Home Forum Gallery Wiki CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 08-12-09, 09:49 AM   #1
2everest's Avatar
Marlin Crawler 80 Series Marlinks
Hey everybody,
I have been searching for steering upgrades for my 1994 for a while. I found many options for upgraded relay and tie rod bars (Slee, Budbuilt, Man-a-fre, etc.) but not the ends. Usually offered stock ends and I wanted something other than stock sized ends. Marlin Crawler offers the Marlink, which immediately caught my attention. I purchased two Marlinks and they look and feel amazing!
The rods seem almost 1/4" thick DOM (Do not know the exact size) and the rod ends are 23mm threads ...
Thank you Marlin Crawler, great product !!!!
-Josh
04' UZJ120L, 32" KM2's, IPF lighting
04' Ford F-350 6.0 Turbo Diesel King Ranch Fx4, Banks Powered, 12.5" Icon, 47x15.50x20 Michelin XML's, 5.38, ARB F&R, Spidertrax Chromoly links/rods, Dynatrac 70 shafts, Hubs, and Knuckles.
2everest is offline   Reply With Quote
Old 08-12-09, 10:02 AM   #2
ONSC VP Yeti
lt1fire's Avatar
I called and asked them about these earlier in the year when I was getting my rods replaced. I was told that they don't fit and won't work for an 80 series land cruiser.
Al
92 fj80: full 6 in slee lift, slee spacers, electric fans, 37x12.50x16.5 Goodyear MT, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch,
Comming very soon, Safari snorkle, FF rear, ARB lockers F/R, 4.88 gears
Olde North State Cruisers
lt1fire is offline   Reply With Quote
Sponsor 08-12-09, 10:03 AM
Sponsored Link
advertisement
Old 08-12-09, 10:03 AM   #3
fzjconvert's Avatar
I am in need of doing this too! Price?
fzjconvert is offline   Reply With Quote
Old 08-12-09, 10:04 AM   #4
phrogg4evr's Avatar
Which lengths did you get to work with both relay and tie rod?
Breaking out the tape measure, looks like 60 series Marlink (44") works good length-wise for the tie-rod (I think the OEM one is around 44.5-45") but the 40 series Marlink might be a shade too long to use for the relay rod. Let us know which ones you used and how they worked once you had your alignment done
Alex
トヨタ ランドクルーザー
'76 Yella FJ40 短いバス
'94 FJZ80 Cummins 4BTA Conversion
'07 Tacoma, stock but locked. New ARB thanks to the baby deer
Ronaldus Magnus
It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first.
Originally Posted by Shahram View Post
The number one selling beverage in America is Kool-Aid, and we're all drinkin' one flavor or another.
phrogg4evr is offline   Reply With Quote
Old 08-12-09, 10:27 AM   #5
I did the same thing but went with budbuilt great customer service and supporting the east coast business.
Roger
94 FZJ80 FOR 3 1/2" lift with BDS Shocks, 4x Inovation Sliders, Locked Rear, semi custom front bumper, custom belly skid plate and always working on it.
kidglove13 is offline   Reply With Quote
Old 08-12-09, 04:07 PM   #6
2everest's Avatar
I gave the tech I spoke with, Brendan, the measurements from center of hole to center of hole, for both the links. On mine it was 42.5" on the relay and 49" on the tie rod. They cut the length down from there according to the rod ends.
They are amazingly responsive, I measured pretty accurately, before I took the old sets off, and set the new ones at that length. So it tracks straight.
Prices are: $127 for each Marlink which includes: One Rod, Two ends, Jam nuts, Grease fittings, and Cotter Pins. I also bought a stabilizer mount kit from them, which is beefy, which was $15. Total including shipping across the country was $292.
Pretty stoked!!!
-Josh
Old 08-12-09, 04:45 PM   #7
Club 4X4 Panamá
Tapage's Avatar
Garage
looks really good .. 292 with drag link and tie rod .? ( plus all TRE's )
HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul !
Old 08-12-09, 07:50 PM   #8
2everest's Avatar
Yeah ... Not bad eh??
They are very good over there, excellent customer service, and tech skills. They mostly deal with mini trucks and stuff, but some of the guys know and have 80's ...
