Old 07-12-09, 05:13 PM   #31 (permalink)
Lickalotapus Rex
MaddBaggins's Avatar
TLCA# 14528
Originally Posted by landtank View Post
On the ones that I have seen that line on the bottom of the CC goes to a nipple that is mounted in the frame.
Maybe the 94s don't have it. I would think they would since I think air goes both ways and being left open it could suck in debris.
I'll check toyodiy.com
Not sure the link will work, outlet tube
part number: 77779-60010
Thats interesting. Both Ross' and mine just end towards the back of the firewall. That line is clear. Your link shows a good pic of a nipple and bracket, but we don't have that at all.
OK, the return line from the fuel pressure regulator to the tank is clear also. Ross and I are both leaning toward VSV or possibly the TVV. I'm going to probably order both of them, test the new ones, remove the old ones and test them and then replace them both.
Is there any way the pressure regulator could be causing any problem?
I had a new fuel pump and sock and since we were screwing with the fuel system, we changed that out just because.
Alvin
62 VW Type 1 Ragtop-Mine, new project
00 XTerra "Rocksie" slightly modded-Wifey's
94 FZJ80 "Tortuga" +4", 315's, 4.88's, locked, armored and scratched to hell-Mine
Copper State Cruisers 13
You're like a breadstick, you got no rhythm
What time is it?
Hey let me outta here, what am I here for
Groove
MaddBaggins is offline   Reply With Quote
Old 07-12-09, 05:27 PM   #32 (permalink)
Lickalotapus Rex
TLCA# 14528
Here's what confuses me. The FSM test for the charcoal canister says to blow compressed air into the tank pipe and air should escape from the purge pipe and the bottom pipe without resistance. This part of the test my canister passed.
If this is true how could the tank build up pressure? Even if everything after the purge side was broken, the fuel vapor and pressure should just blow thru the canister and out the bottom. How can I be building up pressure then?
Alvin
What time is it?
Groove
Old 07-12-09, 05:49 PM   #33 (permalink)
ThinkTank Waterboy
landtank's Avatar
have you tried to pressurize the tank through the filler neck to see if air comes out the canister or at least the air tube?
Rick Bigelow
'96 215k
Groveland MA 01834
Old 07-12-09, 06:33 PM   #34 (permalink)
beno's Avatar
TLCA# 14607
I don't have a charcoal canister. The return line is still there and still receives the waste vapor into the intake manifold for start up burn.
The other line I put a small filter on it and extended the soft line and it vents into the atmosphere.
Is this kosher? Probably not in any emissions jurisdiction that I know of...
I have some venting from the fuel cap on very hot days when I open up to fuel, but after about 6-8 seconds the venting from the gas cap stops.
Take it for what its worth Alvin. I'm not a fuel system expert (or any expert for that matter).
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
beno is offline   Reply With Quote
Old 07-12-09, 06:35 PM   #35 (permalink)
Lickalotapus Rex
TLCA# 14528
I can try it that way, it's clear the other way.
Alvin
What time is it?
Groove
Old 07-12-09, 10:23 PM   #36 (permalink)
sledge916's Avatar
I hope you figure this out as my 96 does this same exact thing!
Sethro
When In doubt, "gas It"
www.flagstaffsnowremoval.net
www.motoexpeditions.net
sledge916 is offline   Reply With Quote
Old 07-12-09, 10:28 PM   #37 (permalink)
Lickalotapus Rex
TLCA# 14528
Sethro
I'm trying, it seems there is a number of people who have this issue.
Alvin
What time is it?
Groove
Old 07-12-09, 10:41 PM   #38 (permalink)
raydouble's Avatar
What about heat from exhaust? Stock exhaust? Missing heat shields?
Originally Posted by decavo View Post
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
raydouble is offline   Reply With Quote
Old 07-13-09, 08:34 AM   #39 (permalink)
Ebag333's Avatar
TLCA# 18864
I had this occur to me the other day. Walked back past my fill port towards the back, and smelled gas strongly. It was not venting from the cap, but somewhere underneath. I opened the cap, and it vented for about 10 seconds, and has seemed fine since.
It only occured to me after a fill up where the guy had gotten it perhaps a bit too full, and it was relatively hot that day.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is online now   Reply With Quote
Old 07-13-09, 10:07 AM   #40 (permalink)
GeoRoss's Avatar
Doesn't appear to be an issue. I have a stock exhaust. Alvin does not. I think there is a problem in the EVAP system. Alvin passed all the tests laid out in the FSM for a running truck. We bench tested the VCV and check valve. We need to bench test the VSV and another valve that is opened when the truck warms up.
Does anyone have a ballpark price on the VSV or TVV parts? I hate the idea of throwing parts at the problem yet getting to those parts is a bit of a PITA without tearing down alot of the air intake. For that matter the air intake maybe a bit dirty allowing pressure to build up.
One question I have is with the fuel pressure regulator. What symptoms would there be if it wasn't behaving. Sort of a long shot hail Mary kind of speculation.
