Old 06-25-09, 06:16 AM   #1 (permalink)
95ToyCruiser's Avatar
Garage
Firewall Bushing/Bearing for steering shaft
I have a 1995 TLC and the steering has had a fair amount of play in it, I tracked it down to the penetration of the steering shaft through the firewall. There is a rubber gromit and it looks like there should be a bushing or bearing there. When the wheel is turned the shaft rolls along the bottom of the hole instead of turning in place. And help on even what the hell this part is called would be a big help.
Shane
95 Cruiser - Factory locked, OME J's, 35x12.5x15 Mud Kings, 1" wheel spacers, home made: rear bumber/roof rack/drawer setup, aux lights, more to come...
96 Taco - 2.7 5sp, TRD locker, 3" OME, 33's, woods beater!!
95ToyCruiser is offline   Reply With Quote
Old 06-25-09, 06:55 AM   #2 (permalink)
lowbanks's Avatar
There is a dust seal p/n 45292-35050 ($12) that goes down there. Common to wear out.
It's not meant to provide that much support, just keeps moisture and dust out.
If you still have too much movement or the seal wears out too soon then you have other worn components in the steering shaft area.
1995 FZJ80 Red/Tan leather
163,000 2nd owner, 285 BFG AT's, spare tire mod, CDL, Pin7 mod, OEM cupholder.
lowbanks is offline   Reply With Quote