-Josh
Old 08-12-09, 08:27 PM   #9
I had the Marlin guys make me a tie rod and drag link over a year ago and they are top quality (1.25" x .25" wall). I only have one grip, there are no flats on the tube to aid in tightening the jam nuts. If I had to do it again I would either machine a flat on the tube next to each end or buy tube and burn on tube adapters. Much like a current thread on the Hardcore section.
Fj-80 tie rod tube adapters
2everest, I see you did a little grinding on your control arms so the tie rod didn't rub. It should give you room to mount up a clamp and install hydro assist.
1994 80 - Some stuff
Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
IBCRUSN is offline   Reply With Quote
Old 08-13-09, 12:34 PM   #10
2everest's Avatar
Yeah, a lot of grinding ... It was not because of the tie rod though ... I am running the OME Caster Correction bushings along with Landtanks caster plates ... I am actually over caster corrected, but that is my plan, because I'm adding another inch to inch and a half ... It all moved the arms up more, which was rubbing even my stocks steering arms ... Little more clearance too ...
Hydro assist??? Haven't read much on that, I'll check out that link ...
The arms are beast ... Heavy!
-Josh
Old 08-13-09, 03:21 PM   #11
Atoyot1031's Avatar
Those are schweet! I was gonna order a new tie rod from Slee, but having seen this, I think I'll give Marlin a call. My tie rod is not so purdy. I bent it back to something resembling straight then welded a huge piece of angle iron to it. This should work much better.
"I don't worry so much about animals...or Subarus anymore..."-My in reference to having an ARB front bumper.
My ROTW
My off-road pop-up camper build thread
Atoyot1031 is offline   Reply With Quote
Old 08-13-09, 04:54 PM   #12
Parts Geek, M1 Mechanic
cruiserdan's Avatar
Remember gents, the tie rod is a fuse of sorts. Make it too strong and you break a steering arm or knuckle or a 2,500 dollar steering box.
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 425 horse HEMI, 6 speed manual trans, cop-attracting-red.
Old 08-13-09, 05:51 PM   #13
Riad's Avatar
Pretty stoked!!!
-Josh
I need a pair of rods too. I have bee debating which ones do I want. My Slee tie rod has been slightly bent from wheeling trip few years back. My front relay rod is OEM and it needs replacement desperately. So if I am not mistaken, you have ditched the stock steering damper and mounts? What is this stabilizer kit mount kit you speak off? Any pix?
My FZJ80
You don't get what you expect, you get what you inspect.
Riad is offline   Reply With Quote
Old 08-13-09, 06:34 PM   #14
2everest's Avatar
The only pic I have available, but you can see the mount. It's well designed and serves its purpose. Also, I was able to mount the OME stabilizer parallel with the truck again. The bracket with the two U-bolts was $15 extra ... I recommend this setup and marlin Crawler to anyone.
-Josh
Old 08-14-09, 10:22 AM   #15
Atoyot1031's Avatar
Words of wisdom as always. Howevr, Mr. T. engineered said components for 31" tires...
My ROTW
Old 08-14-09, 02:39 PM   #16
2everest's Avatar
I agree ...
Old 08-14-09, 03:02 PM   #17
Ebag333's Avatar
Garage
I agree ...
That same logic applies to the $2500 steering box.
'97 LX450
Mods and Pics
'96 LX450
Mods and Pics
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 08-14-09, 03:18 PM   #18
Atoyot1031's Avatar
Exactly, that's why hydro-assist is in my future. Now to break the news to the ...
Also, it's tougher to break a steering box when you follow a few simple rules (i.e. Don't try to turn said 37s when not moving in a rock garden)
My ROTW
Old 08-14-09, 03:21 PM   #19
Supporting Vendor
Isotel's Avatar
Fuses are
Toyota has a great reputation of overbuilding everything, thats why the only rig running stock style components in the XRRA is Ben Swain's Home Grown Racing Rig.. 42's and a V8 on 80 series stuff (Built to the Max) ..
you don't see a lot of any other manufactures that can run 37's on stock stuff!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers -=- CrAwLoRadO.com
Old 08-14-09, 03:46 PM
Sponsored Link
advertisement
Old 08-14-09, 03:46 PM   #20
2everest's Avatar
Really, in my short experience, 35's are tough on most trucks, let alone 37's .. These 80's are amazing !!!
-Josh
