Old 06-20-09, 06:51 PM   #1 (permalink)
landtoy80's Avatar
Power Steering Capacity... Leak
My power steering gear box is leaking where the steering shaft from the steering wheel goes into the gear box.
As rusted as the 80 is, I am not sure if the bolts will come out or snap off so I am going to add some TransX transmission fluid to see if it will stop the leak. It worked on the Camry but I didn't know where the leak was on the Camry.
I also have some Lucas Power Steering additive that is to stop leaks but not sure if it is compatible with ATF???
With the TransX I need a 1:10 ratio but don't know the capacity of the power steering system, how much is it?
kurt
94 FZJ80 312,000 mi
landtoy80 is offline   Reply With Quote
Old 06-20-09, 08:46 PM   #2 (permalink)
breathed's Avatar
0.9 US quarts in a 97LC. I imagine yours is about the same.
97 LC 152k, lockers, cup holder, cdan pin 7 mod, landtank maf
NRA Life Member
breathed is offline   Reply With Quote
Old 06-21-09, 12:24 PM   #3 (permalink)
IronYuppy's Avatar
TLCA# 17705
Mine leaks in the same place. I am (still) using PS fluid, so I added some Wynn's PS stop-leak, but it didn't really slow the loss by much.
Unfortunately the box is very expensive to replace ($3000+!!!), and even the rebuild kit lists at over $250.
I sourced a used box - just need the time to put it on.
'94 lockered FZJ80
"Fish and plankton and sea-greens and proteins from the sea" - BOX
IronYuppy is offline   Reply With Quote
Old 06-21-09, 05:01 PM   #4 (permalink)
real life web wheeler
Lka1988's Avatar
Garage
Same leak here. I'm not gonna worry about it till it starts spewing fluid.
Lane Anderson
'91 TRD FJ80 "Katie" - 264k, 3FE, 3H4, 860+1/850J+1, RR Aussie, 33's, Taco rims, bumper'd, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, aluminum roof rack, desmogged, timed8*, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
Lka1988 is offline   Reply With Quote
