80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 06-29-09, 12:39 PM   #1 (permalink)
RescueU's Avatar
Resolved (so far) - violent shuddering on acceleration - POST MORTEM
I'm bumping this to it's own thread, so if someone wants to get right to the "brass tacks", they don't have swim thru the original lengthy thread (just a lengthy single post).
For reference, here's the original rth-experiencing-violent-truck-wide-shudder-accelleration thread.
So to recap, I've been experiencing a progressive power loss in conjunction with events when acceleration is applied (even modestly) on a long incline (no additional load than standard cargo with plywood drawer system in rear). The onset of this condition presents the symptoms of the truck shuddering, ie... the whole truck starts to vibrate as if going over small rumble strips. There were 2 events when a heavy skinny pedal was applied to counter a driving hazard, where the sudden down shift and revs up over 3000 rpm met with a hesitation, CEL coming on, and then severe power loss & rumbling that required a limping home. This would occur chiefly on the highway, but once the degradation began, I could be in a neighborhood going up a short hill doing 25 mph (w/o OD) and the shuddering would begin.
Just about 2 weeks ago, I replaced both of the factory installed O2 sensors with OEM Denso's, repaired badly leaking cat gaskets, and reset the ECU. For the following 5 days, the truck's health was restored. No shuddering returned, until I had to pull back into traffic from an off-ramp and saw a car barreling down on me in the rear view. So I laid in on the gas @ ~45mph, it downshifted and as it the rpms crested over ~3200 it hesitated and then threw the P0303 CEL (Cyl #3 Misfire) with significant power loss. From that point on, it was a daily experience with the shuddering, even after clearing the CEL and reseting the ECU.
Symptoms & Conditions
Here's an example of the repeatable experience to or from the office on a ~11 mile trip:
Driving home from office...
1mi away @ light - idle is ~4600rpm
3 miles - as I'm halfway up first long incline, shuddering begins @ 50mph-2k rpm and need to turn off OD
5 miles. - next incline w/o OD, hit shuddering @ 40mph-2200 rpm.
7 miles - accellerating up slight hill from stop light, shuddering begins after shifts into 2nd gear reaching ~40 mph - 2k rpm.
9 miles - Can reach up to 50mph - 3k rpm w/o shudder on flat/level stretch of road.
11 miles - Reached home. Idle in park & neutral is -6200rpm; ~6000 rpm in drive w/ foot on brake.
Diagnosis steps
Based on the documented experiences of other Mudders, I checked out the possibility of the EGR pipe touching the wiring harness during torque-heavy conditions and thereby affecting ignition/injection signal.
To recreate the above condition, I conducted the following tests suggested by alia176's:
1) power break test: left foot firmly on the brake and right foot pushing down on the gas pedal to 2,000 + rpm. Tell us if you can recreate this issue.
2) Same test but try to drive up a sidewalk so that the engine has to work real hard. You'll be driving head on (perpendicular) to the sidewalk, assuming your sidewalk has a nice sharp edge and is fairly tall, 6" or higher.
3) Shift Tcase into "low" and then try the same test as above. Do the sidewalk test again.
Results:
1) Other than a slight hesitation (but not repeatable every time) when hitting 1800 rpm, nothing remotely like what I'd bee experiencing on the highway.
2) Conducted up against 8" curb. RPMs could never get above 2000 rpm, whether in D (OD), D(OD off), 2, or 1. - Unable to recreate shuddering condition.
3) Note to self... where one or two test attempts will do, avoid doing it 20 times. I overcompensated not knowing the threshold and doing this for the first time. WARNING - too many of these tests and be on the look out for the A/T TEMP light to show up! Ask me how I know. - Needless to say, I never conducted the test in "low".
"If the issue returns during any of these three tests, then the engine torque (twisting) is messing with your ECU harness that goes right by the EGR pipe." -
This observation has been concurred by other members, so definitely be on the look out for this condition and should be one of the principal trouble shooting steps, IMHO.
Assessment Findings and Remediation
So I pulled all 6 spark plugs and found #1-#5 all identical. They showed signs of running very hot, possibly in lean situation. #6 was the surprise (since #3 Cylinder was attributed to the CEL misfire code), clearly showing oil deposits (gunk) all over the element. How it was firing I can't fathom.
