08-28-09, 03:35 PM
Cat-Back exhaust over frame complete
Took the 80 over to a guy I know that has a local muffler shop. He rerouted the exhaust over the frame rail and installed a new Magnaflow muffler.
Modified the head pipe by removing a couple of inches.
Cat #1 remains outside frame.
Pipe over frame
Cat #2 moved to inside frame. This was done to shorten the length of the cats on the outside so he would have enough room to send the pipe over the frame where there was the most room. No, the cat is not touching the x-fer case...over an inch away.
Exhaust is up high to avoid rocks.
Factory Locked 97 LX450 - F.O.R. 3.5" kit, 315 BFG KM2, DO sliders, DO Rear bumper, then...
06 Tundra Dcab 4X4 - 3" level kit and 33's (DD)
03 Tacoma Dcab 4X4 - Donahoes, Camburg UCA, Deaver, Armor by Demello, 33's - As seen in 08 brochure (SOLD)
http://community.webshots.com/user/vistataco
08-28-09, 03:56 PM
So how long is that shaft seal gonna last with that heat right next to it?
Other than that it looks pretty good. What did it all set you back?
ふざけんなよ!
08-28-09, 04:14 PM
I-HEART-DIRT
I will have to keep this shop in mind when I am ready to do exhaust. Thanks!
08-28-09, 05:59 PM
IH8MUD Thread Killer
That 2nd cat will not be doing too much good as its pretty far away from the motor (wont get hot enough other then cook you transfer seals )
08-28-09, 07:05 PM
Nice job, but I agree that second cat will probably not heat up enough to be of use and if it does it's real close to that TCase and I would be concerned about cooking the fluid + the seal. Other than the cat location the route is real nice. You may want to fab some king of heat shield for both transfer and to protect the feet of your back seat passengers.
Copper State Cruisers #091
1992 FJ80 230k+ miles. OME 2.5" medium with 295/75/R16 Nitto TG's
“Neither current events nor history show that the majority rule, or ever did rule.”
08-29-09, 11:01 AM
Not a bad idea on the shield for the x-fer. The guy that installed the setup suggested an additional heat shield where the exhaust goes over the frame. He also suggested pulling up the carpet and putting down Dynomat or something similar to prevent the carpet from melting.
08-29-09, 11:03 AM
Total for the job was $400.
08-31-09, 04:59 AM
Supporting Vendor
Looks good. Some of the clearances are awfully close, do you get any vibration from metal/metal contact anywhere?
08-31-09, 07:34 AM
ONSC triad VP
Im thinking youll want to do this before too long. I have a very similar routing if not identical but put a single high flow cat in place of your #1 (i got the single cat 95) and also used 3''. http://forum.ih8mud.com/80-series-te...k-exhaust.html
The cab is toasty and dont think of storing chocolate of any sort in the console. I think im going to pull the pass. seat and go firewall to wheel well down the pass side over the exhaust w/ heat sheild and then add noise reduction in the whole rear of the cab. Oh and the carpet will melt; and i thought thought that was just the new cat smell
and on the note of heat, those mounts arent gonna last. Get some solid rod to rubber insulator mounts and youll be good. The heat eats those up, my roomate has gone through them on a stock exhaust and the 3 on mine lasted alomst one year before failing. You dont want that thing rattling around and stressing the Y pipe. Nice touch there btw.
Looks good!
Jason---- I live vicariously..........................through myself
__________________________________________________ __________
95 80 -- Slee4''/omeJ, 37's, factory locked, full armor and a s/c too
72 55-- w/ 76 4sdp 78 f. disc 79 2F -- SOA + 3'' w/ 35's, IPOR protection
92 P/U -- no "D" light, no umph, no fun except at the pump
08-31-09, 10:16 PM
#10 (permalink)
Some of the clearances look closer in the pics than they really are and no rattles yet but i have not driven it that much since it was finished.
Looks good!
Well 2 reasons for me not going with 1 cat...1: The 2 I have work fine so i saved some expense. 2. I am in Cali so it needs to have 2 cats since that is what it came with. Most smog shops would probably not even notice though so long as the 1 cat was doing the job.
I am planning on doing the heat shielding before I drive more than a few miles.
