay, tore everything apart and looking at various woofers we have to see what will work best without modifying too much.
