07-17-09, 10:14 AM
Rookie
Quick Exhaust & Gauge Questions
I have a leak in the exhaust at the joint between the 2 cats. Is there some sort of goop that can patch this up? Tape/wrap would not work because it's right at the joint.
Otherwise, maybe a muffler guy can cut out the joint and replace the pipe section - would this be possible at a reasonable expense?
My other question is about the oil pressure gauge. Every once in a while it seems to cut out. It just drops to the bottom line, even while driving at a decent RPM. Do you think it's just a connection issue, or could this be a symptome of something else?
Thanks for any and all advice.
1995 FZJ80 ... 150,000+ ... New to me
07-17-09, 11:01 AM
I used exhaust sealer on that joint for the last two years and it passed inspection no problem. This year almost all of the rest of the exhaust has caught up with it and is in really bad shape. Time for replacement - but I won't complain that the original made 182K.
If you are not hearing your valves - then it is likely just the sender/wiring/gauge that is the issue when you show no oil pressure.
97 40th lockersx3, Yellow top & Diehard PM-2. Pin7 mod, Georges LEDs & others, Revos, heated mirrors, massive inverter project underway. P0401 fixed. Currently at 180K+. more to come...
87 Supra Turbo - stock, 5-speed, targa roof, midnight blue. Currently at 125K+.
07-17-09, 12:25 PM
The "Chief"
I think yer better off cutting out the two cats and installing one high flow cat. This won't cause problems with your O2 sensors, and your Cruiser will like it.
07-17-09, 01:36 PM
I had something like this, I pulled into an exhaust shop and they welded up the leak in about 5 min, total cost was about $15. That was about 4 years ago.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
07-20-09, 05:09 PM
Rookie
Thanks for your thoughts on this. I ended up bringing it to an exhaust shop to go with the weld method and they ended putting in a new piece of pipe between the cats where the flange was. More expensive than the quick 5 minute job but not very expensive. I can live with that.
Of course, about 4 miles from the shop, the Check Engine light came on. This really didn't surprise me nor does it worry me that much (the engine appears to be running very smoothly). Does it make sense now that more exhaust is flowing through to the 2nd cat and the 2nd O2 sensor that the computer would say: WTF? Should I be concerned? Can I just reset the warning indicator?
Thanks again for thoughts and help.
07-21-09, 02:59 PM
Rookie
Any advice?
07-21-09, 03:14 PM
Pull the code, auto parts stores can usually do that for free, then post up the code.
Ben Silva
My writeups:
09-01-09, 05:16 PM
Supporting Vendor
Not sure if you fixed your problem yet or not, but just a heads up. we will be selling a replacement piece soon that includes the entire y-pipe section and a high flow cat. Direct bolt-in replacement http://forum.ih8mud.com/80-series-te...80-series.html