At this point, I'm reading in the archives as well as some newly offered opinions that the oil fouling could be from a few serious conditions, like the HG, or leaky valve seals, etc.
Not having access to a test manifold (like this one from Summit Racing) to properly conduct a leak down test for the compression, I just swapped out the old plugs with new NGK Spark Plug Part No. 7090, G-Power Single Platinum; BKR5EGP. All were gapped to FSM spec 0.031" and installed, with appropriate amounts of dielectric grease at the plug's ceramic base and wire boots. All plugs torqued down to 14.5 ft/lbs (per CDAN).
BTW, anyone ever noticed in the 1997 FSM that it calls for 20Nm or 14ft/lbs. These are not the same even close, at least on my torque wrench. I don't have the T-wrench in front of me right now, but IIRC, 20Nm is +15 ft/lbs.. maybe more towards 16 ft/lbs. I went with lower amount of the 2 to be safe, prior to seeing CDAN's quote. Just an interesting observation to mention.
The Distributor cap was pulled and the rotor plug found to have heavy deposit build up and scoring. After cleaning it up, you can see the scoring much more clearly.
Not having a replacement Distributor Cap, I cleaned of the point contacts and they looked fine. Factoring the rotor plug's build-up as evidence of possible moisture in the cap, I'm guessing the cap's seal was compromised at one point. I was pretty liberal with the dielectric grease around it's edge, but still plan on picking up a new cap at first chance just to be safe.
I checked all the plug wires (aka FSM: high-tension cables) for resistance values. They are Nology HotWires that I swapped out for the original '97 OEM cables. I had these on hand for $20 new, so in they went and have been on for a good year now, I believe (checking on that). I still plan on getting a brand new set of Toyota OEM wires as soon as my budget can afford them.
Here are the resistance values for each wire. (smaller wire # = shorter length of wire)
Coil - 0.56 kΩ
#1 - 0.63 kΩ
#2 - 0.67 kΩ
#3 - 0.86 kΩ
#4 - 0.89 kΩ
#5 - 1.09 kΩ
#6 - 1.17 kΩ
Net Results
My LC is now running like it's back on its feet and producing strong responses to the throttle. From a dead stop, I took her up a hill that @ 1/2 mile in length @ a good 10° slope and she climbed solid and smooth all the way up to ~4200 rpm then shifted smoothly down to 3000 rpm and continued powering through the climb without significant hesitation... increasing speed the whole way up.
Now THAT's a remarkable difference from the recent experience of my "rollscnardly" condition (ie, rolls down one hill, can hardly get up the next). Every test I put her through, using short steep hills to long grade climbs, there's no doubt that I've gotten a significant amount of power restored in this ol' girl.
The real test was this morning's run to the office. At no point, with speeds ranging from 50 to 70 mph, did she even HINT at any of the shuddering from last week. Pretty amazing feeling, at least from my perspective in the DS.
So if I can find my OBDII reader, I'll try to capture some metrics on my laptop as she's running. I'll post them up when I can get 'em.
Note of thanks
As usual in my past experiences working with the membership of this forum, I'm always duly impressed by not only the breadth of experience to learn from, but also the vested interest folks put into helping others out. A number of you posted some solid info and experience that helped out considerably. In particular I just wanted to put a shout out to: SeanAndHis80 for picking this one up from the start and running it through the course; RacerLex, a local Mudder who offered up his new set of OEM wires for testing; and alia176, for the surprise phone call/message from New Mexico. Those were some good tests you suggested and definitely helped guide the diagnosis path with what we were able to rule out. I appreciate the time on the phone and the experience relayed about your HG "fun" and more.
Hey, I consider their responses actually commonplace for Mudders, and that's why I see them as uncommon.
Cheers, until the next evolution.
- Sean
97' FZJ80 "Fire Engine" Red/ARB winch bar & M8000 /OEM Lockers/OME 850/863 & OME shocks/285-REVOs/Custom welded roof rack on factory rails (Blackout special)/XTVA & XTS5000 radio/Yaesu 8900/CB WX/custom storage drawers/
'88 4Runner
RescueU is offline   Reply With Quote
Old 06-29-09, 01:16 PM   #2 (permalink)
SeanAndHis80's Avatar
New plugs are probably only a temporary fix. You are still going to need to figure out what is causing #6 to be so wet. Valve seals, HG or rings - gotta be one of them, right? ...the first two are easy to do at the same time - the latter would be a bear anytime.
