I just installed the Landtank MAF housing with a 22204-21010 sensor that I purchased with the unit (from another 'Mudder). The MAF was new, the sensor lightly used. The truck started and ran fine. After about 10 minutes, the CEL came on. Per the instructions, I reinstalled the original housing and sensor. I went to AutoZone, they pulled the code which was P0110. The CEL went out as I was leaving. I also picked up some MAF cleaner and hosed the sensor down. Reinstalled. Same problem. Before I call Cruiser Dan and order up a new sensor, is there anything else it could be?