1994 FZJ80, OME850/864 w/ CSC 1.5" spacers, 285/75 r16 BFG AT/KO, 131K
"SUBDUCTION leads to OROGENY"
"Strip Mining Prevents Forest Fires!" "Stop Continental Drift!"
"Tuff Schist" "Reunite Gondwanaland"
WFC: 2020 5337 1783
GeoRoss is offline   Reply With Quote
Old 07-13-09, 07:09 PM   #41 (permalink)
AdventureBuddies's Avatar
I believe a number of people who have this issue (including myself) have aux tanks. Is this happening to people who don't have aux tanks?
The only time it happened to me I was heading off to Death Valley and fueled up about 15 miles before getting on the trail. I filled the tank and sub tank as full as I could. It seems that was a mistake - that overfilling can cause problems. So, has anyone confirmed if this pressure problem occurs when the tank not full? I don't know if it's relevant, but it would be useful to try to determine similarities between everyone's trucks/situations.
97 CE: BFG AT 315s, +3.5" OME 419/868, 3x locked pin7, 4.56, ARB/M12000, modded Kaymar, snorkle, FrontRunner 45 gal sub tank, Maggiolina Grand Tour RTT.
"It's a shame that at this moment all of the people who best know how to govern the world are busy drinking beer."
AdventureBuddies is offline   Reply With Quote
Old 07-13-09, 07:33 PM   #42 (permalink)
sledge916's Avatar
mine does it too and I do not have a aux tank
Sethro
Old 07-13-09, 07:41 PM   #43 (permalink)
retrofive's Avatar
TLCA# 19315
Just for a little bit of reference Ebag333 and I live in the same city, climate, etc. I have not experienced any of this. We typically wheel together as well. I own a 94 pretty much stock and min. PM at this point. FWIW HTH.
'94 LC |OME 851+1"/860/N73/N74E/SD24|SLEE BLUES|SLEE SLIDERS|CDL/7PIN|285/75/16|YAK RACKS
JEFFERSON STATE CRUISERS
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
retrofive is offline   Reply With Quote
Old 07-13-09, 10:23 PM   #44 (permalink)
1FZ-FE Club
gotmud's Avatar
TLCA# 18039
Alvin/Ross,
My 94 still does this even after replacing the VSV & TVV, which I did two months ago when I rebuilt my engine.
Strangely, the tank even built up pressure without the engine in. I noticed the smell of gas one day and noticed it was peeing out of the fuel line that would normally connect to the fuel filter. I clamped the line and periodically cracked the cap to vent the tank on the warmer days when the a/c was not on out in the shop.
I mainly purchase gas from QT up here in the valley. Not sure of they have additives that lower the boiling point of the gas that cause it to boil off sooner than another brand of gas. Since all of the fuel up here comes from the tank farm out in west Phoenix, it's hard to say which brand(s) might have different additives. I also fill up our Corolla at QT but don't have the same issues, and it sits out in the sun all day.
1994 FZJ80
gotmud is online now   Reply With Quote
Old 07-14-09, 09:41 AM   #45 (permalink)
GeoRoss's Avatar
Originally Posted by gotmud View Post
Alvin/Ross,
Alvin and I are completely confused. We are going to try and pressurize his tank and see what happens. The tank breather line is clear from the charcoal canister to the tank. Pressurizing will show that it is clear the other way. I don't see a valve of any sort on this tank breather.
Alvin's TVV and the VSV controlling this system checked out during running checks as well as bench testing the other valves.
I don't know enough about the system but to throw out WAGs. Could the fuel pump be pushing too much fuel to the filter (relay or other control mechanism) and causing too much warm/hot fuel to return to the tank via the fuel pressure regulator and tank return line? This could pressurize the tank during warm temps and rapid changes in altitude. The excess fuel vapor could then overwhelm the charocoal cannister causing premature failure.
WFC: 2020 5337 1783
Old 07-14-09, 09:45 AM   #46 (permalink)
1FZ-FE Club
gotmud's Avatar
TLCA# 18039
IIRC, there is a check valve somewhere between the cc and the gas tank. I have yet to look for it, but I just might later this evening. I suppose it is possible this valve could be bad and is letting too much pressure return to the tank. Once again...
1994 FZJ80
Old 07-14-09, 11:03 AM   #47 (permalink)
ThinkTank Waterboy
landtank's Avatar
on a trail run this summer we had a guy with a 91 boil off 5 gallons of fuel. The first thing he noticed was a hissing sound coming from the CC. When he pulled the gas cap the tank vented for something like 10 minutes and you could hear the gas boiling.
If everything checks out I'm thinking the evap system is getting overwhelmed from pressure do to expanding gas and just can't vent it fast enough. With more and more people having this problem it might be a good idea to change out all the soft lines. They might be swelling with age adding some restriction.
Just a wild ass guess but from where I'm sitting it would be my next move.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 07-14-09, 12:15 PM   #48 (permalink)
Just another cruiser with the same problem. Always just had a few seconds at fillup, but on recent trip from AZ to WY, it vented for several minutes. Was fine on the next fillup. Interested to see if it was an isolated event or happens in the near future. Subscribed with interest.
