Old 08-31-09, 03:21 PM   #1 (permalink)
azzzuki's Avatar
pinging when bearly on the gas???
I removed my cat and now when im cruising and bearly on the gas i get a slight pinging.
I think its a o2 censer problem, is there a way to bypass it?
1985 4x4 pick up new build.
1991 fj80 4" lift , 35" bfg's KM/2 5.29's.locked. SOLD
1997 LX450 wife's ride ,all stock.
azzzuki is offline   Reply With Quote
Old 08-31-09, 03:25 PM   #2 (permalink)
Ebag333's Avatar
TLCA# 18864
Is this on the '97 or '91?
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 08-31-09, 04:16 PM   #3 (permalink)
azzzuki's Avatar
the 91........................
Old 08-31-09, 05:58 PM   #4 (permalink)
phxtlc's Avatar
How's your temp? I notice mine does it more when really really Phoenix hot out. I have discovered that the t-stat is bad and needs "a changing" which is probably doing it. Also noticed the same thing after making the mistake of Circle K regular unleaded.
One day I'll figure how the sun in arizona is 2-3 times hotter then other places. Same big ball of fire.
Copper State Cruisers #091
1992 FJ80 230k+ miles. OME 2.5" medium with 295/75/R16 Nitto TG's
“Neither current events nor history show that the majority rule, or ever did rule.”
phxtlc is offline   Reply With Quote
Old 08-31-09, 08:00 PM   #5 (permalink)
azzzuki's Avatar
temp is rock solid..............
Old 09-01-09, 06:47 AM   #6 (permalink)
Brian894X4's Avatar
Unfortunately, the factory guage will be rock solid throughout the entire "normal" range, including the hotter end of the scale, unless you've done the mod to make the guage read properly. Your rig could still be running really hot, but just not hot enough to move the needle past the dead zone into the red zone.
1995 FZJ80, modified for regional expeditions. Click here for more...
My main website:
In Search of History Expeditions
Foreign Toyota 4x4s
Military Toyota 4x4s
Brian894X4 is offline   Reply With Quote
Old 09-01-09, 07:25 AM   #7 (permalink)
IH8MUD addic
RedTacoma's Avatar
Is it possible that all the pinging issues are related to the fact that Gov changed fuel standards. I dont know if people realized but we went from Methanol in fuel to Ethanol in fuel. Later one sucks water into fuel like crazy
Some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned or negotiated with. Some men just want to watch the world burn.
RedTacoma is offline   Reply With Quote
Old 09-01-09, 07:40 AM   #8 (permalink)
jlg32281's Avatar
Location: recently moved to houston (Vidor, TX is home)
What do your spark plugs look like?
96 LX450 factory locked; Procomp 14" aux fan; aluminum roof rack; a few scratches. 98 Cobra DD.
Republican because everybody can't be on welfare. "The best social program is a job." - Ronald Reagan
jlg32281 is offline   Reply With Quote
Old 09-01-09, 01:57 PM   #9 (permalink)
Try running some BG44K through it to do a little injector cleaning. The other thing to easily look for would be a vacuum leak at a connection or a hose. A lean condition may occur and cause the pinging.
97 Cruiser, ARB locked, ARB front bumper, homemade rear bumper, homemade (George's) sliders, 295/75/16 BFG's A/T, 2.5 heavy OME lift, winch, Landtank MAF
elhombre is offline   Reply With Quote
Old 09-01-09, 02:50 PM   #10 (permalink)
Moby's Avatar
The light throttle ping is very common in Toyota's of this vintage. My 3FE did this as well. I didn't have success getting rid of it until I rebuilt it, but I'm sure that some combination of top end cleaning (carbon build up on pistons, rebuilding the injectors, clean plugs, vacuum leaks...) probably could have solved it in a less drastic manner
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 09-01-09, 03:36 PM   #11 (permalink)
azzzuki's Avatar
Thats kinda what i was thinking ........just a real old engine......
Thanks for all the input
Rob
Old 09-01-09, 05:35 PM   #12 (permalink)
Cruiser Jimmy's Avatar
Location: Indy,IN. But currently on the road: SoCal,NV,AZ,NM.
TLCA# 12112
Play with timing some.
TLCA Chapter Club
'83&'87 FJ60, '92 FJ80
Cruiser Jimmy is offline   Reply With Quote
Old 09-01-09, 05:49 PM   #13 (permalink)
TLCA# 2432
I agree with Moby,also change the valve cover gasket. Mikr
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
Michael Hanson is offline   Reply With Quote
Old 09-01-09, 06:46 PM   #14 (permalink)
jonheld's Avatar
TLCA# 5980
You've gotten some good suggestions so far.
Make sure your cooling system is functioning properly. I had the same symptoms when my fan clutch was in the toilet.
I agree with running several cans of FI cleaner through the system. I like the Redline stuff, but it takes several tanks to notice a difference.
Jon Held
1991 FJ80 "Lumbering White Rhino"
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
http://www.sdsysdesign.com/tlc/
Buy your FJ80 FSM here:
http://www.sdsysdesign.com/tlc/fsm.html
jonheld is offline   Reply With Quote
Old 09-01-09, 07:05 PM   #15 (permalink)
livin a poor college life
Lka1988's Avatar
Garage
That only applies to 93-97. I was going up Parley's Canyon (pretty long mountain pass) with a bad fan clutch a few weeks ago, and I was able to monitor the engine temperature, through the gauge, so I didn't overheat.
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
Lka1988 is offline   Reply With Quote
Old 09-01-09, 10:38 PM   #16 (permalink)
91Cruizer's Avatar
TLCA# 16728
I have the same thing happen. Only when running the a/c on the hottest days, 105-110 degrees. I figure it is probably heat soak of some kind as the temp gauge is normal. I have a whole new top end and radiator. Timing is stock.
91 fj80, ome low lift, Bilsteins, 198k
72 fj40, 350 chev, 3 speed SOLD!
65 VW Beetle
01 F150 Prerunner
91Cruizer is offline   Reply With Quote
