12-27-08, 07:21 AM
Location: Savannah, Ga ...currently in Kandahar, Afghanistan
80 blinker problem
I just got an 80 and the blinkers just failed. When you activate them, the flasher relay down by your left foot just buzz's. I swapped it out with one from the stealership but it didn't fix the problem. I tried the hazards and they work on all 4 corners.
Where should I go next?
thanks in advance
Dave
06 4Runner V8 4WD-Shrockworks front bumper/custom rear bumper/Stubbs' sliders/King front and rear/Ramsey 8k winch/dual batts/34" MTR's
94 Landcruiser-3x locked/4:88's/35's/SLee 6"/part-time 2wd conversion/aux fuel tank/ARB front/Kaymar rear/dual batts/Snorkel/Warn 10k winch/Metaltech sliders
12-27-08, 12:10 PM
From the fsm:
Trouble
”Hazard” and ”Turn” do not light up.
1. Hazard Warning
2. Turn Signal Flasher
3. Wire Harness
None of blinks for hazard.
(Turn is normal.)
1. Bulb
3. Wire Harness
Hazard warning light does not light up.
(Turn is normal.)
1. HAZ–HORN Fuse
Ñ2. Wire Harness
Hazard warning light does not light up in one direction.
1. Hazard Warning Switch
2. Wire Harness
Turn signal does not light up in one direction.
1. Turn Signal Switch
2. Wire Harness
Only one bulb does not light up for hazard turn.
1. Bulb
2. Wire Harness
*1 Turn signal does not light up.
1. Ignition Switch
2. TURN Fuse
3. Turn Signal Switch
4. Wire Harness
*2 Turn signal does not light up
1. TURN Fuse
2. Turn Signal Switch
3. Wire Harness
'95 cruzr, arb, winch, ome lift, trd sprchrgr, kamar rear, 176k, borla exhaust (dont waste your money) and some other useless junk..
12-27-08, 03:27 PM
Thanks for the response Smoke. I finally figured my problem out though.
I guess I can add one to your list above:
For "Hazards blink but turn signals do not"
- check that the impedence is the same for each side. I had one blinker in my ARB bumper that was out. I removed the bulb on the other side and now the blinkers (OEM) work again. ...now just need to replace the two in the bumper at the same time.
01-10-09, 08:34 PM
son of a Bi+!!!!!
the damn buzzzzzzz is back and I can't figure out where the problem is. I've disconnected all the blinkers from the front and rear bumpers (ARB/Kaymar) and when I turn the hazards on, all 4 corners blink.
When I turn the turn signal on (either way), the relay down by my left foot just buzz's and no blinkers come on.
has this happened to anyone else? ...any ideas?
01-10-09, 08:44 PM
Bitter Clinger
is it low on fluid?
Brett - http://brettpassmore.com
Facebook Me! | Join IH8MUD on Facebook
Are You Connected on LinkedIn? Find my profile here
97 LX, 85k, 3x Locked, 315/KM2, Fancy Tree Mod.
08 Avalanche LTZ 4x4
Originally Posted by koop
I agree with bpassmore. I need to lie down now.
Originally Posted by Chang-kuao-lo
i agree with passmore. i need to lie down now.
This message has been deleted by woody.
Originally Posted by Atticus
go away
01-10-09, 08:47 PM
You'll need to upgrade your flasher. There is a thread or two by LANTANK, I think, that discuss this very issue. It occurs when you have a trailer as well. Too many lights going on at one time.
ふざけんなよ!
01-10-09, 08:48 PM
Originally Posted by bpassmore
is it low on fluid?
huh?
01-10-09, 08:55 PM
Bitter Clinger
go away
01-10-09, 08:58 PM
addict.
is it low on fluid?
Oh man that was funny...
here's your thread, dude. http://forum.ih8mud.com/80-series-te...r-upgrade.html
96fzj80, mostly stock except for the suspension, steering, gears, brakes, batteries, lights, bumpers, running boards, skid plates, stereo, speakers, cargo area, and tires. Also a 2001 Taco DC.
custom 80 series mic holders, dash bezels, seat repair parts, and clear ARB lenses, all available right now, right here www.gamiviti.com
and some of my best friends are TLCA members.
01-10-09, 09:25 PM
#10 (permalink)
that is funny!!
01-10-09, 09:27 PM
#11 (permalink)
Bitter Clinger
good luck buddy.
go away
