Old 06-03-09, 07:39 AM   #1 (permalink)
Filmpro
Good Idea / Bad Idea
Probably a stupid question bit I am still fairly new to all this. I have a few mods I am thinking about and would like to know which ones are Good Ideas / Bad Ideas. They are as follows:
1 - Limb Risers
2 - Axle Cams
3 - Tire Pressure Monitors
Any comments? My 80 is almost done after spending seven (7) months in a build process. I am trying to finalize the last mods to be sure I did not miss anything ... so I can actually drive it for the next 10 years...
Rich
2006 Toyota LC, Thunder Cloud Metallic - (SOLD)
2001 Toyota LC, Riverock Green, 79k Miles - (SOLD)
1997 Lexus LX-450, Champagne
(Fully Modified)
Filmpros is offline   Reply With Quote
Old 06-03-09, 08:05 AM   #2 (permalink)
mainemike's Avatar
TLCA# 17772
Limb risers can be very helpful in the northeast and northwest; basically anytime you are wandering along tight, overgrown trails with a lot of foliage. I was following your discussion about roof rack lights, and you'll need to look at where the limb risers end so they send branches up and over the lights.
Axle cameras I don't see as needed. I prefer skid plates and a spotter. If I'm that concerned about the debris underneath my truck it's time to stop and get out and look for myself.
Tire pressure monitors I don't see as needed. Especially if you can't control tire pressure from the cab, the way some mil-spec vehicles can. That is more of a military, "running at high speed thru hostile terrain" scenario. Having simple on-board air makes more sense. On an 80 you would only drop pressure for extended trail runs or sand, I don't see a reason to warrant constant monitoring of tire pressure.
When do we see pictures of this beast?
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, hopefully exploring somewhere in North America.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 06-03-09, 08:10 AM   #3 (permalink)
Doc
Utarded
Doc's Avatar
TLCA# 17266
Garage
If by 'axle cams' you mean castor correction bushings....
get 'em.
Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Old 06-03-09, 08:56 AM   #4 (permalink)
retrofive's Avatar
TLCA# 19315
Like some other threads have mentioned quick disconnect for Limb Riser sounds like a good plan if you go that route.
x2 axel cams (unless like mentioned caster correction) not needed.
x2 Tire Pressure monitors not needed.
'94 LC |OME 851+1"/860/N73/N74E/SD24|SLEE BLUES|SLEE SLIDERS|CDL/7PIN|285/75/16|YAK RACKS
JEFFERSON STATE CRUISERS
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
retrofive is online now   Reply With Quote
Old 06-03-09, 12:32 PM   #5 (permalink)
NLXTACY's Avatar
TLCA# 19015
Limb risers are a good idea. Axle cams give you cool points
What about instead of tire pressure monitors you go with the Staun internal beadlocks? They run about $160 per tire.
ふざけんなよ!
Old 06-03-09, 04:32 PM   #6 (permalink)
Filmpro
Thanks...all good input.
Hmmm...controlling tire pressure form vehicle eh? I should mention that to my builders and see if it sends them over the edge....LOL
I do have an Extreme Outback Magnum Air Compressor mounted right behind the Milemarker 12K hydraulic winch on the ARB Deluxe Bumper.
07. ExtremeAire Magnum
The limb risers I am sold on.
The axles cams I am thinking might be good for me. I will often be out alone scouting locations or dropping off a film crew somewhere fairly remote ... and I may not have a talented spotter handy. I also may use the vehicle for a TV Pilot on off road adventures.
I was waiting until is done to post pics....it will be a long post...7 months of building...and a lot of time and $$$$$$$$$
Rich
(Fully Modified)
Old 06-03-09, 04:33 PM   #7 (permalink)
Filmpro
Already have those...Axle Cameras is what I was talking about.
get 'em.
Rich
(Fully Modified)
Old 06-03-09, 05:43 PM   #8 (permalink)
wanderlust
nat88toy's Avatar
TLCA# 16379
so now you want CTIS "central tire inflation"
it can be done but id have to bring my MIT grad buddy on the build
98 sr5 T100 32" procomp mtr
1994 FZJ-80 factory locked, 4" lift, Landtank caster plates, Arb bumper, warn 12,000, snorkel, 35" TrXus mt, full belly skid, extreme air, bud built HD- TR & DR, HD 1/4 wall DOM control arms
1996 FZJ-80 factory locked, 4" lift Land tank caster plates, arb bumper, warn winch, HD 1/4 wall DOM control arms,FOR parhard adjusters
nat88toy is offline   Reply With Quote
Old 06-03-09, 07:24 PM   #9 (permalink)
98 SNAKE EATER's Avatar
1) Limb risers are great and have served me well, but expect random people to ask you what they're for at least twice a day (even with huge elephant ears hanging from them)
2) Axle cameras are great for rocks, but if you play in the mud as much as I do, they won't do you much good
3) Tire monitors are cool, but internal mount sensors are still pretty expensive
The cheaper external mount sensors will work, but are prone to damage and theft
I personally check my tires way too frequently to need one, but that's just me
98 SNAKE EATER is offline   Reply With Quote
Old 06-03-09, 07:34 PM   #10 (permalink)
NLXTACY's Avatar
TLCA# 19015
Run these and it wont make it much of an issue:
4wd Accessories Australia
ふざけんなよ!
