LinkBack (4) Thread Tools Display Modes
Old 03-22-09, 09:51 PM   #31 (permalink)
dnp
dnp's Avatar
I, too, am very interested in this mod. I recently had the 1fz in my '95 rebuilt due to two bad rod bearings......I absolutely HATED to do it, because the 1fz is so underpowered. These vehicles SCREAM for a V8; however, I couldn't find a good, concise write up on how to swap (and what to swap) into an 80. I couldn't even find a good write up on an SBC swap......well, not one that didn't leave a lot to the imagination.
Please provide as much detail as you can, and if your test mule works out well (and if you're so inclined), you will probably have a pretty good market if you decide to offer a 2UZ swap "kit"......anyone else on board for something like that?
To me, an 80 with a V8 would be the perfect off-road vehicle.......just my opinion
4x4: '03 Lexus LX 470; '03 Lexus GX 470; '95 FZJ80 triple locked; '95 Land Rover NAS Defender 90 ST; '93 Suzuki Carry RHD mini-truck 4x4; '89 Jeep Comanche 4.0L 4x4; '86 Jeep CJ7 (FOR SALE)
4x2: '01 Lexus GS 430; '87 Ferrari 3.2 Mondial Cabriolet (SOLD, SOLD, SOLD!)
dnp is offline   Reply With Quote
Old 03-23-09, 07:33 PM   #32 (permalink)
alia176's Avatar
Correction - an 80 with a V8 would be the perfect on-road vehicle.......It's already a great off roader with the I-6
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 03-23-09, 08:31 PM   #33 (permalink)
I'm using a uzj100 transmission, the total drivetrain move for me was 6.5 inches. Currently the transfercase is hitting the floor and I need a slight body lift and floor modification to clear it. My throttle body also hits the hood where the PCV hose enters.
90 4runner, 98 3.4 supercharged, 5 speed, 100 coils and 4" front bracket lift
95 4runner with a 3.4l for the wife
thefatkid is offline   Reply With Quote
Old 03-23-09, 09:07 PM   #34 (permalink)
is the 100 series trans off-set rear?
SuperRunner is offline   Reply With Quote
Old 03-23-09, 09:13 PM   #35 (permalink)
The quick brown fox .....
Beowulf's Avatar
No.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 03-23-09, 09:18 PM   #36 (permalink)
TLCA# 13863
Gospel
Toyota 4x4's of Texas aka T4x4T
97 LX450 OME 2.5, 1" spacers, CDL w/pin7, Toyo 315's, cup holder, Bullbar, Hannah Sliders & Rear Bumper.
TLCA# 13863
Buckru is offline   Reply With Quote
Old 03-23-09, 10:15 PM   #37 (permalink)
The 100 transfer case and the 80 transfer case are both passenger drop front and rear if that is what your asking. I purchased a 100 a340f and bolted my stock 80 t-case to it. They are the same t-case with some small differences. You can save some money using your transfer case.
Old 03-23-09, 10:20 PM   #38 (permalink)
Moby's Avatar
Originally Posted by Beowulf View Post
No.
-B-
Do you mean t-case? The Tundra with the 4.7 has a centered rear output on the t-case but the 100 doesn't. When my father in law had his 100 up over the holidays I crawled under and did some rough measurements (which I promptly lost). Definitely offset to the passenger side though. Not as much as my FJ62 but it should work fine. Unfortunately I couldn't talk him leaving his drivetrain with me however so I'll have to look elsewhere if I want to swap one into my 62
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 03-30-09, 05:54 PM   #39 (permalink)
Motor came today. I was hoping it would come with the accesories, but alas it did not.
Motor has 22,000 miles on it.
I have already got the crossmember and the engine mounts completed with my mockup motor. This will go in tonight to make sure everything is still with in spec before I completely weld everything together.
