07-14-09, 08:54 PM
#61 (permalink)
Lickalotapus Rex
Originally Posted by splitshot
I didn't either till I read through this thread, worth a try...
That does mean another high altitude run in the near furture.
Well...duh
07-14-09, 08:59 PM
#62 (permalink)
Originally Posted by MaddBaggins
Well...duh
I'm in. Picnic or overnight on mount lemon?
1994 FZJ80, OME850/864 w/ CSC 1.5" spacers, 285/75 r16 BFG AT/KO, 131K
"SUBDUCTION leads to OROGENY"
"Strip Mining Prevents Forest Fires!" "Stop Continental Drift!"
"Tuff Schist" "Reunite Gondwanaland"
WFC: 2020 5337 1783
07-14-09, 09:04 PM
#63 (permalink)
Lickalotapus Rex
I'll fill up with Techron Supreme and we can take the kids for a picnic saturday
07-14-09, 09:39 PM
#64 (permalink)
1FZ-FE Club
1994 FZJ80
07-14-09, 09:45 PM
#65 (permalink)
Lickalotapus Rex
same as mine and Ross.
07-14-09, 09:59 PM
#66 (permalink)
_
Originally Posted by turbocruiser
... BTW, you should not use Redline WW with Toyota Red, causes a sludge throughout the system and has caused some cooling issues for a few folks. HTH.
A touch off-topic here: Are you referring to the regular red Water Wetter or the purple Diesel Water Wetter? I am currently using the diesel version in an effort to reduce warm-weather off-idle/transitional pinging. I was under the impression it was silicate-free and would not react in a negative manner with the silicate-free Toyota Long Life coolant.
96 FZJ80 | 97 FZJ80
07-14-09, 10:00 PM
#67 (permalink)
Parts Geek, M1 Mechanic
Originally Posted by Tools R Us
I wonder if fuel mix has changed to lower the vapor pressure enough to overpower the system? I know that some additives were not run here in the summer because of this, maybe this has changed or they are getting close to the line?
This is a very interesting observation. Just this afternoon I was over at my favorite boat shop and the owner was bitching about the ethanol content of current gasoline. They have been having substantial problems with vapor-lock in Mercury I/O fuel injected engines that are running fuel (the only kind they can find) that is blended with ethanol. The only cure is to drive 165 miles south to get to the one station at Elephant Butte that does not have blended fuel.......
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
07-14-09, 10:26 PM
#68 (permalink)
Originally Posted by cruiserdan
This is a very interesting observation...over at my favorite boat shop and the owner was bitching about the ethanol content of current gasoline
On this note on our 5-week southern US "expedition" loaded no doubt to GVWR, 4.10 gears and 315s, we maintain a decent 14-15 mpg highway (and the requisite 10-13mpg city).
Anyway, stopped near the coast in Louisiana and filled up adjacent to a marina with 93 octane E0 (non-blend) fuel. We got 18.5mpg on the same stretch of I10 on cruise control where earlier we got 14.5mpg, identical weather too.
I'm fairly certain that especially during the fuel hikes of last summer, many distributors overblended. Additionally in Phoenix where we're getting such poor volume:energy ratios in 115ºF, it can't help this situation when we drive to cooler altitudes, maybe introducing an abnormally low "A" pressure in the fuel system?
Pskhaat (Scott)
UZJ100 FZJ80 FJ45
07-14-09, 11:36 PM
#69 (permalink)
Alcohol is one, but there are a few components/additives that can lower the vapor pressure of gas. From some brief research Phoenix area summer fuel is mandated to be 7 psi vapor pressure tested at 100F, but the rest of the state is 9psi.
So we leave with 9 psi fuel, it’s 110F, driving over black asphalt that’s 140F, the A/C is on full bore so the fan output temp is 150F blowing back under the rig. The fuel is pumped through the system and a portion is returned to the tank, used as coolant. After a few hours of driving, how much will this heat the fuel and what will the vapor pressure at that temp be? During our drive we gained altitude, to say 6000 ft and the atmospheric pressure is ~11 psi.
I’m no fuel chemist, so don’t have the answers, but it sounds plausible that this could cause some of the fuel components to vaporize, off gas and overload the system? If so would the effect on system components be permanent or would it be purged out and recover?
