08-28-09, 08:14 PM
91 in AK, Won't go w/o Diff Lock engaged
Hi.
Just moved to Anchorage, leaving our 66 FJ45LV garaged in Maryland (sob)
We bought a 91 80 series last night, very cheaply, and now we need to make it right.
It will not go, there is just a spinning sound, unless the diff lock is engaged. I have a guess, but I could use an informed opinion.
3 Questions:
1. What would cause this?
2. Can a regular transmisson shop handle this?
3. Does anyone have contact info for the "Just Cruisers" shop in Wasilla? Or is it Cruisers only?
Thanks in advance.
Other than this issue and some neglected maintenance we need to catch up on, it looks like a great truck!
-Brian
Reason: wrong shop name?
08-28-09, 08:27 PM
livin a poor college life
Common item to check is the drive flanges on each end of the front axle. It's possible one is stripped out.
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
'04 Crate 4-string bass, Ernie Ball Slinks, stock
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
08-28-09, 08:43 PM
Mine did that when I broke my front axle. The CDL keeps all the power from going to the spinning broken stuff, or maybe just something isn't hooked up. Beware.
 IH8RUST
'92 FJ80 - 3FE - with stuff on it
ROTW
08-28-09, 08:46 PM
could be a missing driveshaft etc.....
I/e front works, not rear, or rear works, not front.
figure out which
08-28-09, 09:25 PM
Location: recently moved to houston (Vidor, TX is home)
you need to figure out where the "spinning sound" is coming from.
96 LX450 factory locked; Procomp 14" aux fan; aluminum roof rack; a few scratches. 98 Cobra DD.
Republican because everybody can't be on welfare. "The best social program is a job." - Ronald Reagan
08-28-09, 10:03 PM
Broken drive flange($45), or a broken axle/birf. Easy fix for a wrencher, not so bad if you've done it before. Doubt it has anything to do with the tranny
88 4runner, Downey 3" lift, headers, intake, exhaust, 4.88, custum body
92 fj80, OME 851/863, Diff breather mod, basically stock DD, The Meat Wagon
"Bring out your dead"
08-28-09, 10:07 PM
Too bad you weren't a little farther north,a nd I'd help ya out. SOunds like a stripped drive flange, missing rear driveline, or broken rear axle.
TK
1966 FJ-45lv resto. in progress
1966 FJ-45lv donor
1971 FJ-40 fun truck, resto. in progress
1974 FJ-40 donor
1985 FJ-60 donor
1985 FJ-60 creampuff
1993 FZJ-80 built to haul groceries
08-28-09, 10:32 PM
... Alive
Brian, it is Cruisers Only. 373.3789
Probably a simple fix.
Call me. Pretty much 24/7 if it is about Cruisers
I'll have some more questions for you (including who you bought it from). Probably narrow it down a lot even over the phone.
Mark...
http://www.AlaskaCruiserTrek.com
MIBS Rules!
The first primordial slug that sprouted gripping pods to pull itself out of the ocean onto the slick rocks of the world beyond was the original proponent and carrier of MIBS. It has been onward and upward since. Embrace MIBS! Leave the other slugs behind!
08-28-09, 10:52 PM
I just spoke with Mark - I am running the truck up to his shop tomorrow - will let you know what we find.
08-29-09, 05:00 AM
#10 (permalink)
post up some pics of the truck and do tell how much you paid for it.....
also - very curious what you find out is wrong and pics of the fixing
'96 black/tan, no lock, no lift, 285 ta ko's, 230,000, synthetic xfer case/diff's, dino engine & trans, removed cleaned & reinstalled carpets, starter rebuild, gonna be doing axles & fan clutch soon
now with 304,000, still haven't done axles or fan clutch...
08-29-09, 07:23 AM
#11 (permalink)
Like others have said, missing driveshaft, stripped flange, or broken axle.... has to be one of these
Al
92 fj80: full 6 in slee lift, electric fans, 37" Goodyears, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch
Olde North State Cruisers
08-29-09, 08:42 PM
#12 (permalink)
All signs point to stripped flange. Mark was very helpful, and I am ordering the part Monday - looks easy and cheap to fix. He has some awesome cruisers up there!
I bought the truck for just under $2K - it has misc. dents along the drivers side, a cracked winshield (AK standard) and a LOUD exhaust leak. Interior is in good shape, and the paint is all one color. But it's perfect for my wife and kids this winter.
Thanks for all the help!
08-30-09, 01:13 AM
#13 (permalink)
... Alive
Brian, JP was at the shop tonight and he will be expecting your call on Monday.
Mark...
MIBS Rules!
08-31-09, 10:09 PM
#14 (permalink)
Mark - Thanks. I didn't find time to call today. But I did get an exhaust quote from Midas - $4,699. 2 cats etc. Criminy. Where would you recommend I look for a custom exhaust? I'm sure someone could build one way cheaper.
I'll be doing the front axle, (brakes, rotors & bearings) with the flange when it comes in. I'll call JP in the morning and get things rolling.
I am loving the truck - just don't want to break the bank on the way to making it right.
- Brian
08-31-09, 10:17 PM
#15 (permalink)
... Alive
What makes you assume that you need all of that. It might just need the hole patched or a new section of pipe to replace the bad section. Midas will ALWAYS quote you for a full system and quote absurd prices. ALWAYS.
If you are tearing into the front end. now is a good time to put speedy sleeves on the axles and new axle seals too. Swap your Birfs side to side to get more life out if them while you have it apart. That rig can probably use knuckle bearings as well.
BTW, I forgot when we were talking the other day. I have some brand new winter tires, ready for studding and on rims. If you are looking. seems like you said you were. Give me a call if you want.
Mark...
MIBS Rules!
08-31-09, 11:25 PM
#16 (permalink)
Mark - You are right. Midas = crazy. My tools are still in storage, so I haven't been able to even pull the heat shield off - but from peeking around, I think a little patch around the O2 sensor will do.
Speedy sleeves, knuckles, rotors, brakes etc... would you be interested? I would be in over my head, and you know the truck. I'll call you tomorrow to see what you think.
Brian
