Old 09-10-09, 12:22 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
CycloSteve's Avatar
Dyno Results
Ok, I have not found much with dyno results (yes I did search), so figure it is time to start a thread. Perhaps not your normal item on the list for the Cruiser crowd.
Basically I am helping Baktash and EMS Powered with the R&D efforts for their upgraded FZJ80 exhaust system. As part of the Beta testing, a pre-install and post-install dyno was the best way to see what real gains the system might provide.
Several folks are taking part, and my rig is one which has the TRD supercharger, so a good baseline could be found for similar rigs.
Luckily there is a great all-wheel-drive dyno within a 30 minute drive from my place, and they arranged for a good price for two separate visits.
So, off I went today for my pre-test. Here are a few observations, comments, pictures, and of course video. Enjoy.
• Location = 034 Motorsports, Fremont, CA
• Altitude = 56' above sea level
• Date = 09/09/09
• Time = 18:11
• Temp = Appx. 75 degrees F
• Humidity = Moderate
• Fuel = 91 Octane pump gas – Union 76
• Tire PSI 48 = rear, 46 front
• Strapped down at the axles front and rear
• Runs all done in 2nd gear with 2nd gear start button engaged – necessary to keep the trans from downshifting
• 2000 – 5000 rpm was the designated run-range
• Peak HP = 168.8hp @ 4500 rpm - at the wheels
• Peak Torque = 212 ft-lb @ 3250 rpm - at the wheels
Observations:
• Dropping boost between 3000 and 4000 rpm, then rising again
• Serious change in AFR starting @ 4000 rpm, very rich
• Maximum boost = 6psi
• The three runs were very consistent, with minimal variation
All in all I am pretty happy with the results, as the drivetrain and oversize tires, etc are eating quite a bit of power and this dyno is known to be very-very conservative in the ratings. Looking forward to the post-exhaust installation. Once that is done, will be looking to sort out the AFR issues.
Definitely the trip to the dyno is not for anyone who has concerns with the health of their vehicle. With the stress, I am sure that some rigs would definitely have problems…it is not normal duty cycle to be flogged at WOT to redline for these rigs.
YouTube - cyclosteve's Channel
1996 TRD Kazuma FZJ80, ARB Lockers w/factory magic switch & dash light mod, CDL 7-Pin, 4.88's, OME Heavies, Slee Short Bus & Sliders, Warn 9.5, Black Powder Coat wheels, BFG AT 35's, 4x4 labs rear with spare and bike mounts, Lightforce 170's, EMSPowered 2.5" exhaust...Hula Girl Tilt-o-Meter
CycloSteve is offline   Reply With Quote
Old 09-10-09, 12:56 AM   #2 (permalink)
Ebag333's Avatar
TLCA# 18864
Thanks for sharing. Interesting results, can't wait to see the post version.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 09-10-09, 02:26 AM   #3 (permalink)
So those hp and torque numbers are with the supercharger right?
bignasty is offline   Reply With Quote
Old 09-10-09, 02:34 AM   #4 (permalink)
LockedLX's Avatar
TLCA# 8675309
It's not?
Thanks for sharing. Do you know what the advertised crank HP/TQ numbers are for the blower at 6 psi?
'97 LX450 - 136k, tree & rock enhanced
'95 Volvo 854 Turbo - 265k, highway star
Originally Posted by SUMOTOY View Post
I just mathed boost is *exactly* the same as gearing Ken!
LockedLX is offline   Reply With Quote
Old 09-10-09, 06:39 AM   #5 (permalink)
Supporting Vendor
sleeoffroad's Avatar
Is the Green / Yellow line on the bottom the boost?
Christo Slee
www.sleeoffroad.com
sleeoffroad is offline   Reply With Quote
Old 09-10-09, 07:13 AM   #6 (permalink)
beno's Avatar
TLCA# 14607
I regularly flog the crap out of my rig--pushing 4200-4600 rpm for sustained time periods--mainly going up passes and other "troublesome" terrain where the 1FZ just falters with stock gears and big tires.
I did the Eisenhower Pass in Colorado pushing 4500 rpms for almost 8 minutes keeping a sustained speed of almost 67 mph (normally aspirated).
