Old 07-02-09, 02:37 AM   #1 (permalink)
93 landcruiser ECU pinout diagram
this is for a 93 land cruiser...
i cannot believe NO ONE has a printed diagram of our ECU pinout???
i'm trying to install a piggy back fuel controller to play with my a/f mixture during idle and cruise. i have a hks s-afr hoping i can use it with success to get better gas mileage
i've located the ECU, but i need to know where the:
air flow pressure signal (mass air flow sensor) wire
throttle position sensor wire
rpm signal
ecu ground wire
thanks for any help
93 Toyota Land Cruiser... Pioneer AVIC- Z1 Nav/DVD
305,000 miles!
Tuning Haus is offline   Reply With Quote
Old 07-02-09, 02:51 AM   #2 (permalink)
i am talking about the COMPUTER TERMINALS like these
MKIV.COM
305,000 miles!
Old 07-02-09, 06:44 AM   #3 (permalink)
jlbuk's Avatar
all these are easily found at source, so if the colour coding of the cable stays the same throught it's length, you could easily verify that it is indeed the same wire at the ECU by continuity check ?
1996 4.5 petrol 80 UK truck, factory F&R lockers, 2" lift, 285/75 BFGs, OME CC bushes
1996 4.5 petrol 80 Zambia truck, factory F&R lockers, cheap ebay birfs - so far so good
1993 4.5 petrol/LPG 80 UK street truck (JDM import) upgraded to a 60221 ECU from the US, ome861s / 862s
jlbuk is offline   Reply With Quote
Old 07-02-09, 09:45 AM   #4 (permalink)
northerner
semlin's Avatar
rpm signal
ecu ground wire
thanks for any help
afaik, nobody has really tried to tune a 93 although there has been lots of talk about it.
the 93 does not have a maf it has a vaf. you should read this thread to learn more.
http://forum.ih8mud.com/80-series-te...n-project.html
the factory electrical manual is what you need but i think even the fsm has most of that information you want if you hunt around.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 07-08-09, 12:43 PM   #5 (permalink)
bump...
i have to say i'm kind of disappointed and surprised that out of all the experienced landcruiser die hard fans, i can't get anyone that knows the PINs on the ecu...
i just need to know
ignition
the mass air flow signal wire
rpm
throttle position
i believe that's it...
anyway, hopefully someone who knows comes across this post..
thanks again
305,000 miles!
Old 07-08-09, 02:10 PM   #6 (permalink)
northerner
semlin's Avatar
bump...
i just need to know
ignition
rpm
throttle position
thanks again
these are heavy trucks, not sports cars. with the exception of the vaf/maf conversion and upgrade projects, no one has really had much impetus to start messing with the air flow, ecus and tuning, especially on the 93/94s since they have no obd2 or maf. supercharger experience has shown that the 93-94 vaf does not seem to be able to handle greater airflow which is why we were looking at retrofitting a maf. i am interested to see how you make out and the link i provided has a number of potentially helpful diagrams.
93 fzj80
66 fj40L
m101cdn trailer
83 Honda ct70
48 Ferguson TE20
wfc 4812-2635-4880
Old 07-08-09, 06:01 PM   #7 (permalink)
retrofive's Avatar
TLCA# 19315
Garage
Isn't that info covered in FSM/EWD?
'94 LC |OME 851+1"/860/N73/N74E/SD24|SLEE BLUES|SLEE SLIDERS|CDL/7PIN|285/75/16|YAK RACKS
JEFFERSON STATE CRUISERS
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
retrofive is online now   Reply With Quote
