Old 07-02-09, 09:09 AM   #31 (permalink)
1FZ-FE Club
gotmud's Avatar
TLCA# 18039
FWIW, 22R's had a rubber boot (19114-35011) that went around the dizzy to help keep out water. Not sure if they are still available new, but a quick scour through a bone yard might net you one. Might be worth checking to see if it is large enough to wrap around a 6cyl cap.
1994 FZJ80
gotmud is offline   Reply With Quote
Old 07-02-09, 12:33 PM   #32 (permalink)
colsoncj's Avatar
22RE's did have a boot. Very sweet feature. Unfortunately not large enough for the 1FZ.
I actually started my off-roading running mini trucks and 4runners.... I just wish I knew a landcruiser like I know them...
-Cory
04 Dodge 2500 Diesel - Tow Rig/DD
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig: Build: http://forum.ih8mud.com/80-series-te...j80-build.html
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline   Reply With Quote
Old 07-02-09, 01:44 PM   #33 (permalink)
blzrfn's Avatar
TLCA# 18225
The 3FE came with a boot as well. Unfortunately the original owner of my truck ripped it. I don't know why he removed it the wires, cap and rotor were all original.
91 FJ80 - completely stock (for now) working on getting all the PM done
blzrfn is offline   Reply With Quote
Old 07-02-09, 02:14 PM   #34 (permalink)
colsoncj's Avatar
so the 3FE had a boot? dont happen to know if it will work on a 1FZ?
-Cory
Old 07-03-09, 01:34 AM   #35 (permalink)
colsoncj's Avatar
well.. the problem apparent did NOT fix itself as its now manifested itself....
I cant drive the thing over about 2K....
The OD light (overdrive) is now blinking at me. I have horrible throttle response... which has progressed from a previous which was just a dead spot between no throttle and minimal throttle...
from doing a bit of searching i believe i'm now actually throwing a code, but im unsure if its the root problem or a symptom of the problem...
any help appreciated... i'm going to do some more searching tomorrow and see if im actually throwing a code and if so, what it is.... thankfully the cruiser did manage to make it back 20 minutes and get me home!
-Cory
Old 07-03-09, 01:16 PM   #36 (permalink)
colsoncj's Avatar
next question, can a throttle position sensor affect transmission operation?
I'm still thinking I might have a bad TPS which now has somehow got my overdrive O/D light flashing throwing a trans code... I'm getting ready to go pull the code, so I should know what it is shortly, and will post up.
-Cory
Old 07-03-09, 02:21 PM   #37 (permalink)
colsoncj's Avatar
Codes:
Transmission was code 88, severed ECM and TCM or short circuit
Engine code 24, Intake Air Temp Sensor Signal (part of the AFM) short circuit or open for 0.5 sec or more
Engine code 31, Volume Air Flow Meter (AFM) Signal; When idle contacts are closed and the engine speed is 1,500 RPM or less there is an open circuit in the VC and VS signal or a short circuit between VS and E2. (E2 is sensor ground, VS is a connection between the ECM and part of the AFM, and VCC i believe connects the AFM to the TPS via the ECM).
On a side note the TCM does rely on signals from the TPS per the FSM operation description. If the IDL (Idle) points of the TPS close (TPS sees the throttle closed) it signals the TCM to unlock the the lock-up system, however im not sure it recieves the signal in conjunction with the ECM or if the ECM provides it... its looks like its in conjunction, which would me that a bad TPS could signal a bad ECM to TCM connection... but it looks like the signal has 2 ways to reach the TCM, from the VA term of the ECM and from a shared IDL connection from the TPS to the ECM and TCM.
I've already cleared the codes, and I'm going to take it for a spin to see what new codes come up. As it stands right now, I feel fairly confident that its one of these things, listed in what I think is most probable at this point:
1. TPS (Throttle Position Sensor)
2. TPS wiring
3. AFM (Volume Air Flow Meter)
4. AFM wiring
5. ECM
-Cory
Old 07-03-09, 04:30 PM   #38 (permalink)
colsoncj's Avatar
Took it for a test drive... just barely got home, again. not cool.
Current symptoms:
First part of the drive had NO issues whatsoever.
Second part of the drive:
While driving it started the whole not wanting to run thing and then threw a tranny code 88 again. got back and checked, no engine codes.
While driving it will just stall, stumble down regardless of throttle input and the catch itself. it barely ran on the way back becuase of this. it would stall, then catch itself, rev back up so i could keep moving, then stall again.
When I got it back to the house its back to its original issue of reving to approx 2200, then stalling, catching itself around 1800 rpms, then repeat. Same thing that was shown in the first youtube video.
I'm still fairly confident i have a throttle position sensor issue of some kind, and the tranny code is just a secondary symptom. In talkin with another very skilled toyota mechanic he agrees with my diagnosis. He had a similar issue where a motor got washed and the throttle position sensor internal spring which helps pull the sensor back to home would bind up and it (the TPS/ECM) couldn't make sense of the throttle position. I'm going to do a quick test of the TPS and see what happens. If it comes back alright, I'm going to pull the whole throttle body off, re-check the sensor, remove, check springs, and lube, reinstall, check again, and reinstall the whole throttle body and see what happens. Hopefully something will become apparent.
-Cory
Old 07-03-09, 05:50 PM   #39 (permalink)
colsoncj's Avatar
checked out the tps and afm... both ohm'd out fine.
started it back up, still had the stall at around 2200rpm. shut it back off.
unplugged the tps sensor, and started back up. no issues except a CEL. no stall, hesitation, stumbling, anything... ran great.
Took it for a drive and besides the tranny not knowing when to shift, didnt have a single problem. got back and rev'd it up, no stall. shut it off, plugged the tps back in, started it back up, all the issues returned.
i'd say that means i have a bad tps... but i'm not quite sure how, given that it ohm'd out alright. must be something else going on either inside of it or with the wiring.
-Cory
Old 07-04-09, 01:31 AM   #40 (permalink)
firetruck41's Avatar
TLCA# 14300
What year does it say on your plug wires?
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is online now   Reply With Quote
Old 07-04-09, 02:07 AM   #41 (permalink)
colsoncj's Avatar
i'll check tomorrow...
-Cory
Old 07-08-09, 07:14 PM   #42 (permalink)
colsoncj's Avatar
well, i'm 92% sure I've got it fixed. Put a new TPS on it, adjusted it, and reinstalled the throttle body.. so far about 30-40 miles and no issues... time will tell.
-Cory
