Old 08-31-09, 04:31 PM   #1 (permalink)
Aftermarket Front Radius Arms
Does anybody make after market low profile front arms?
Or, it is what it is with the arms.
I know Slee makes arms but they look like OEM in Style I know they are machined.
I little more ground clearance would be nice in the front.
Would a 3 link be worth investigating?
Cost to do 3 link?
What other options are there for the front end.
I have done tons of research here and on the net, what do you all think?
Roger
94 FZJ80 FOR 3 1/2" lift with BDS Shocks
kidglove13 is online now   Reply With Quote
Old 08-31-09, 06:30 PM   #2 (permalink)
DMOZ's Avatar
TLCA# 18906
I'm also interested to hear about options on radius arms.
I'd like to reduce the binding that occurs in the front axle, correct for caster, and still keep safe/practical as a daily driver.
I know ToolsRUs has a good solution for reducing the bind that occurs with OEM arms and that might be the route I eventually take.
Alternatively, Superior Engineering makes these arms Superior Engineering,which some say mimics a 3-link setup.
Thoughts?
__________________________________________________ ___________________________
97 LX, 54k, locked, CDL, 7-pin, OME 850/860, 285 Revos, ARB, dual batteries, de-racked...
DMOZ is offline   Reply With Quote
Old 08-31-09, 06:43 PM   #3 (permalink)
Here ya go (if the link works)
Shawn Jackson's Toyota FJ80 Land Cruiser Page - 3-Link Completed Finally!
mmml4 is offline   Reply With Quote
Old 08-31-09, 06:58 PM   #4 (permalink)
I have seen Action's 3 link, how much would it cost to do is the question?
Roger
Old 08-31-09, 07:09 PM   #5 (permalink)
I am currently putting an 80 series axle under my 4runner and IIRC I will have about $500.00 in it minus the axle, but I did have some materials that were left over from other projects. I think you could do it all from scratch for less than a grand.
Old 08-31-09, 07:14 PM   #6 (permalink)
retrofive's Avatar
TLCA# 19315
Another good read if you havent done so is Jodo's build up.
EDIT | found the thread: http://forum.ih8mud.com/80-series-te...r-project.html
'94 LC |OME 851+1"/860/N73/N74E/SD24|SLEE BLUES|SLEE SLIDERS|CDL/7PIN|285/75/16|YAK RACKS
JEFFERSON STATE CRUISERS
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
retrofive is offline   Reply With Quote
Old 08-31-09, 08:20 PM   #7 (permalink)
lt1fire's Avatar
As far as aftermarket radius arms there are only two that I know of for the US market. Slee and another one that 4wd toyota owner put on one of their rigs. I can't remember the name but it has something to do with a snake... do a search and it will come up.
3 link cost??? If you do it yourself not much.... have someone else do it, could cost a pretty penny
Jodo did JK long arms on his and it looks and seems to work great
There is also a way to flip the arms and have them attach to the top of the axle.... there is also a thread on this that a search will produce.
Good luck with your search.
Al
92 fj80: full 6 in slee lift, electric fans, 37" Goodyears, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch
Olde North State Cruisers
lt1fire is offline   Reply With Quote
Old 08-31-09, 08:25 PM   #8 (permalink)
Ebag333's Avatar
TLCA# 18864
If you do a 3 link, I want the bushing/mount that you will cut off one of your arms. I am in need of one....
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 08-31-09, 08:39 PM   #9 (permalink)
Something similar to the JK set up I think would be cool. But I like the idea of a 3 link as well.
I have access to someone who would be more than happy to help me weld it up.
A good materials list would be a good start.
Any ideas?
Roger
Old 08-31-09, 10:57 PM   #10 (permalink)
always broke
alkaline747trio's Avatar
actionjackson's thread is probably the best place for a materials list, that or his website if its still up.
What?
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 08-31-09, 11:19 PM   #11 (permalink)
Hey there a lots off think you can do with the front arm on your cruiser, One is if your looking for ground clearance is cut off the axle mounts and put them on top off the axle flipping the arm upside down, that is a really good one becuase it all so gives you more flex. I have also seen them made out off pipe, were some one make there own dont really know how strong it would bee to see tho. If your looking for more flex there is the 3 link that every one is talking about wich is good but if your car is not lifted space gets tight under there, but then there is an x link wich keeps you car stable like factory but also give grate flex off road. But looking at my cruiser the front arm dont hang down passed the diff any way so i cant really see the point but it is your car so up to you. good luck and hope all gose well.
