| Still got problems!... Ok, so I found out the 7 pin round pin connector is British (the truck came from the UK) so I can't get an adapter for it here. Luckily, I found the pinouts on an Australian site, and was able to test the voltage in the different wires, to be sure I identified the right ones.
Found a Reese converter box I had bought for my Volvo wagon (on which I could never manage the trailer wiring install, because the wiring loom in the back was so messed up by previous hacks), which I forgot is needed when you have cars with separate turn and brake lights. Hooked it up and all seems to work now, I just need to run a power cable to the battery for the Reese box.
Whew...
__________________ Current rig(s): 1992 HZJ80 LHD 215Kms SOLD: 1982 BJ60 3B H42 230Kms and counting
Still planning an expedition...
Reason: New info