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
beno is online now   Reply With Quote
Old 09-10-09, 07:40 AM   #7 (permalink)
IH8MUD Thread Killer
Koffer's Avatar
Wink
I did that same run at 3200rpms at a whopping 20 to 25 MPH , while helping kill all the bugs alone Rt 70 with the nice sooty diesel cloud pouring from my "90hp of Fury" 3B tuned for sea level
I did see 60+ mph , on the way down the other side
Todd
64' FJ40, 86' BJ70, 96' FZJ80 , 66'M416 and a 92' M101CND
Koffer is offline   Reply With Quote
Old 09-10-09, 08:07 AM   #8 (permalink)
Looking at those numbers at the wheels make you almost want to save for pistons and rods. 6psi IMO just isnt doing it. But 6psi is better than stock, i guess.
Thanks for the dyno run. Very helpful.
Old 09-10-09, 08:10 AM   #9 (permalink)
firetruck41's Avatar
TLCA# 14300
What are the different colored squiggly lines, and the associated numbers (difficult to see)?
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is offline   Reply With Quote
Old 09-10-09, 08:19 AM   #10 (permalink)
hzavarce's Avatar
Nice data !
Here are the results of my pre SC and post SC tests
http://forum.ih8mud.com/80-series-te...ests-data.html
97 White S/C S80 LC, 173K, Landtank MAF, OEM E-lockers, ScanGauge, OME 2.5 Heavy F&R, 315 Toyos MT, Hella TPMS, ARB Bar w/Slee AC drier plate, Warn 9.5XP, Slee Transfer Skid Plate, Slee Light Harness Upgrade+Aux lights, KC Daylighters, Interior LEDs, ARB Snorkel, all synth, Interior Winch control, CDL, OEM Hand Throttle, Inverter w/Matrix Switch, Gentex Mirror, SOR seat covers.
hzavarce is offline   Reply With Quote
Old 09-10-09, 10:53 AM   #11 (permalink)
Supporting Vendor
baktasht's Avatar
Looks like it's more than likely the AFR's.
baktasht is offline   Reply With Quote
Old 09-10-09, 11:01 AM   #12 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
Wut? Does that mean I should stop using the rev limiter as a audiable shift light?!? (Anybody who has wheeled with me know that I'm not kidding... Especially when I was on those Toyos!)
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 09-10-09, 12:02 PM   #13 (permalink)
Supporting Vendor
baktasht's Avatar
I stand corrected. The brown/green line at the bottom is boost. Black line in the middle is AFR's. Blue is torque. Red is HP.
Looks like the dyno they're using is a Land and Sea "Pro" 1000 AWD Chassis Dyno. I'm not familiar with that particular dyno and how much lower/higher it will read than other chassis dyno's. But since Steve will be doing the post dyno at the same location, it will give us good back-to-back results to compare percentage gains. Typically you will see anywhere from 5%-30% difference in actual HP/TQ figures from one brand of dyno to another
Old 09-10-09, 12:12 PM   #14 (permalink)
CycloSteve's Avatar
Hi Christo,
Yes boost is yellow/green.
Blue = Torque
Red = Horsepower
Black = Air Fuel Ratio
The line tapped for vac/boost was the one to the FPR.
Steve
Old 09-10-09, 12:21 PM   #15 (permalink)
CycloSteve's Avatar
Originally Posted by LockedLX View Post
It's not?
Factory without S/C = 212hp @ 4600 and 275 ft-lb @ 3200 at the crank.
TRD S/C @ 6psi = ?? Nothing on their site...perhaps CDan may have some answers.
Based on my experience with Eaton S/C's, likely there is a gain in the neighborhood of 75 to 90hp at the crank. As said, I am more interested on the gains from the exhaust upgrade at this point.
Old 09-10-09, 12:28 PM   #16 (permalink)
CycloSteve's Avatar
WOT is not my normal mode of driving the cruiser...just every once in a while when bursting onto the freeway, or perhaps dropping someone who expects the cruiser to be a dog. It has a rev limiter?
Used to my SC Audi banging against that wall in first and second gear. One reason why I have a Valentine 1.
Old 09-10-09, 12:41 PM   #17 (permalink)
CycloSteve's Avatar
For those wondering about the descending black squiggly line...watch the video closely for the soot. Essentially the ECM is enrichening the mixture. The soot is a great visual, and definitely lets you know when the truck is above 4000 rpm, and dumping fuel...better to be rich than lean.
Old 09-10-09, 12:48 PM   #18 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Here's mine 2F-ETI in red the blue is a Nissan 4.2 Turbo Diesel
At the rear wheels 413ftlbs of Torque and Power 244hp
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 09-10-09, 12:57 PM   #19 (permalink)
CycloSteve's Avatar
Originally Posted by hzavarce View Post
Nice data !