Copper State Cruisers #007
07-14-09, 11:41 PM
#70 (permalink)
tools
I can see your take on this, it seems like a good overview, but mine does it up here in Flag at 7000 feet even when I do not change altitude at all, seems to only do it in hot weather 85 and up, does not get balls soggy hot like it does down there in Phoenix but still does it up here, can actually here it boiling in the tank, = scary!!!!!
Just a thought
Sethro
07-15-09, 12:01 AM
#71 (permalink)
Originally Posted by sledge916
tools
Just a thought
Sethro
Same scenario applies, the raise in altitude is for Mr Baggins/us valley dwellers. If your running 9 psi/100F fuel at say 11 psi atmospheric pressure how much heat does it take to to raise the vapor pressure enough to get significant off gassing?
07-15-09, 04:57 AM
#72 (permalink)
ThinkTank Waterboy
have any of you guys replaced the fuel pump? Maybe that is becoming a bigger heat source as it ages.
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-09, 06:22 AM
#73 (permalink)
Alvin and I just changed his out on Sunday because we were there and he had a new one (+tank filter) on his shelf. We may find out this weekend if it helps.
WFC: 2020 5337 1783
07-15-09, 08:23 AM
#74 (permalink)
yup, changed pump, pump sock, and relay
Sethro
07-15-09, 08:32 AM
#75 (permalink)
Hmm I wish I knew the answer to that, I don't know. I sure hope someone figures this out, just a matter of time I guess , this group of people usually do figure things out sooner or later.
Sethro
07-15-09, 05:22 PM
#76 (permalink)
What's next?
I'm leaning with Kevin, the additives they are putting in are creating a different flash piont than the system can handle in extreme conditions (or was ever intended to). I thought higher octane would counter act, but Gotmud blew my theory...
'69 fj40
CSC#103
A dry heat still cooks a turkey
07-15-09, 05:59 PM
#77 (permalink)
Lickalotapus Rex
If it turns out the fuel additives are the culprit, then the only real choice I'll have is to either drill a vent in the cap or remove the vent line from the cc before I do any trips.
07-15-09, 07:17 PM
#78 (permalink)
I disagree, would make the “problem” worse.
... I opened the gas cap and it vented for (I kid you not) 10 minutes. …
The only process that I can see causing this is fuel off gassing/boiling, two ways to stop it are; lowering the fuel temp or raising the system pressure. As the fuel temp increases, the vapor pressure is lowered and it starts off gassing. The vapor has more volume than liquid, so pressure goes up. The system is designed to hold pressure, this is a good thing, it raises the boiling point of the fuel, like how the cooling system works. If the pressure is lowered, like you saw by removing the cap, it will boil more.
A vented system would boil off more fuel, more often. Our gas is a cocktail of ingredients, like with any distilling process the ingredient with the lowest vapor pressure will go first. With an open system much more fuel is going to be lost as vapor, at least this way most/some of it is being burned as fuel?
Is this causing a real problem or is it more is a noise/smell issue? Is it setting a code, making the motor run rich, etc? I agree that the system appears to be overtaxed and is operating outside of it's design, so is venting, but is it more than a temporary problem under certain conditions?
07-15-09, 07:22 PM
#79 (permalink)
I think the worry is that we will do permanent, catastrophic damage to our gas tanks. Both times I experienced this problem, I could hear the gas tank itself reform as the pressure was being let off.
1995 FZJ80, Locked, ARB, OME, BFGs, HIDs, 4x4Labs rear (Thanks Alvin!), Tradesman full length rack, CDL + pin 7. BA.
07-15-09, 08:43 PM
#80 (permalink)
I'm inclined to say that something is wrong with the rigs that are having these symptoms OR that people are putting too much gas in the gas tank at fillups ... aka "topping it off." I say that solely based on the fact that despite ascending and descending well over 6k ft in a single run, on almost always a full fuel tank, and on a relatively hot day here ~94 degrees, I don't have this problem. I "vent" for a few short seconds right after removing the gas cap, right after stopping to fill up, right after coming into town on a hot for here day and I almost always am filling up at 1/2 tank (habit). I never smell excess fuel vapors around the canister and I never vent for more than a few short seconds even if I let the tank down to 1/4.
