Old 08-29-09, 04:24 PM   #1 (permalink)
You want to do what...?
e9999's Avatar
Can you tell O2 sensors are going slowly bad from smog test gas results?
I imagine there are tests based on electrical resistance and all to tell if the 02 sensors are still good or not, but I was wondering whether one can also tell if the 02 sensors are going bad slowly based on the gas measurements results on a typical smog test, as in there are more HC coming out of the pipe etc. I'm not talking about bad as in throwing codes here, just slow degradation. But likely too many other factors I suppose.
(And while we're at that, is the notion that used to float around that putting new sensors in place of old would sometimes result in dramatic mpg increases still accepted by folks in the know?)
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 08-30-09, 01:24 PM   #2 (permalink)
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Well Eric, I tested the resistance on both my sensors after throwing a rich fuel code 26. Steped thru all the other diagnostics myself and never threw a code 22 or 28 for O2 sensor failure, but could not get the 26 to go away, even with a thorough throttle body cleaning and tune up. Finally had the inboard sensor pulled and they tested it under load and it failed...all w/o throwing a failure code.
Must tell you that my truck has a history of eating this one sensor like f'ing candy. New sensor and she runs just great.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
Brentbba is offline   Reply With Quote
Old 08-30-09, 04:35 PM   #3 (permalink)
e9999's Avatar
did you see any smog test evidence of it going bad before you starting getting the codes?
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 08-30-09, 06:10 PM   #4 (permalink)
Brian894X4's Avatar
I'm kind of curious about any improvements after replacing sensors that aren't obviously bad. Mine have 110,000 miles on them, but the truck seems to run great. I've heard that some manufactures, including Toyota in certain models, recommend automatic replacement of sensors around 90,000 miles.
1995 FZJ80, modified for regional expeditions. Click here for more...
My main website:
In Search of History Expeditions
Foreign Toyota 4x4s
Military Toyota 4x4s
Brian894X4 is online now   Reply With Quote
Old 08-30-09, 07:15 PM   #5 (permalink)
scottm's Avatar
I posted graphs of my O2 sensor outputs in these threads, the last one is with new toyota sensors. The new ones are clearly more sensitive. The old ones were throwing codes for the heater in the sensor failing.
http://forum.ih8mud.com/80-series-te...look-like.html
http://forum.ih8mud.com/80-series-te...ncrease-3.html
http://forum.ih8mud.com/80-series-te...rs-better.html
'03 UZJ100: wife's ride; '97 FZJ80: Traded in; '97 FZJ80 40th: Totalled; '03 4R; '06 Specialized Epic Comp Disk: Daily Driver; B-767: company vehicle
"if thou would have peace, be thou then prepared for war".
"Except for ending Slavery, Fascism, Nazism and Communism, WAR has never solved anything." - Ronald Reagan
scottm is offline   Reply With Quote
Old 08-30-09, 10:59 PM   #6 (permalink)
Rookie
Can't tell from the sniffer IMO
I replaced my O2 sensors before last test, and it indicates slightly MORE dirty than before. This was replacing OEM with OEM. In my case might be more of an indication of a deteriorating CAT? Definitely NO mpg increase. What gave me 3-4 MPG better was fixing plugged EGR port and VSV.
Here are my #'s for 4 years of smog testing:
Code:
1994 FZJ80 - 1FZFE
Smog Data
Test	2500 RPM Test		Dilution	Idle Test		Dilution
Year	O2	CO %	HC PPM	CO+CO2%	RPM	O2	CO %	HC PPM	CO+CO2%	RPM
2005	0.2	0.01	21	15.11	2701	0.1	0.03	36	15.13	642
2007	0.9	0.03	14	14.63	2410	1.0	0.08	41	14.40	627
2008	0.0	0.16	38	14.96	2471	0.0	0.11	78	14.81	628
2009	0.4	0.41	73	15.31	2541	0.2	0.13	107	15.14	644
Standard	---	<= 1.20	220	6.00	2500	---	1.20	220	6.00	775
Oxygen Sensors replaced with OEM parts 2 months before 2009 test.
dgspencer is offline   Reply With Quote
Old 08-31-09, 01:10 AM   #7 (permalink)
e9999's Avatar
Code:
1994 FZJ80 - 1FZFE
Smog Data
interesting, thanks.
Indeed, the new sensors did not result in better numbers. Problem is that there are too many other effects going on, so probably the emissions indeed won't be too useful for directly figuring out the state of the sensors.
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 08-31-09, 01:14 AM   #8 (permalink)
Ebag333's Avatar
TLCA# 18864
From what I've read from folks posting, it looks like maybe 1-2 MPG.....at the most.....for a few days/weeks/months.....
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 08-31-09, 08:27 AM   #9 (permalink)
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
No - It's been an intermitent code, but always a 28 (O2 sensor), not a 26 (rich fuel).
Brent
Old 08-31-09, 09:21 AM   #10 (permalink)
chiz45's Avatar
I had mine replaced at 150k, and the 1-2mpg increase is what i'm seeing. I'm at 157k now, mixed city/hwy driving. Truck has stock gearing and 33" muds.
1996 Cruiser, 151k, 33s and lots of extra metal.
chiz45 is offline   Reply With Quote
Old 08-31-09, 08:14 PM   #11 (permalink)
matt60/80's Avatar
I'm gonna say no. I just got new cats courtesy of the #%@^ers who stole mine and took my rig thru emission today. I did not replace the O2 sensors. Readings were 0 PPM HC and 0% CO. Yes you read that right.
matt60/80 is offline   Reply With Quote
