Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Thread Tools Display Modes
Old 07-29-09, 01:17 PM   #1
BadgerManBEN
BadgerManBEN's Avatar
High pressure on the low pressure side of the AC System.
My AC stopped working so I checked the compressor and it seemed to be working just fine. So I went and picked up some R134a with the gage on it thinking it must be time for a recharge. I plugged it in to the low pressure side, even made sure it was the low pressure side by tracing it out, and the gage read 130psi. If I am right that is 100 psi too high. Anybody heard of this and have an idea what might cause it?
94 FZJ80, Factory lockers, 285 toyo all terrains, future family friendly offroad expedition vehicle.
BadgerManBEN is offline   Reply With Quote
Old 07-29-09, 01:25 PM   #2
BadgerManBEN
Other details that may help. I saw the high pressure and did not try to discharge any freon into the system. It was high pressure with the engine running and while it was off. I let some of the pressure out down to about 100 psi and it went back up.
Sponsor 07-29-09, 01:59 PM
Sponsored Link
advertisement
Old 07-29-09, 01:59 PM   #3
Tools R Us
10k Club
Tools R Us's Avatar
Was the compressor running? If the compressor isn't running the low and high side pressures will be the same, base system charge, about what your seeing.
Copper State Cruisers #007
Old 07-29-09, 02:03 PM   #4
1972FJ55
Supporting Vendor
1972FJ55's Avatar
Garage
Is the compressor engaged when you're checking it? Look at the front hub of the compressor, not the pulley, and see if it's spinning. If not, then the pressures will be even on both sides of the system. By the way, those hose gauges are notoriously inaccurate.
'72 FJ55(sold)
'85 FJ60(sold)
'82 FJ60(sold)
'97 FZJ80(this is the keeper)
'62 VW Ragtop(mega project)
1972FJ55 is offline   Reply With Quote
Old 07-29-09, 02:34 PM   #5
dixie_cragger
dixie_cragger's Avatar
I had my AC converted to R134a in my FJ62. It wasnt until my AC went out a second time did we realize the fittings were flopped from the conversion (hi pressure fitting was actually the low pressure side and vice versa). I do believe the AC shop was able to insert freon into the hi pressure fitting side....
1990 FJ62
- ARB/JKCustoms Rear, OME Heavy,33" Goodyear MTRs
dixie_cragger is offline   Reply With Quote
Old 07-29-09, 03:12 PM   #6
BadgerManBEN
Yes, the compressor was engaged it wasn't just the pulley spinning. No modifications have been made.
Old 07-29-09, 03:43 PM   #7
FJ60Cam
Lifer
FJ60Cam's Avatar
Yep, you can fill on the high side. With the engine off, turn can upside down and fill as liquid.
Cameron Mosley
'85 FJ60 - Daily Driver
FJ60Cam is offline   Reply With Quote
Old 07-29-09, 05:24 PM   #8
TX Cruiser
Knowing how these compressors don't internally disintegrate, I'd recon the expansion valve is stuck open. 130psi is a bit much when the pressures are equalized with the system off, so this tells me the compressor is pumping. That is unless your ambient temperature is really high. Put a real set of gauges on it and holler back. The valves in the compressor could be shot, but not likely.
2- 91 FJ80's, one smashed
In the family
74 FJ40 w/PTO winch, tow bar
83 FJ60
84 FJ60
90 FJ62 w/damage inducer
94 FZJ80 w/damage multiplier
95 FZJ80 " "
03 UZJ100
TX Cruiser is offline   Reply With Quote
Old 07-29-09, 10:31 PM   #9
roneyj
If this was the gauge that comes with a can for around $15-$25, its junk. I return about as many of these as I sell. I would not add or release anything untill you check it with a real set of gauges. Just me experience.
1995 FZJ80 White, 170K, 2.5 Skyjacker Springs
roneyj is offline   Reply With Quote
Old 07-30-09, 12:17 PM   #10
BadgerManBEN
I had a friend mention, who is a pretty decent mechanic, say that the system may just need to be balanced. Anyone ever hear of this?
Old 07-30-09, 04:53 PM   #11
TX Cruiser
Balanced? Never heard of that. Might he have said that the pressures are equalized?
In the family
83 FJ60
84 FJ60
95 FZJ80 " "
03 UZJ100
Old 08-25-09, 05:02 PM   #12
popawoody
"Balancing" in A/C biz
The term "balancing" is a term sometimes used in the refrigeration business that referrs to adjusting the level of charge. It's a pretty arcane term, but it's more accurate than "charging" since sometimes the system is overcharged. A refrigeration system is properly charged by adjusting the referigerant level so that the evap is producing the correct amount of superheat for the particular referigerant and expansion valve. Superheat is the measure of how much heat is being transferred. The technical details aren't important here.
Your friend had no great insight I'm afraid. The best advise I can give is the same as that given by others here. Put a REAL gauge manifold on the system so you can see both suction and discharge pressures. If the suction side is, indeed, standing at 130psig with the compressor turning -- and the high side isn't off the charts -- then either the compressor valves are leaking badly (which isn't too likely) or there's a pressure relief valve in the compressor that's open.
Buy, beg, borrow or steal a set of gauges before you do anything else.
popawoody is offline   Reply With Quote
Old 07-04-11, 04:27 PM   #13
TeeDiggs
TeeDiggs's Avatar
Does anyone know if places rent out real gauges? I completely just bought a $19.99 hose gauge from AutoZone. Havent used it yet, but they did have a Manifold Gauge for I believe $39.99 in there... would that be worth anything?
1996 Black FZJ80 (The Black Pearl) - 144k 166,xxx, 265/75/16 GY Wrangler Duratracs, 3X Factory Locked
TeeDiggs is offline   Reply With Quote
Old 07-04-11, 10:44 PM
Sponsored Link
advertisement
Old 07-04-11, 10:44 PM   #14
e9999
You want to do what...?
e9999's Avatar
if you buy an A/C manifold and gauge set, be sure it has the QD connectors for 134. Those are not that easy to get separately and are expensive.
HF has a set for car systems that they have regularly on sale for about $40 with the QDs. Don't know how accurate.
Not all inexpensive gauges are bad, though. I have a pro Yellow Jacket manifold type set and it was pretty close to what my cheapo Kragen filler / gauge set was indicating.
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).
: '03: 125K
DDs: ex-Accord (seller's remorse), Prius
: souped-up DR650
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