Great thread, and goes over the pre-vs-post comparisons quite well. The item to note from dyno-to-dyno with similar vehicles is how close the curves match. Between Hzavarce's chart, Christo's SC chart and mine, the curves are very similar, with most differences IMO being due to the different dyno's bias and local conditions.
Old 09-10-09, 01:01 PM   #20 (permalink)
CycloSteve's Avatar
^^ Matt, your rig is a beast! Give me more torque.
Old 09-10-09, 01:06 PM   #21 (permalink)
Lifer with a 2F-ETI
Yep not bad almost double yours so I suspect a well built 1FZ has a lot more to offer. I'm sure you have more than 4 main bearings holding the crank up.
Links
Mac's Space
On the rev limiter
Old 09-11-09, 04:43 PM   #22 (permalink)
Salue's Avatar
Eagerly following this thread
Steve,
Any ETA for the exhaust dyno run? You ever consider getting LandTank's MAF, if so, maybe a final 3rd dyno run after doing the MAF....Hint hint(only because I plan on getting his MAF as well)
Cheers,
Salue
'97 Land Cruiser SC
'99 4runner SC
Salue is offline   Reply With Quote
Old 09-11-09, 05:31 PM   #23 (permalink)
CycloSteve's Avatar
Well no FedEx box today at the office, so it will not be this weekend. Also will be wheeling up in Tahoe next mid-week and weekend, so not that one either...may try do do the install during after-hours the following week, but that usually does not sit well with the family.
Have read some about the LandTank MAF, but not sure if I am ready at this point, or if that would complicate things with the current rich fuel dumping I have at 4000+ rpm. Need to find a local tuner who can crack into the ECM code and perhaps tweak the fuel maps via the OBD II, or look at a piggyback to do fuel management via the PC.
Also for those looking for the Dyno Logs, here are two.
http://emspowered.com/productdevelop...e_exhaust1.jpg
http://emspowered.com/productdevelop...e_exhaust2.jpg
Old 10-01-09, 06:14 PM   #24 (permalink)
Malta (Chip Plant) NY
PDoyle's Avatar
Subscribed. I have Landtanks MAF and will be needing an exhaust system.
Pat Doyle
1994 White FZJ 80, leather,CDL switch. rear winch hitch attachment .-SOLD
1996 White FZJ 80, 7 seats,leathered up, CDL,Locked,LandTanks MAF, 2" OME lift/Shocks,Revo's.
PDoyle is offline   Reply With Quote
Old 10-06-09, 07:15 PM   #25 (permalink)
alia176's Avatar
Steve,
What's your torque and hp at around 2,800 rpm?
Thanks.
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 10-06-09, 09:00 PM   #26 (permalink)
ThinkTank Waterboy
landtank's Avatar
from the group who originally tested my MAF with a wideband O2 the AFRs where you are seeing a rich condition improved quite a bit. From memory they went from around 8.6 to 10.8.
It will be interesting to see someone crack the MAPs through the OBDII port.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 10-07-09, 04:30 PM   #27 (permalink)
What is the AFR that people need to run for this motor at WOT and at idle?
Old 10-07-09, 06:08 PM   #28 (permalink)
Turbo Diesel Lover
Tapage's Avatar
X 2 on this question and just wonder if are the same for NA and SC engines .. ? thought around 11:1 @ WOT and 14.7:1 ideal at idle .. ( or less means more lean ? )
HJ-60 2H-T Intercooled Tencha
Old 10-07-09, 06:43 PM   #29 (permalink)
ThinkTank Waterboy
landtank's Avatar
I believe idle is around 14.7. Now when talking about WOT I think it's different depending on whether or not the engine is normally aspirated or boosted.
I've only been concerned lately about the boosted number and even then I've yet to find a definitive answer.
Running rich helps keep the EGTs down and it protects the engine however a leaner mixture will produce more power.
The 8.6 value I posted is usually considered very rich and that was on both SC'd and Turbo'd engines.
I've read that a 10.8 AFR on a boosted engine is a good safe value but again there doesn't seem to be a consensus on that from what I can tell.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 10-07-09, 07:44 PM   #30 (permalink)
Thanks for the info. I forgot to state boosted. I dont mean to thread jack, just brainstorming.
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/311629-dyno-results.html
Posted By For Type Date
Interesting thread for 80 series owners... - Rising Sun Member Forums This thread Refback 11-03-09 12:05 PM
Supercharged Audi and VW Forums -> Aggregated G2 Dyno results This thread Refback 09-10-09 03:40 PM
