07-02-09, 08:17 PM
| | Forum Lifer
| Brake Light help needed: Ok folks here is what happens:
All lights off----apply brake=
Results: (both brake lights work, DS BRIGHT/ PS-just running light bright)
Key in ON position---- head lights on=
Results: Only DS brake light works-VERY bright, PS goes off NOTHING)
* let off the pedal w/ lights on & you have running lights on both sides
* third brake light--NO ISSUES!
NO trailer harness in system.
Any thoughts folks, wife's rig & I don't need her getting pulled over for this & not knowing how to fix it.
Would this be a ground issue or a power issue????
Any help is GREAT!!!
Thanks!!
__________________  You can't fix Stupid
---CottonLand Cruisers-----
---White Trash of the Elwood Chapter----
---STLCA----
------------------------------------------------ We've been this close to death before, we were just too drunk to know it
Guess the price of being sobers being scared out of your mind
-Drive by Truckers-
07-02-09, 08:57 PM
| | rockin' a 2WD 80...
| Replace the bulb. Worth a try...
__________________ Lane Anderson Daily- '91 TRD FJ80 "Katie" - 3H4, 267k, 3FE, Registry, ROTF, FB Beater- '96 RZJ90 Prado RC - Red, SAS, geared REALLY low, locked F/R, 4-linked, coilovers, big tires on beadlocks, chopped, PIC Classic- '63 VW Type 1 (Bug) - Anthracite, 43k, 1600cc, 100% restored, BLOG Non-vehicle- '01 Crate 4-str bass - MapleBurst, Ernie Ball Slinks, '62 Fender P-bass pickups, PIC ---- "VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
"You're not allowed to use words like 'zirconium' without giving more info. That's a rule somewhere." -Jon Held |
07-02-09, 09:50 PM
| | Forum Lifer
| Quote:
Originally Posted by Lka1988 Replace the bulb. Worth a try... | Yea, tried that but still the same result
---STLCA----
-Drive by Truckers-
07-03-09, 05:16 AM
| | 250+ Club
| I had a similiar issue with my turn signal. Driver's would work and Passenger's would not. Replaced the bulb with one I had in the garage and it still didn't work. Tried another bulb and it worked. Though the bulbs looked the same I guess they were different.
__________________ 1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust. |
07-03-09, 09:22 AM
| | Hill & Gully Rider
| Try replacing both brake light bulbs. The bright one may actually be a bad bulb. To prove that, swap original bulb positions & try testing before replacing with new bulbs and see if problem follows the suspected bulb. - HTH
__________________ '94 FZJ80 w/220K+miles; FF & Disc Brake Rear Axle, ARB w/Ramsey8K, Kaymar w/spare pivot, "Redneck Enginuitive Bellypan" skid plate, 2 batts. & isolator, OME 850/863 Springs w/OME N73/N74 Nitro Shocks, SS Brakelines, OME caster kit & steering damper, CDL W/Pin 7 mod., Temp.gauge mod, Amsoil converted, F.O.R. sliders. Green Diamond Tires: Icelander M/T LT265/75R16-E - Tom -- Link to my GDT tire thread
Reason: clarify swap
07-03-09, 02:55 PM
| | Forum Regular
| is it possible you have the bulb in backwards IE there are two differ levels on the nubs on the bulb. I think I did this but it might have been on my old chevy?
__________________ 95 Landcruiser: All Stock, PHH, Graphite wheels, black grill mod Graphite emblems, 275/70/16 Goodyear Fortera Triple Tred's.
08 Tundra Crewmax Limited: Redrock Leather. FBG 3/1, stock tires for now. BUY YOUR SURVIVAL BRACELETS HERE! |
07-03-09, 04:07 PM
| | Hill & Gully Rider
| Quote:
Originally Posted by grizzlygibbs is it possible you have the bulb in backwards IE there are two differ levels on the nubs on the bulb. I think I did this but it might have been on my old chevy? |
Good point, griz. It's made that way on purpose - it's called keying the socket and you shouldn't be able to get that bulb in backwards, unless the socket is broken or the bulb was forced in. These dual circuit bulbs and sockets can be the source of a bunch of electrical nightmares, unless you know what's going on. Two circuits feed these sockets - 1. brake lights, & 2. tail/running lights. The wires and filaments are in close proximity and a short can mess up either or both. Residual moisture from water crossings can make it even worse. These light bulbs & sockets are a good place to start for twilight-zone electrical problems with your rear lights.
__________________ '94 FZJ80 w/220K+miles; FF & Disc Brake Rear Axle, ARB w/Ramsey8K, Kaymar w/spare pivot, "Redneck Enginuitive Bellypan" skid plate, 2 batts. & isolator, OME 850/863 Springs w/OME N73/N74 Nitro Shocks, SS Brakelines, OME caster kit & steering damper, CDL W/Pin 7 mod., Temp.gauge mod, Amsoil converted, F.O.R. sliders. Green Diamond Tires: Icelander M/T LT265/75R16-E - Tom -- Link to my GDT tire thread |
07-04-09, 09:25 AM
| | 250+ Club
| I have/had the same symptoms. I'd already swapped out the right side rear brake bulb recently and yet was told again it was out.
What happened in my case is that the wire for the brake signal is soldered to the exterior metal of the socket housing. I found that the wire wiggled abit too much and sure enough.. that's what was causing it. I soldered the wire back to the metal side of the socket and brake light was back in service.
I hope that helps.
__________________ __________________
- Sean
97' FZJ80 "Fire Engine" Red/ARB winch bar & M8000 /OEM Lockers/OME 850/863 & OME shocks/285-REVOs/Custom welded roof rack on factory rails (Blackout special)/XTVA & XTS5000 radio/Yaesu 8900/CB WX/custom storage drawers/
'88 4Runner |
07-31-09, 09:38 PM
| | Forum Lifer
| Quote:
Originally Posted by RescueU I have/had the same symptoms. I'd already swapped out the right side rear brake bulb recently and yet was told again it was out.
I hope that helps. |
Big thanks..... on Sunday I'll look into this
---STLCA----
-Drive by Truckers-
08-31-09, 03:46 PM
#10 (permalink)
| | Supporting Vendor
| Did you ever find a solution for this? |
08-31-09, 08:35 PM
#11 (permalink)
| | Forum Regular
| I had a very similar issue. Light off, ps brake lights work. Lights on, ps brake light wouldn't.
Changed bulb, swapped bulbs, etc. I ending having to replace the entire socket.
Works fine now.
__________________ Stocked '94 FZJ80 CDL - 7 PIN'D |