Old 03-30-09, 06:00 PM   #40 (permalink)
Bitter Clinger
bpassmore's Avatar
TLCA# A47-P3C
purty
Originally Posted by tcb View Post
If you catch me eating dog of any kind, send lawyers, guns and money, cause the shit has hit the fan.
bpassmore is offline   Reply With Quote
Old 03-30-09, 08:03 PM   #41 (permalink)
What transmission are you going to run with the VVTI engine? I think it is at a750f 5 speed auto.
Old 03-30-09, 09:19 PM   #42 (permalink)
stock FJ80 trans.
Trying to make this swap as simple as possible and repeatable. That way I can have pre-made mounts, and a bellhousing/flex plate adapter. This swap would of course require welding, and modified drivelines, but everything else should be bolt on custom parts.
Old 03-30-09, 09:39 PM   #43 (permalink)
LandCruiserPhil's Avatar
stock FJ80 trans.
Up until now I was really excited with the conversion but now you have two critical parts that are not available over the counter. By using the 100 trans everything is available just about anywhere. Why did you nix the idea of using a 100 series trans?
"Knowledge without experience is just information"--Mark Twain
Copper State Cruisers #003
LandCruiserPhil is offline   Reply With Quote
Old 03-30-09, 11:12 PM   #44 (permalink)
stock FJ80 trans.
Just FYI this will not work as the VVTI engine was not offered with a 4 speed tranny. This will cause some codes.
The a343 (if that is what you have) does not have a line pressure solenoid. Line pressure is controlled by a throttle valve driven by a cable connected to the throttle plate. Your VVTI tundra engine is drive by wire.
You will need a transmission from a 2003-2007 LC100 to work with that engine. Wiring is a little more of a issue when running a Tundra harness and ECU.
Old 03-31-09, 12:12 AM   #45 (permalink)
Kindof a big deal
Gordopescado's Avatar
TLCA# Shhh.
Damn fatkid. Nice points.
"Whyte Stallyn"
1991 FJ80-work in progress many aspirations(currently bending and welding accessories)
Just me, my Toy and my fishin' pole
You just got passed by a tractor.
[ ][ ]=TOYOTA=[ ][ ]
Anyone wana go fishin'?
凸(◣_◢)凸...︻╦╤─****
Gordopescado is offline   Reply With Quote
Old 03-31-09, 02:11 AM   #46 (permalink)
And I can simulate a solenoid. So it will work just fine and not throw any codes.
So I also learned a few things today:
1UZ and 2UZ have different mount patterns.(I have to re-do my mounts now)
VVTI 2UZ's are drive by wire. Not too difficult to get working, but just more work.
I also hope I can use one of my mid sump 1UZ oil pans on the 2UZ. That will solve much of the underneath clearance issues.
Old 03-31-09, 09:07 AM   #47 (permalink)
here it is inside the bay. I need to put on the SC400 pan before it will go in all the way. I will do that probably tomorrow night and finish up the mounts.
Old 03-31-09, 09:19 AM   #48 (permalink)
Waggoner5's Avatar
What about the oil filter hitting the panhard support? Cant wait till you start on the wiring. Did you get the whole harness? What ECU are you going to run? You are making it look easy.....compared to mine.
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
Waggoner5 is offline   Reply With Quote
Old 03-31-09, 09:39 AM   #49 (permalink)
I will be using a filter relocation kit.
With the SC400 oil pan I will not need to move the panhard, and clearing the diff will be much easier. I will still need to modify the steel part of the pan slightly, but only ever so slightly, much less than the stock pan.
I am using a 2005-2006 4x4 ECU, although now that I think about it, a 2wd may have been a better option. Unfortunatly the harness was cut on this motor. However I do have a 2002 harness that I can use, I just hope the ecu connectors are the same. If the plugs are the same, I will run a small seperate harness for the VVTI and throttle, and any other sensors that are required.