David
currently 5 LC's, but need to downsize. 4 fzj80's (1 rollover for parts), 1 '71 FJ40 project
Pinetop Cruiser is offline   Reply With Quote
Old 07-14-09, 06:14 PM   #49 (permalink)
alia176's Avatar
It sounds like the charcoal inside the canister has expired on our older rigs. FirstToy replaced his charcoal and all has been well ever since. If these things weren't so expensive, more and more of them would be replaced I'd imagine.
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 07-14-09, 06:20 PM   #50 (permalink)
Photoman's Avatar
I had this happen to me going up and through Denver. The way I solved it was I bought a second gas cap and drilled a small hole in it. In essence making it a vented cap. I may have made a check valve with a ball for it. It was 7-8 years ago and I can't remember. The original cap is good for emissions if there is testing.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 07-14-09, 06:28 PM   #51 (permalink)
1FZ-FE Club
gotmud's Avatar
TLCA# 18039
My cc is brand new. Changing it made no difference at all.
1994 FZJ80
Old 07-14-09, 06:39 PM   #52 (permalink)
GeoRoss's Avatar
I talked to CDan yesterday and learned that the charcoal canister of the 93/94 model years is now discontinued. 95-97 is a different part number. No clue if there is a difference but since my canister failed spectacularly in the FSM test, I am taking a chance this will work fine as a replacement. I ordered a new gas cap with thoughts of creating a vented gas cap.
One thing I am not sure of is the breather hose coming out of the tank. There is a part called something along the lines of some sort of valve. I guess I could see a way where this is a one way valve to the canister that can get gummed up if the tank gets overfilled which also hurts the charcoal canister.
IIRC people with sub tanks fill the main tank through this line. Can anyone recall if there is some sort of one way valve there.
WFC: 2020 5337 1783
Old 07-14-09, 07:45 PM   #53 (permalink)
Tools R Us's Avatar
I wonder if fuel mix has changed to lower the vapor pressure enough to overpower the system? I know that some additives were not run here in the summer because of this, maybe this has changed or they are getting close to the line?
I haven't noticed this problem, but when we were on 4 Peaks a couple of weeks ago (~4000ft climb), noted that all of the rigs there had gas smell.
This maybe helpful?
http://www.autoshop101.com/forms/h62.pdf
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 07-14-09, 07:59 PM   #54 (permalink)
Lickalotapus Rex
TLCA# 14528
Ali, that would be a thought, but I replaced mine last summer when this problem first arose. problem is still there.
I think I will make a vented cap or pull the line to the cc when I do any elevation and just let it vent to atmosphere.
I think Tools may be on to something. That gas smell is the first indicator Kevin.
Alvin
What time is it?
Groove
Old 07-14-09, 08:10 PM   #55 (permalink)
Lickalotapus Rex
TLCA# 14528
Maybe I should stop hitting the cheap station and fill up with Chevron during the summer and see what happens. It would be a cheap experiment.
Alvin
What time is it?
Groove
Old 07-14-09, 08:14 PM   #56 (permalink)
GeoRoss's Avatar
My limited research points to this as an issue, especially in the spring when the blends switch.
Something is overwhelming the HVAC system which I guess leads to premature charcoal canister failure. Too much hot gas returning to the tank after the fuel pressure regulator? Intermitent failure in any of the three valves that purge vapor from the canister to the intake? Patially blocked tank breather line from the tank to the canister?
FJ40Jim advises to just swap the purge and tank lines on the canister to bypass the HVAC system in a 60. Maybe it would help an 80 in
duress?
I read that PDF you posted. It advises not using shop air to pressure test parts of the system. Something about oxygen and gas and explosion. Alvin and I are/were planning on trying to pressurize his tank at the filler to check if that breather hose is. Should be intersting.
This maybe helpful?
WFC: 2020 5337 1783
Old 07-14-09, 08:19 PM   #57 (permalink)
tblume's Avatar
TLCA# 19103
to throw another "what if" in the mix;
are you just recently seeing E10 in your area?
WAG here but I speculate the petro-chem industry is stretching the fuel out to the ragged end and it is not doing well with our somewhat older rigs?
'93 FZJ; 3x locks, CDL &7 pin, tall skinny MT's, mediums, metal tech bumper. no flares-rack-steps.
RIP '71 FJ55 '78 FJ40 '84 FJ60
tblume is offline   Reply With Quote
Old 07-14-09, 08:42 PM   #58 (permalink)
What's next?
splitshot's Avatar
Have you tried switching grades? I'v got a truck that cannot tolerate 87 in the summer because of the volatility, but runs fine with it in the winter.
'69 fj40
CSC#103
A dry heat still cooks a turkey
splitshot is offline   Reply With Quote
Old 07-14-09, 08:47 PM   #59 (permalink)
Lickalotapus Rex
TLCA# 14528
With the mileage this thing gets and the price of gas, I hadn't considered that.
Alvin
What time is it?
Groove
Old 07-14-09, 08:51 PM   #60 (permalink)
What's next?
splitshot's Avatar
I didn't either till I read through this thread, worth a try...
That does mean another high altitude run in the near furture.
'69 fj40
CSC#103