97 40th lockersx3, Yellow top & Diehard PM-2. Pin7 mod, Georges LEDs & others, Revos, heated mirrors, massive inverter project underway. P0401 fixed. Currently at 180K+. more to come...
87 Supra Turbo - stock, 5-speed, targa roof, midnight blue. Currently at 125K+.
SeanAndHis80 is offline   Reply With Quote
Old 06-29-09, 03:52 PM   #3 (permalink)
RescueU's Avatar
Oh nice, Sean... suck the life outta my joy, even if fleeting.
Yeah, I know I'll be getting to know this engine on a more personal note in the not so distant future. I took some picks of what looks to be leaks underneath @ the engine/tranny connection point (how'd ya like that technical jargon?), and also in front, which I imagine is at the timing cover. I also notice at some point there was some oil leakage along the bottom side of the distributors connection to the head.
You can take a look at them here.
Gotta go get some rest. Let's see how the truck does on the homeward leg of the highway travel.
- Sean
'88 4Runner
Old 06-29-09, 04:16 PM   #4 (permalink)
Pics no workie.
The leak at the dizzy is just the dizzy gasket - a pretty quick and easy one to take care of.
'97 Land Cruiser, locked.
unclegit is offline   Reply With Quote
Old 06-30-09, 04:25 AM   #5 (permalink)
RescueU's Avatar
Originally Posted by unclegit View Post
Pics no workie.
All fixed. Thanks for the heads up on that.
Yeah, I was looking at that in the FSM. Seems pretty straightforward. I was thinking about tackling that when I R&R the Distributor Cap. What do you think?
- Sean
'88 4Runner
Old 06-30-09, 05:10 AM   #6 (permalink)
I wouldn't go nutz trying to seal all of the leaks. What your pics show is typical for an engine of this age - mine looks very similar. The main thing you have got to do is figure out where the oil is getting into #6. I'll have to look around - but you can probably solve this by following someone driving your truck and looking for when the smoke DOES happen. Oil enters the cylinder under different conditions based on where the leak is. It probably doesn't smoke while idling - but you need to look during acceleration, deceleration and WOT. If you can figure out when it happens I bet we can narrow it.
Old 07-01-09, 08:15 PM   #7 (permalink)
RescueU's Avatar
Quick update:
Since Monday morning, I have to say I'm very pleased with the restoration of power during climbs and such loads.
Not one hint so far of the shuddering or power loss has returned (knocking on wood).
I still have yet to R&R the new plug wires, PCV valve and vacuum hoses.
I'll let ya know how it goes afterwards.
You know, Sean80...I'm half tempted to pull plug #6 since i'll be yanking the boot anyways, just to see how it's doing so far. That way I'll be able to tell if the replacement of the #6 wire made a difference with getting good spark.
- Sean
'88 4Runner
Old 07-02-09, 06:14 AM   #8 (permalink)
Do it if you are in there - you will at least get an idea how long it will last before having to replace again. BTW - I went through this with a 280Z - I am just guessing 20 years ago now. It was fuel fouling the plugs due to a faulty sensor in the fuel injection. I did it for a year or so. I found that NGK plugs held up to the conditions the best by far - lasting 3x longer than any other plug I put in there. I have used them in every application since - and was happy the LC specified them stock.
Now, if it were mine, I would do the head gasket PM - or at least start planning it. The reason I would is because it will expose all three possible areas that the oil could be getting in and put you at ease of mind with the HG at the same time. When the head comes off - send it out to be cleaned, new valve seals(1), and valves adjusted. Do the head gasket(2) as described here or the FSM and while you are in there you would be able to see if the rings(3) are in bad shape by the bore of the cylinder.