As food for thought the "pressure tests" done as diagnostics are probably hindering the answer if they are done at pressures much higher than the tank generates. IOW if the tank is at say 2 psi vapor pressure and you are testing things at 20 you are going to overcome the obstructions or constrictions or valve malfunctions causing these problems. Its a circular test that returns to zero.
Also, as food for thought, any topping off of the fuel tank causes a comparatively massive volume of fuel to saturate the charcoal canister (massive compared to the slow vapor soak that happens via regular operation). If this has happened and preloaded the charcoal canister the combined effects of that and a hot day, a hot and aging fuel pump perhaps, and a return line that's too close to a heat source / heat sink and, voila, you have high fuel tank vapor pressures. That combined and compounded by assorted chemicals added to the fuel with lower vapor points probably makes this worse. I'd again suggest looking at the return system separately, making sure that there is a smooth running cool running fuel pump, and testing at tank pressures such as 2 to 5 psi. HTH.
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 9.5psi and climbing, My Rocky Mountain Mojo Mobile!
07-15-09, 09:09 PM
#81 (permalink)
Lickalotapus Rex
How about sitting on top of a gas tank holding so much pressure it vents for 10 minutes. Sound safe and fun to you? The idea of a tank bursting scares the shit out of me.
07-15-09, 09:10 PM
#82 (permalink)
ThinkTank Waterboy
as far as the topping off idea, how much stink bug if any do you guys have?
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-09, 09:12 PM
#83 (permalink)
Lickalotapus Rex
turbocruiser, both Ross and I do not top off. We discussed this while we were scratching our heads. I'm running a new fuel pump as of sunday. I'll see if that does anything.
07-15-09, 09:12 PM
#84 (permalink)
Lickalotapus Rex
I'm level
07-15-09, 09:50 PM
#85 (permalink)
I wonder if brittle vacuum lines down stream of the canister reduce the vacuum enough by letting in atmospheric air into the system and compromising the ability of the canister to purge.
I am also completely ignorant about the fuel pump system. Could the pump or
relay fail in a postion of too high of pressure causing more volume of gas to return via the fuel pressure regulator?
WFC: 2020 5337 1783
07-15-09, 10:02 PM
#86 (permalink)
The pressures called for in the FSM to test the charcoal canister are on the order of .5psi. That is hard to achieve on a regular shop compressor. Alvin's one year old canister "failed" this past weekend but we may of been using to high of psi. I don't recall Alvin if you smelled gas in the engine bay during your last gas boiling event.
It may be useful to just relace all to rubber lines in the
HVAC loop in an attempt to solve this. I just wish there was an easier way to do this other than removing the air intake. Granted, I don't know how filthy the intake gets but a
thorough cleaning of it and the associated ports may help as well.
I would think they might have similar problems in Aus unless they don't have a simlar HVAC system as they don't have our EGR.
I'm as concerned as Alvin yet feel like I am grasping at straws.
WFC: 2020 5337 1783
07-15-09, 10:26 PM
#87 (permalink)
Okay, so scratch that off the list then ... but ... do return to testing the system using sub 2psi pressures (IIRC the gas cap itself is designed to hold two pounds or 2.5 pounds so anything more than that assuming a properly working cap is hindering your search for solutions).
Another thought just to cross another easy thing off the list ... do any of your regular parking positions include a decline on the USDS of the vehicle? If so right after a fill-up, even one carefully controlled so as to prevent topping-off, you might have some gas seep into the overflow tube causing the "pre-load problem" in the charcoal canister. Hope this helps.
07-15-09, 10:33 PM
#88 (permalink)
Can anyone post up the hose routing diagram?
Originally Posted by decavo
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
07-15-09, 11:42 PM
#89 (permalink)
Bad gas Tank?
88 4runner, Downey 3" lift, headers, intake, exhaust, 4.88, custum body
92 fj80, OME 851/863, Diff breather mod, basically stock DD, The Meat Wagon
"Bring out your dead"
07-16-09, 10:53 AM
#90 (permalink)
Originally Posted by Tenzig Norgay
Bad gas Tank?
Not likely.
