11-24-08, 09:11 PM
Waivering Steering Problem
I have an 80 series that does not track correctly on the open road. In the straight ahead position it seems to waiver and I am always correcting this. Don't get me wrong. It's not that serious! (Registration checks have never picked anything up.) Seems that other vehicles, form slight wheel ruts in our secondary roads and because of the LC's wide track it's either in a rut or out.
Is it normal for a LC to do this?
I'm thinking that I should replace some steering bushes and stuff.
Got no idea what though.
Seems to me that something in the front end may be worn and causing my cruiser to float just that little bit! I'm pretty fastidious about mechanicals. Also planning a big trip around Aus so want everything to be AOK!
My wife does not like driving the LC because of this steering float.
Not that I want her to drive it but sometimes on a long trip in Aus I need her to do a bit of the driving. I'd also like her to enjoy driving it, cause they are a brilliant vehicle.
Any suggestions would be appreciated.
This is my first thread so if I've done anything wrong, forgive me.
LynRick
11-24-08, 09:43 PM
Is your truck lifted at all?
Bigger than stock tyres/different style tyres?
(if you are lifted) Have you corrected for caster issues?
Do you find that your wheels seemingly find every rut and line in a rather smooth looking highway?
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
11-24-08, 09:53 PM
It has a slight lift. Approximately 50mm (2 inch), beefier springs with Bilstien shocks.
Only slightly higher than stock.
I've had steering alignment done when fitting new tyres. They havn't said anything about excessive height.
These improvements to the suspension were done before I bought the vehicle back in 02.
Yeah! Everything in the last line of your quote.
LynRick
11-24-08, 09:56 PM
Sorry, only 60/40 road tyres.
LynRick
11-24-08, 10:05 PM
Castor Kits
Tough Dog Castor Bush Kit
Application
Price
2 Degree Kit
$149.50
BUY
3 Degree Kit
$198
BUY
Found this stuff about castors but how do you know what number of degrees you need?
LynRick
11-25-08, 12:10 AM
Take it to a shop and have it measured. Also have them balance your tires.
You can jack up each wheel and check for play to make sure you don't have worn bearings.
11-25-08, 12:16 AM
Check your Tie Rod Ends and Stabilizer Bushings.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
4" Lift 33" Yoko Geo MT
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
11-25-08, 12:22 AM
Just had my birfs done so I know it's not the bearings.
Are there bushes in the front steering bits which are prone to sloppiness over time?
LynRick
11-25-08, 12:26 AM
Kalawang
Will do.
Should'nt be any play in them. Right?
LynRick
11-25-08, 12:47 AM
#10 (permalink)
If your bearing preload wasn't set right (or something has backed off), then that could be causing it.
Double check for play in the tire. It'll only take a couple minutes to see, and it's an easy test.
FAQ post for reference:
IH8MUD Forums - View Single Post - Front Axle Rebuild - For FAQ
11-25-08, 02:13 AM
#11 (permalink)
Thanks. Yeah this was checked last Friday by a mechanic doing a registration check. We have to take our vehicles to an authorised inspection station every year in Aus. They go over the whole car mechanicals and particularly the front end, checking for freeplay in all the components.
Have checked out the front axle rebuild in the past. Was thinking about attempting it myself but decided that discretion was the better part of valour. I chickened out and had it professionally done! Very expensive!
LynRick
11-25-08, 06:32 AM
#12 (permalink)
if there is no free play in the front end at all, then you are left with the tires and the castor to correct. as suggested by your mate, get the castor measured and then the appropriate bushings to correct it.
if i were you i would still check for any play in the front end myself. here is a step by step guide on how to do so with pictures. really, until you do this, you are shooting in the dark: http://forum.ih8mud.com/80-series-te...ation-faq.html
TLCA #14504
'97 FZJ80, ARB Bullbar, IPOR rear bumper, factory lockers, Slee 4" lift, Toyo MTs, Austrailian Outback drawer, Hellroaring Dual batt system w/ dual Optimas, Lightforce 240s, etc, etc...
My blog
11-25-08, 10:28 AM
#13 (permalink)
I'm his mate?
Sweet!
11-25-08, 11:02 AM
#14 (permalink)
Will do.
The only way I know to check the TRE is to dismount it and try to move it by hand. If it moves, change it. The stabilizer bushings are more likely to cause a bit of bounce than wander and can be eyeballed. Just look to see if space has developed. They are cheap and easy to change.
I'm reasonably confident that your problem is in the TRE's as they have the most dramatic effect on steering and handling when they are busted.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
11-25-08, 06:31 PM
#15 (permalink)
Thanks for all the advise and link to that article, peepers.
And a special thanks to my new "mate".
I'm sure I'll get to the bottom of this!
LynRick
11-25-08, 06:40 PM
#16 (permalink)
Kalawang
I think you are right about the TRE's. I'll do the full check as suggested earlier. Got to find something!
Thanks for your advise.
LynRick
11-25-08, 06:57 PM
#17 (permalink)
 we are all mates as far as i am concerned
TLCA #14504
My blog
12-08-08, 08:40 PM
#18 (permalink)
lynrick's problem is the same as mine.
I was just going to post the same problem but lynrick worded it better.
I have the same lift as he does. I don't have caster adjustment but I have lived with it for a year. So thats not the only problem.
I don't notice the problem in town. Its REAL BAD at 80mph. I have to bump steer to keep in control as the road turns. It seams to be getting worse. I am glad today is the last day of my 150 mi/day commute as I don't think I would drive it tomorrow with this problem.
There is the "steering adjustment" for play in the steering wheel on the steering box.
Could excessive play cause wandering? If not, what problems are there with too much play?
My tie rods are 5 yrs old have 100,000 mi on them.
I too don't know what to look for with worn tie rod ends. I can turn the tie rod in my hand (like a throttle on a motorcycle) but there is no back and forth movement. I don't feel any slop.
kurt
94 FZJ80 316,000 mi
12-11-08, 06:23 AM
#19 (permalink)
Anyone know what the steering adjustment on the steering box does other than adjust play in the steering wheel?
kurt
94 FZJ80 316,000 mi
12-11-08, 07:25 AM
#20 (permalink)
Low caster will "show up" as something gets worn or another spec gets slightly out of alignment. Have you had toe alignment checked?
1995 FZJ80 - F.O.R. Gen II 3.5" lift - 37" Trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted - Durabak'd
12-11-08, 08:13 AM
#21 (permalink)
Trucks with bigger than stock tires often need more toe in than stock. You might also try to adjust your tie rod to add a little more toe in beyond stock specs. This can make a big difference in handling and steering.
95 FZJ80 headers, custom collector 2x2.25" into 3" Y-pipe, 3" Flowmaster/mandrel exhaust, LT MAF, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier
