80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 04-20-09, 11:37 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Cruzer_89's Avatar
Relay clicking when in 4WD low
When I engage the 4WD LOW I get a clicking sound from under the dash and my center diff lock light sometimes turns off. It seems to worsen depending on the amount of load the 4WD low range system is under.
Has anyone ever experienced this?
96 FZJ80 ,PHH, OME 850J and 863.... <><
HG Job, silicone PHH, Slee Brake lines, LandTank CC plates,
ARB Rack..
Cruzer_89 is offline   Reply With Quote
Old 04-20-09, 06:15 PM   #2 (permalink)
Cruzer_89's Avatar
C'mon anybody out there ever see this issue?
ARB Rack..
Old 04-20-09, 06:21 PM   #3 (permalink)
retrofive's Avatar
Does the CDL actually ever engage? or engage and then dis-engage? IIRC there is the CDL switch on the tranny and the actually switch that it engages the actuator (there are 2 more but can't remember off the top of my head). There is a couple threads on testing the relay for the center diff. I thought mine was toast, but a local chapter guy helped me test it out.
All the same, my guess would be to pull the relay and run some of the tests on it.
'94 LC | JEFFERSON STATE CRUISERS
retrofive is online now   Reply With Quote
Old 04-21-09, 06:52 AM   #4 (permalink)
Cruzer_89's Avatar
Pull the CDL relay... I'll try that.
Thanks retrofive.
ARB Rack..
Old 04-21-09, 09:17 PM   #5 (permalink)
Did you check the 4Lo switch at the transfer?
If you have CDL mod, do you have the same problem with CDL in 4Hi?
1997 LX450 stock with 153,000km (as of Jan 2009), factory-locked mall cruiser, CDL (homemade), 285/75R16 Trxus MT, ARB winch bar w/o winch, P0401 (solved, cracked vacuum hose) with slight pinging at 1400-1600rpm (95% gone after fixing P0401)
2002 Civic daily driver
xingji is offline   Reply With Quote
Old 04-23-09, 07:21 PM   #6 (permalink)
Cruzer_89's Avatar
I have not done the CDL mod so i would not know if it would do it engaged on 4Hi. What does that switch look like the the t case?
ARB Rack..
Old 04-23-09, 08:35 PM   #7 (permalink)
Disclaimer: I am a n00b, and I am only offering advice because only one other person has posted.
The switch is on top of the transfer case, on the passenger side.
I'm guessing this is due to some sort of a wiring problem, corroded wire, broken insulator, bad plug, etc.
It could also be a bad relay. But it is much easier to visually inspect wiring than ripping out the relay to test. So have a quick inspection of all the plugs and wires.
It sounds like you don't have FSM nor Wiring manual, so this probably won't be an easy thing to tackle.
Old 04-23-09, 10:48 PM   #8 (permalink)
retrofive's Avatar
Between searching the forum and the link below managed to find my locking issue...
Troubleshooting the Toyota FJ80 Land Cruiser Center Diff Lock (CDL) | Pacific Northwest Backroad Adventures
We did pull the relay and used a 9v battery on the according pins in +/-....-/+ back and forth pattern to eventually un-stick my actuator. All my switches tested fine.
Good luck. Read through the above and let us know.
Old 04-24-09, 08:19 PM   #9 (permalink)
Cruzer_89's Avatar
Thanks for the opinions guys and retro thanks for the link. I plan on tearing into it tomorrow.
ARB Rack..
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/279717-relay-clicking-when-4wd-low.html
Posted By For Type Date
Troubleshooting the Toyota FJ80 Land Cruiser Center Diff Lock (CDL) | Pacific Northwest Backroad Adventures This thread Refback 11-07-09 02:38 PM
