04-21-07, 04:43 PM
ThinkTank Waterboy
turbo manifold project
now that the old cast manifold has moved on I'm prepared to share my work on a turbo manifold that I've designed.
As others I have borrowed heavily from Dusty's work with weld ells. The design basically posituions the turbo under the manifold and just aft of center. This position allows for a slip joint in the center and should provide ample room up top for plumbing duct work.
Attached here are the drawing files of the tubing configuration and the flange.
Rick Bigelow
'96 215k
Groveland MA 01834
04-21-07, 04:46 PM
ThinkTank Waterboy
I've cut a corrugated sample of the flange that I'll fit to the engine to make sure everything lines up prior to actually having a iron one laser cut out.
You'll notice that the exhaust gasket fit quite well and there is a provision for the EGR passage
Rick Bigelow
'96 215k
Groveland MA 01834
04-21-07, 04:46 PM
ThinkTank Waterboy
more
Rick Bigelow
'96 215k
Groveland MA 01834
04-21-07, 06:02 PM
Good work Rick, It looks like you're well underway to build the manifold,
Have you picked other components to complete the build?
95 TLC, factory locked, CDL switch
F.O.R. lift kit, 4.88 gears, 315 Dick Cepek FCII
04-21-07, 08:13 PM
ThinkTank Waterboy
I'm still sorting some of that out. I'm getting together with Cattledog tomorrow to further investigate fuel delivery with the stock ECM.
I've got a few irons in the fire right now that need a little more attention before I pull the trigger on having the manifold built and a turbo bought.
But it's getting close.
Rick Bigelow
'96 215k
Groveland MA 01834
04-22-07, 09:02 AM
I think the slip joint issue should be considered. I don't think you will need a slip joint and what a pain that will be. just cut the manifold flange between each exhaust port and make the exhaust manifold flange bolt holes a little larger toward the outermost ports (1,2,5,6). these are the suggestions made by Corky Bell in his book with regards to I6 engines. if that slip joint leaks only a very little bit you will smell smoke in the cab and wont be happy. just yesterday a changed out a blown wastegate gasket that was lightly smoking. But at leaste you can change out wastegate gaskets fairly easily
I only cut the flange between 3 and 4 but I did make larger bolt holes towards the ends. My manifold has more room for thermal expansion because it has a pair of secodary runners.
When I built mine I didn't want the turbo any lower than possible to minimize contact with water f I ever cross any.....but then I mounted my air filter lower than the turbo...so go ahead
and I would leave the flange a half inch thick and dont cut it down to fit the exhaust gasket-leave it beefy as possible to make cracks less likely. after you weld it up it will be a bit warped and will need to be machined flat which may loose up to 1/8 and inch in thickness (mine did) in some places.
97lx450
1 tons and 42's
4" slee coils, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
my build
http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
ezgo electric golf cart crawler build pend....
2002 porsche C4S
04-22-07, 05:58 PM
ThinkTank Waterboy
Dusty, what do you think about chopping it into thirds. That way I can move the T3 flange center stage and have some meat to hang the turbo from. That would make 1+2, 3+4 and 5+6 as pairs.
I'm a little concerned about cutting them up into 6 pieces with that turbo flange bridging two of them.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 11:15 AM
ThinkTank Waterboy
I've been PM'd about updates and finally have something to add to this thread.
About the only thing left from the original design is the drawings themselves.
Using 90* elbows to sweep into the main runner was cost prohibitive and the slip joint fell into the same category as well as getting predictable results was questionable.
So I basically borrowed all the good ideas that I liked from other designs and am using them for my manifold.
Attached is the over view of the manifold as it sits now. The elbows and "Ts" have been cut down to fit properly and chamfered for welding. As some will notice this is how another manifold was built recently.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 11:18 AM
ThinkTank Waterboy
The next series show how expansion will be handled. The manifold will eventually be cut up into three sections. The center section bolt holes are round while the outer sections are elongated. Hopefully I've done my math correctly when calculating the expansion differences at operating temps
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 11:20 AM
#10 (permalink)
ThinkTank Waterboy
The next two pictures shows the chamfered joints prior to welding and the inner runner that will need to be welded and then ground smooth.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 11:21 AM
#11 (permalink)
Looks nice Rick. Did you go with stainless? I'm looking forward to seeing the flange fabricated.
1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust.