Old 03-31-09, 04:43 PM   #50 (permalink)
Waggoner5's Avatar
With the 91 tranny the 2wd harness may be a necessity. What about the anti theft in the Cruiser ignition?
Gary Waggoner
Golden, Co
TLCA 10689
LSLC 2000
Rising Sun 2007
Old 03-31-09, 07:44 PM   #51 (permalink)
anti theft is easy. I just need to get a transponder sensor, and then get a key programmed. I have done this before. Same way remote start works. You actually have to put a key in a box....oh, that just reminds me. I have an RX300 with a remote start, but the remotes got lost and I removed the key. I can use that sensor...SWEET! Or any other remote start that are set up for coded keys.
Old 03-31-09, 09:23 PM   #52 (permalink)
Turbo Diesel Lover
Tapage's Avatar
IIRC until 2002 Tundras don't have a transponder or security feature on the key just plain key .. this feature come with the VVIT engine ( ECU / harness ) ..
Actually the pre VVIT 2UZ just need a few wires to run .. thought the VVIT are bit more complicated.
With the starter cilinder and the complete harness .. just simple swap on a Non VVTI engine ..
nice project .. keep us posted ..
HJ-60 2H-T Intercooled Tencha
Old 04-10-09, 11:47 AM   #53 (permalink)
Well a bit of bad news. The motor I got was bunk. I am trying to work out warranty info with the seller. Turns out, the front of the head is pretty much broken off. Cams and head are destroyed
Good news is, the mounts are completely done and with the SC400 oil pan, clearance for the diff and panhard are not a problem. Now I just have to wait for a new motor. Meanwhile I will work on the exhaust.
Old 04-10-09, 01:22 PM   #54 (permalink)
Bitter Clinger
bpassmore's Avatar
TLCA# A47-P3C
wow. sorry man.
Old 04-10-09, 02:56 PM   #55 (permalink)
they are sending me out another motor next week. Shouldn't set me back too much, plus I get a free motor out of it with a bad head.
Old 04-10-09, 07:22 PM   #56 (permalink)
sls019's Avatar
TLCA# 19741
Cool project you are working on there. Too bad about the motor, but now you will have some spare parts. Will be waiting for more updates.
MY 71 buildup: http://forum.ih8mud.com/40-55-series...ld-pieces.html
____________________________________
71 FJ40 - 350 sbc, 4" lift, 35" tires, 2nd rebuild
95 TACOMA SR5 V6 4x4 - future Lexus V8 swap
sls019 is offline   Reply With Quote
Old 04-10-09, 09:40 PM   #57 (permalink)
What would cause damage like that?
Kernal is offline   Reply With Quote
Old 04-10-09, 09:43 PM   #58 (permalink)
BenMara's Avatar
wow reminds me of when i had a sheared crank in a 1.3 samurai, it was nice running on 2 cylinders
94 FZJ80 - 200k+ miles, Sleed 6", 325/85/16 XMLs the moveable yard ornament.
LQ9, NV4500, 4speed Atlas, 1 TONs, 40s, in near future
Be informed about ButylFuel
"my AAD (Advanced Automotive Disorder) has grown worse"
-IPOR-
BenMara is offline   Reply With Quote
Old 04-10-09, 10:30 PM   #59 (permalink)
front end collision. I think the cam just got tapped a little while it was running, causing things to bind up and break the head.
Old 05-10-09, 09:05 AM   #60 (permalink)
A month has gone by.....we need an update
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/273882-2uzfe-swap-into-fj80-building-progress.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - 2uzfe into 80 has it been done This thread Refback 08-19-09 05:06 PM
Anyway to disable traction control in drive-by-wire - Tundra Solutions Forum This thread Pingback 08-14-09 04:25 PM
80 Series V8 conversion. - Page 3 - Expedition Portal Forum This thread Refback 03-19-09 01:21 PM
80 Series V8 conversion. - Page 2 - Expedition Portal Forum This thread Refback 03-19-09 12:14 PM