P.S the 3 link that shawn jackson has done is not a ture 3 link really it is a 4 link becuase he still has the panhard arm on, i could bee wrong but the 3 links i have done we put a A fram on the top off the diff and do away with the panhard arm then you dont have any side way restricion from it, and i know wot your going to say the panhard arm stops the diff from going sideways but the solid A fram stops the diff from moving sideways becuase it is joid at two points on the chassy like a triangle if you get wot i am saying. any ways the 3 link i have done before work really good you can almost sit the diff up and down upder the car thay are really good.
tezzza is offline   Reply With Quote
Old 09-01-09, 11:02 AM   #12 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
Slee used to offer a tubular arm that was a lower-profile. They are not as robust as his current offering and would not be the best choice for a vehicle that is used agressively off-road. That is why his new design exists.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
cruiserdan is online now   Reply With Quote
Old 09-01-09, 11:18 AM   #13 (permalink)
1FZ-FE Club
gotmud's Avatar
TLCA# 18039
Dude, that was painful to read! -Heading to the medicine cabinet for some asprin...
1994 FZJ80
gotmud is offline   Reply With Quote
Old 09-01-09, 12:54 PM   #14 (permalink)
concretejungle's Avatar
TLCA# 14646
no kidding
I don't understand why there is any argument for there being more flex by putting the arms on top of the axle instead of it's stock location. You still have the same arms, the same amount of mounting points, same bushings....... doesn't make sense to me. But i agree with getting more ground clearance.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 09-01-09, 02:20 PM   #15 (permalink)
Ebag333's Avatar
TLCA# 18864
Originally Posted by concretejungle View Post
no kidding
x3....
The only thing I can think of is that the front tends to bind because of interference. If you move the mounts for the control arms, and flip them, you will change what they interfere with.
The other thought I just had is that you may not change the total range of flex....but may change the range that is available to you. It's like changing the location of the shock mounts and keeping the same shock. If your shock has a real short body, you might gain more length without losing any up travel because you had lots of room for up travel that you weren't using before. It's the same shock, same total travel, you're just changing it to use more.
'97 LX450
'96 LX450
Old 09-01-09, 03:39 PM   #16 (permalink)
Turbo Diesel Lover
Tapage's Avatar
There are another thread here in this section with a Aussie made control arms ( for Patrol and Cruiser ) that hold the axle in 3 points ..
It's like removing one of your cruiser control arm bolts ..
HJ-60 2H-T Intercooled Tencha
Old 09-01-09, 04:55 PM   #17 (permalink)
Yes I saw the aussie arms but they are like $1000
I have no idea what I want to do really, maybe just leave it the way it is.
Like they say if it ain't broke don't fix it.
I was thinking of trying to design my own which could always be a fun project.
Roger
Old 09-02-09, 08:33 AM   #18 (permalink)
Originally Posted by Ebag333 View Post
x3....
Yeah your right on the money there but also the arms hit the steering drag link when on the bottem binding it up even more, if you keep the factory arm after lifting the car there is bugger all clearance between the too thats if you put in caster correction plates, so when one gose down the other gose up and hits and drag link, when flipping the control arms there is more clearance between the too.
Old 09-02-09, 09:38 AM   #19 (permalink)
Walking Eagle's Avatar
no kidding
There is one thing that is different, and it's that one thing that makes all the difference. The arm is more level. More level arm has less front to back movement when it goes up and down. Less front to back movement - less binding in the bushings.
'97 LX450 - locked, Mickey Thompson MTZ 315's, J's, Rancho RS9000XL 14" shocks, RSC remote shock control 3" front drop brackets, 1" body lift, FOR custom front bumper, and a plethoria of rock lights
Owner fabed rotating slider steps, rear bumper / winch and hitch, front and rear extended shock mounts, front spring spacers 1.375", front swaybar drops, rear bumpstop drops, rear swaybar extensions - 'If I can fab it, I won't buy it!'
Walking Eagle is offline   Reply With Quote