07-08-07, 11:25 AM
#12 (permalink)
ThinkTank Waterboy
The next step is to mount the manifold to the head and position the T4 flange and Tial waste gate flange.
Both of these flanges will be sleeved into the main runner. My hope is to hang the turbo underneath the manifold like the AVO and Safari does at a level that will allow the down pipe to pass under the AC line and still go over the frame in the same way that the stock exhaust does.
The turbo that I've purchased is the GT35R with a 3" V-Band flange so it should have enough room to do what I want in there.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 11:28 AM
#13 (permalink)
ThinkTank Waterboy
Everything is 304.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 03:26 PM
#14 (permalink)
precision. fine work
you probably already know the following:
be sure not to make any of your 3 cuts in the flange till all welding is complete as the flange will expand if you do.
have the flange surfaced after the cuts are made as it will be holding some tension after welding is completed and will flex a bit after you cut the flange. if you surfaced before the cuts are made the flange will not be flat
97lx450
1 tons and 42's
my build
2002 porsche C4S
07-08-07, 04:10 PM
#15 (permalink)
ThinkTank Waterboy
We talked about this. While I drew up the plans it's two other professionals doing the work. The manifold as it currently sits will be clamped to a 1" piece of steel during welding. Once the entire piece is welded it will be heated to 1500* to stress relieve it and then the two cuts in the exhaust flange will be made. The EGR passage will then be milled and then all three flanges, exhaust, turbo and waste gate will be resurfaced.
I feel fortunate to have these guys working with me on this project.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 04:27 PM
#16 (permalink)
Looks great, and really professional. Gaps look perfect for welding. Much easier than trying to fit the 90* elbows. A little loss in potential performance isn't a big deal on a vehicle like we have.
Might be worth it to stress relieve the manifold after welding and before milling the flange. It might warp after a few heat cycles due to some internal stresses. Maybe not, but might be worth it if you hate exhaust leaks as much as I do.
I don't know, maybe I've just had some crappy headers in the past...
Any plans to sell these manifolds?
67 FJ40, SM420, SOA, ARB rear, elocker front, 30 spline longfields, 37 inch MTR's.
07-08-07, 04:54 PM
#17 (permalink)
ThinkTank Waterboy
Again, this isn't me doing the work, these guys know exactly what they are doing. All the joints look just like the one I posted. The reason for the sleeves is that they needed to be able to cut into the runner and weld it properly. They didn't want to just layer a bunch of passes over itself to fill in the void.
Attached are some pictures of the parts for the T4 flange. These are just rough parts and they need to be machined for final fit. The end result will be that the rectangle tube will be welded together and then slide into the flange itself.
So the tubing gets cut for the flange port. The sleeve is assembled and machined to fit the hole and welded in. Then the T4 flange is slid over the sleeve and welded into place. The same will be done for the wastegate however the sleeve is just a simple turning on a lathe.
I'll be happy to have more made up if people want them but honestly this isn't going to be a cheap part. But I'm hoping it's a good one.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 05:07 PM
#18 (permalink)
Rick, that looks beautiful. Don't know if you've made your final decision on where the turbo will sit, but my recommendation is to consider the rest of the "stuff" you want under the hood. For me, I wanted to know that regardless of future mods, the second battery tray, the windshield washer bottle and the grotesquely large cyclonic air filter assembly would fit. And as Dusty has mentioned, the turbo will get so hot it'll glow red after a good run. I know he's counting on his hood liner  but keeping it below the manifold is my vote.
Mike R.
hmmm....nuthin'
Answer a fool according to his own folly.
07-08-07, 05:33 PM
#19 (permalink)
ThinkTank Waterboy
That stuff has been on my mind for quite some time. Needless to say this build is going in a very different direction from previous ones.
I really have no need for a second battery so that space will be occupied, but my York OBA system should still fit with the stock filter canister in place.
If I get the factory manifolds off and mount this unit for placement I'll shoot some more pics and post them up.
Rick Bigelow
'96 215k
Groveland MA 01834
07-08-07, 07:18 PM
#20 (permalink)
Rick, another thread reminded me to remind you of the factory bracket that supports the y-pipe - the one that has two bolts into the tranny housing. That is a great mounting point for your own bracket to tie in your down pipe housing and really takes a lot of stress off the manifold studs. Another reason to keep it low
Mike R.
hmmm....nuthin'
07-08-07, 10:17 PM
#21 (permalink)
like Mike said the bracket used by the ypipe is perfect for for support. I'm using mine
sounds like this stainless manifold is built to go the distance. this is one area where I worry about my cast job as I have read that a life expectancy of 5 years is average for a mild steel weld el manifold. mine has multiple welded joints and this can only add to the stress. this stainless job looks immortal. Im sure you will have much more money into this manifold than the ebay one you could have kept. But I have yet to see Rick cut any corners and this build is one more testament
You could have taken a cheaper road than a gt35. Huge power potential. I believe this is the same turbo Christo has spoken of in the past with reference to the AVO kit.
