06-15-09, 05:15 PM
Where does this plug into?
Noticed a low rough idle at times, so I took a look under the intake planum and found this vacuum line disconnected. I coudn't find where it is supposed to be connected.
Any ideas?
http://forum.ih8mud.com/members/jaso...-line-edit.jpg
You can see the hose circled by a light red line.
*Note the hose had completely fallen off and I had been able to locate the nipple that it slips onto on the left side of the picture, but could not locate where the other end slips onto. I had replaced this hose with the new one in the pic and cut it to the length of the original hose.
06-15-09, 05:30 PM
is that the one that goes to the charcoal cannister?
1997 LX450 Green! with lockers
06-15-09, 05:34 PM
Nope, all hoses are connected properly from canister. This is one of the thinner vacumm lines underneath the planum. I was able to reconnect to the nipple on the left side of picture, but cannot locate where it was connected on the other end.
06-15-09, 05:55 PM
Took another look at what you were talking about, and think this might be it! I didn't realize there was a T in the hose coming from the canister. The line slipped right onto the T. I'm hoping this was it...
Here's the T fitting with the hose from the canister disconnected and the vacuum line next to it.
The line connected
*I was also experiencing some pretty extreme gas odor after running the vehicle for awhile. I thought I would have to replace the canister, but maybe this will solve some of that odor?
06-15-09, 06:33 PM
That might be the cause of the odor. If not there was a thread about replacing the charcoal in the canister to save $$ over buying a new one.
97LX450, 145K, 315CooperSTT's, OME851/860's, TRD S/C, Bump It Offorad Sliders, 4x4 Labs rear, J-Moose rack, Camping Lab RTT, CDL 7-Pin, George's LED's, Slee SS lines, 100 pads, silicone PHH, Raventai temp, Z34 Vent, Serious case of E-locker envy , CDan parts throughout. IM Scut monkey level I.
http://forum.ih8mud.com/80-series-tech/290251-rotf.html
06-15-09, 07:54 PM
This may help
06-15-09, 10:16 PM
Yep you put it in the correct spot. That short section of hose with a clamp at each end is often loose on the 80s I've had or looked at or worked on. Kind of a quirk. Doesn't seem to affect anything one way or another...
DougM