Old 06-04-09, 05:23 AM   #11 (permalink)
Filmpro
So far I have not thrown anything at you guys you can't handle ... albeit, I have tried ...
We'll see if I can stump you with the ejection seat, smoke screen, tire spike deployment, and turret guns that pop out of the hood ... that is Phase 4 of the build...
I found this.
CTIS
Rich
(Fully Modified)
Old 06-05-09, 04:13 PM   #12 (permalink)
wanderlust
nat88toy's Avatar
TLCA# 16379
I found this.
CTIS
already anticipated the ejection seat thus the explosive bolts on all the door hinges
Old 06-05-09, 04:17 PM   #13 (permalink)
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
I found this.
CTIS
Q died. RIP Bond gadgets will never be the same!
Limb risers look cool when put on, but are fairly useless in the desert! I removed mine. Kicked myself for NOT putting on quick disconnects. Wish I had to put on for trips only and off the rest of the time.
on the axle cams and pressure monitors.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
Brentbba is offline   Reply With Quote
Old 06-05-09, 04:39 PM   #14 (permalink)
ThinkTank Waterboy
landtank's Avatar
you already have enough cams in the cab, how many angles of that mug do you need?
Rick Bigelow
'96 215k
Groveland MA 01834
Old 06-07-09, 07:13 AM   #15 (permalink)
Filmpro
Hey, all my sides are my good sides ... gotta make sure I cover 'em all...
Rich
(Fully Modified)
Old 06-07-09, 07:15 AM   #16 (permalink)
Filmpro
Don't forget the wireless remote for these...
Rich
(Fully Modified)
Old 06-07-09, 07:51 AM   #17 (permalink)
jonheld's Avatar
TLCA# 5980
So when my neighbor closes his garage door it blows the doors off my rig and sends my passenger seat into the tree...nice.
Jon Held
1991 FJ80 "Lumbering White Rhino"
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
http://www.sdsysdesign.com/tlc/
Buy your FJ80 FSM here:
http://www.sdsysdesign.com/tlc/fsm.html
jonheld is offline   Reply With Quote
Old 06-07-09, 08:18 AM   #18 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Here's another opinion.
Limb Risers-99% poser material. Maybe in South America or if you live in the jungle but here they seem to catch on stuff and get damaged, or damage your roof rack. Real Cruiserheads will mock you behind your back. At least make them easily removable.
Axle Camera-This is just silly. Way too gadgety. You're building a Land Cruiser not a rANGE rOVER. The guys who have driven Land Cruisers around the world and to the ends of the earth, do not use axle cameras. Learn to drive and read the terrain. The first bit of slop you go through, is going to splash mud on the camera and make it useless. Only helpful if you are always in dry rocks or for spotting yourself over the speed bumps in the Starbucks drivethrough.
Tire Pressure Monitor-Why? I've seen these snagged and ripped off twice but admittedly on H1s. Check your tire pressure before you leave in the morning and otherwise forget about it. Even when wheeling hard, flats are not that common.
There is a fine line between tastefull well thought out functional mods and trucks that are modded for "bling". Don't cross that line.
Andrew
Old 06-08-09, 04:06 AM   #19 (permalink)
Filmpro
Possibly...but not sure I agree. The limb risers would be removable and I am mostly concerned about brush. They may get hung up in thick stuff....you could be right about that. I can install them and remove them if they turn out to be more trouble than they are worth.
Also, this vehicle may very well be used in a Pilot for a TV Show ... or at the very least the vehicle will be seen on camera in a pilot for a TV show.
Real Cruiser Heads already laugh at me behind my back so that is not a factor for me....
Rich
(Fully Modified)
Old 06-08-09, 10:53 AM   #20 (permalink)
NLXTACY's Avatar
TLCA# 19015
Its because we all wish we had the fundage to do wacky stuff ourselves. I for one applaud the insanity
ふざけんなよ!
Old 06-16-09, 06:15 AM   #21 (permalink)
wanderlust
nat88toy's Avatar
TLCA# 16379
some of his insanity has been inspired by some of the things you have done to your 80
Old 06-16-09, 09:01 AM   #22 (permalink)
NLXTACY's Avatar
TLCA# 19015
so I've heard
ふざけんなよ!
