| Transfer case linkage stuck Hi All,
I finally got around to fixing what I thought to be a seized transfer case HI/LO shifter. The shifter didn't want to budge from HI when I had the vehicle in PARK or NEUTRAL. Since the PO never used LO range, I figured it was the shifter, as it seems from using the search function, this can happen if LO never gets used.
Well, once I disconnected the shifter from the linkage, the shifter moved fine. I put the truck in NEUTRAL and tried to move the bar that was connected to the shifter (I assume this is called the linkage?), but no luck.
Any ideas what to check next?
Again, to try an shift to LO, I put the vehicle in PARK or NEUTRAL and try and shift, but it won't budge. The shifter moves freely when disconnected from linkage.
Any help would be appreciated!
edit: Oh yeah, it's a 1997 LX450 with 160,000 miles.
__________________ 1986 4Runner - long gone
1989 4Runner - long gone
1997 LX450 w/lockers
2007 FJ Cruiser
