07-03-09, 10:28 PM
New OEM Inner Hub Oil Seal different?
I searched but didn't see any thing that addressed this.
My new front hub oil seals are different than what is currently on my 91 FJ80. The old ones have a distinct groove or step on the side that faces outward (towards bearings), it also has a rubber lip that originates from both sides of the seal.
The new oil seal's metal body is flat on both sides, and on the side facing the bearings there seems to be a gap from the metal lip instead of a rubber seal. Also the new one has a coil spring behind the rubber lip...dont see the coil on the old one.
Anyone else encountered this difference? I'm thinking that what I have on there is either old oem part that has been superceded with a new design or that it is an aftermarket seal?
Any thoughts?
1991 FJ80
07-03-09, 10:32 PM
Parts Geek, M1 Mechanic
The wheel bearing seals, 90311-62001, have been the same since 1976.
Do you have new factory seals? Are they 90311-62001? If so, the seals in the truck are not factory seals. If you do not have new factory seals then that may be your problem.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
07-03-09, 10:35 PM
IH8MUD addic
I think this is after market seal I just replaced what seems the same as from your description .
I was curious to see them different but I bet PO wanted cheap job so he got it.
Some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned or negotiated with. Some men just want to watch the world burn.
07-04-09, 02:09 AM
Yes they are.
I've taken a pic of them both:
Does the side with the gap on the new OEM seal(pictured above) go toward the bearings & outer hub?
I assumed so but thought I'd ask to be certain.
thanks.
1991 FJ80
07-04-09, 02:18 AM
Originally Posted by Marco7
Yes they are.
thanks.
I don't believe so (if I'm understanding you correctly). The side with the spring goes inboard (towards the center of the vehicle).
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
07-04-09, 03:09 AM
Ohhh. Glad I didn't install them yet.
My logic was that the gap would catch the grease, but I can also see that it could be engineered to use the strength of the coil spring as a barrier to keep the grease packed inward toward hub. And if the grease got onto the spring it could work it's way loose.
Thanks firetruck!
1991 FJ80
07-04-09, 09:57 AM
Those are NOT factory seals, they are aftermarket copies. The label is generic and if you note it says "REF # ONLY".
07-04-09, 03:57 PM
I used Marlin crawlers new seals on my front end rebuild a yera ago , great so far. Much bigger/ heftier than stock
1981 BJ42
07-04-09, 08:41 PM
What?
I'm suing!
Here's my receipt:
I guess the circled policy isn't quite etched in stone there.
Should I just roll with it and use them or is it worth the hassle of raising a stink about it on Monday when they re-open?
Thanks Cdan.
1991 FJ80
07-05-09, 12:10 PM
#10 (permalink)
So is the packaging pictured definitely NOT Toyota?
That would be very disturbing to know that this particular dealer could not be trusted to sell authentic oem parts.
I really need to button it all back together so i may never know. Next time I'll just order straight from cdan.
1991 FJ80
07-05-09, 02:45 PM
#11 (permalink)
Not a factory wrapper, not a factory seal.
07-05-09, 02:49 PM
#12 (permalink)
www.got40.com
Now that there is some kinky shit if true.....
My Toyota dealer will refuse to use non Toyota parts....
Shane
07-10-09, 07:53 AM
#13 (permalink)
he also charged you too much they should be about $12.00 each. you need a new place to get parts from like i don't know maybe cDAN.
Eric J
94' de-flared FJ80 on OME heavies with slee blue's on some 33's, Aussie locked rear, ARB front loaded with a re12000 & Kaymar rear, home made sliders, budbuilt drag links and 250K+ on the clock. cdl switch w/7-pin.
OLDE NORTH STATE CRUISERS