97lx450
1 tons and 42's
my build
2002 porsche C4S
07-09-07, 11:29 AM
#22 (permalink)
ThinkTank Waterboy
Using the tranny brace for support has been one of my targets for a while.
Safari and AVO use turbos with internal waste gates. While this simplifies the down pipe and integration into the exhaust system it does get real crowded because of the added width of the turbo housing.
This is the major reason I went with an external waste gate. Another reason was that other cheaper turbos could be used on this manifold.
Rick Bigelow
'96 215k
Groveland MA 01834
07-09-07, 11:56 AM
#23 (permalink)
Rick, lookin' good!
94 FZJ-80 DD,lockers,850-860 with 1" spacers,37x12.50x17 Truxus M/Ts,17x10 GLW beadlocks,York OBA,GLW front and rear bumpers,Warn 9000 with blue rope,Auto window mod,GLW rear cargo bars,LED cargo lights,CDL switch and Pin-7 mod,OEM hand throttle,lots more coming!http://www.greatlakeswaterjetinc.com
07-09-07, 04:12 PM
#24 (permalink)
ThinkTank Waterboy
thanks for all the kind words.
I had an early day today so off came the stock manifolds and on went the turbo one. I've got everything marked out and if I can I'll be dropping it off for completion tomorrow.
Surprisingly my options for turbo placement was extremely limited especially having it down under. In that position there was only 1 spot, so I went with that as my choice.
Rick Bigelow
'96 215k
Groveland MA 01834
07-10-07, 07:55 AM
#25 (permalink)
ThinkTank Waterboy
I just got back from my machinist and he has everything now to complete the build. He's thinking sometime early next week for the finished product. Sorry I didn't get any pictures but I will next week.
Rick Bigelow
'96 215k
Groveland MA 01834
07-10-07, 08:28 AM
#26 (permalink)
Rick, this is looking good. Very good work from your crew! I am watching all these turbo builds with keen interest hoping that some day i will be able to afford to follow in the footsteps.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
07-10-07, 10:20 AM
#27 (permalink)
Rick, looking very good. Can't wait to see pics next week.
Did your GT35r come with a restrictor for the oil feed? If not, you will need one to prevent smoking. This is a common problem for people using this particular turbo. I think the larger GT series turbos shipped with a restrictor, but the 35r did not. This may have changed now due to some of the early problems people had with it.
http://www.turbobygarrett.com/turbob.../faqs.html#t16
1996 LX450 w/ factory lockers, Optima Red Top, HIR 9011 Hi & Low Beams, OME 850J/863, Slee Blue CC Bushings, Bilstein HD Shocks, ARB winch-bar, 295/75/16 Terra Grapplers, yellow box speedo correction, LED domes, CDL switch w/pin 7 mod.
07-10-07, 10:48 AM
#28 (permalink)
ThinkTank Waterboy
Thanks for the tip, if I knew what a restrictor looked like I might be able to answer the question to whether or not it came with one. I'll have to check into it.
Rick Bigelow
'96 215k
Groveland MA 01834
07-10-07, 02:06 PM
#29 (permalink)
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Oil inlet fitting for GT28/30/35R with built-in restrictor
Oil inlet fitting for GT Ball Bearing Turbos for GT28R/GT28RS/GT30R/GT35R with built-in oil restrictor (of .035" hole size). Custom machined part. Output is -4 AN male flare. use with any of our -4 feed line assemblies.
07-10-07, 05:03 PM
#30 (permalink)
the restrictor point is a good one. I have used 2 diff restrictors on mine. when my turbo first started smoking I was hoping the problem was too much oil so I went with a smaller restriction but the bearings were coked and the shaft was loose. after I put in the new bearings I went back to the bigger hole and its not smoking. I dont know what to think on this one. But I do know that most turbos need only a fraction of the oil pressure available to operate properly.
97lx450
1 tons and 42's
my build
2002 porsche C4S