Old 07-02-09, 07:12 AM   #9 (permalink)
RescueU's Avatar
I'm with you on that, Sean. The thing that concerns me is what you see in the pic of the beginning of the leak @ the tranny seam. Notice how clean that is? I had wiped it all down before firing the 80 up after all the work on the plugs and such. I took it out on a test run and ran her for maybe 15 or 20 minutes of tests. That leak you see in the picture was taken right after I pulled back into the driveway. With that additional info, what impression does that give you about the nature of the leak, other than just "old age".
Dude, I like how you think. I'll definitely get a friend and check that out.
Again, I'm of the same mindset. I'm not really afraid to try any new procedures, but my main concerns are three-fold: 1) Do I have the proper reference knowledge and have prepped ahead of time so I know what I'm getting into, or atleast have access to someone that can provide RTH if needed; 2) Do I have all necessary tools to do the job right, the first time; 3) Workplace location....considering that all my wrenching is done in the driveway or curbside in front of my house, due to lack of a garage, I'm cautious of the big projects like a tear down. Heck, my only saving grace has been the 10X10 tent I've depended on over the years. Given a garage that'd allow me to tear things down, with space to lay it out without fear of being (relatively) disturbed, then I'd be one very happy camper.
So, I do the best with what i have to work with in the open air, plan for the worst, and expect the best. Besides, I'm already prepping my neighbor a few doors up who's a fellow wrencher with a 2 car garage. I've got a 22RE from my '88 4Runner that's been sitting on the side of my house for months now needing some engine work. Hoping to use his garage to pull the 22RE and rebuild that.
- Sean
'88 4Runner
Old 07-02-09, 09:13 AM   #10 (permalink)
Yeah - that is a bit more then. Track it down, with the fan and the wind speed under the truck where you see the oil isn't necessarily where it is leaking from.
I hear you there. I have been wrenching in driveways and parking lots for 7 years now and would be hesitant to take on such a project without a garage either. I finally solved it - just bought a house this week with a large two car garage ...sorry it is about 300mi North of you in New Hampshire.
Someone has made a head gasket DVD on this board - is it IdahoDoug maybe? I would get that to build up confidence and get a good idea on the job length. I have Elmariachi's Birfield DVD and am waiting for a good night to view it. Told wifey that it has a surprise ending!
Old 07-04-09, 10:32 AM   #11 (permalink)
RescueU's Avatar
I grew up in Amherst, NH (at least 13 years of my youth). Honest to God, I was just thinking last night size of the spread up there we could've gotten if we'd sold our place here in NoVA a few years ago. I could see the barn with the 4 post lift!
Alas, here we are and thus here I wrench!
Happy 4th of July to everyone!
- Sean
'88 4Runner
Old 07-05-09, 06:27 PM   #12 (permalink)
RescueU's Avatar
Uh oh!
So I finally got around to replacing the distributor cap and spark plug wires. As discussed earlier, thinking it would be prudent to pull #6 spark plug while I was in there I went ahead and did it.
Glad I did......(see attached)
I really can't tell if this thing has ever fired! And I don't get the sense it's oil vs unburnt gas. Could it be that the #6 was never getting spark or atleast not reliably via the spark plug wire?
I'm kinda at a loss why the CEL is not informing that I'm missing or something. And furthermore, why isn't the 80 running rougher?
Is there a good test to confirm that spark is actually coming down the wire and firing off the plug?
- Sean
'88 4Runner
Old 07-05-09, 07:47 PM   #13 (permalink)
Does Blackstone labs test antifreeze for contamination (oil or combustion gases); would that help narrow it down??
Found this link:
IH8MUD Forums - View Single Post - white smoke
Kernal is offline   Reply With Quote
Old 07-06-09, 08:34 PM   #14 (permalink)
Believe it or not - but that plug is probably still firing OK. Oil is not inherently a conductor so it will not immediately affect the spark. After a while the heat and electricity will more or less create a conductive path to ground that will sap the spark and make the engine run like it did. It will happen again and, unfortunately, as you know #6 is not easy to get to for a quick replacement. My bet is still on the head gasket being the culprit at this point. Are you sure that there are no signs of trouble in your overflow? Does it pass the bubble test?
Amherst is real nice - we used to have a house in Nashua about ten years ago and I always had wished we bought in Amherst back then. This time we headed East to Chester - lots of property and motorcycle trails to play with my kids on.
