Bleeding brakes, what am i doing wrong?
After completing OME lift(J's/L's w/1" spacer up front to level out) i intalled the MAF SS brake lines. Read the FAQ on bleeding, Landtanks commments about the possible leak in the system (haven't found anything to indicate a leak, but it could be the culprit) but i still have very spongy brakes. I have not adjusted LSPV yet, plan on dropping .25" but not until i get the air out ![]() I have had wife and son "Manning" the pedal... 1. Started from the back first, crack bleeder, pump brakes at least 3X or until air bubbles are gone (have clear 1/4" tubing to see stream) 2. Once sides are done, crack LSPV and pump until clear stream emerges. 3. Move to front, crack valve, pump until clear 2X. End result is i do not see air, and brakes suck... I haven't gone through quarts of fluid, but definitely pints...Advice? __________________ 97 FJ-80 Factory Locked, 116K, ARB, OME J's/L's, 1" spacer up front, 4" MAF Castor Plate, 2" FT Sway drop, HID's, Diff. breather, 315 KM2's 99 4-Runner Limited, 265 REVO's, Hella FF, E-Locker 2007 FJ Cruiser OME, ARB, Warn8K, Gobi, Trail Gear Sliders, TRD Rims w/BFG 285 AT's...SOLD :( |
tagging along for my own mushy brakes after new rear pads installed.
__________________ 95 fzj80, Factory Locked, CDL, Pin 7, Hankook 285 Dynapro m/t looking for used OME lift |
At any point did the level in the master cylinder reservoir get really low?
Remember it has 2 separate compartments that hold fluid, maybe one got really low and you didn't notice? This would lead to air in the MC. If this happened you will need to bleed the MC. The procedure is pretty easy but I don't know the details from memory. If you have an service manual it is in there. I don't know if I am just lucky but I have always just bled brakes by myself just pumping the pedal. Drain and fill MC reservoir with new fluid. Clear line on bleed screw going into a bottle with fresh fluid. Crack bleeder. Pump brakes while making sure to keep MC reservoir full. Pump until clear fluid come out. Close bleeder. Repeat all the way around including LSPV. The only issue I have ever come across was when I let the reservoir get too low. I just bled the MC and all was good. Good luck. PM me if you would like the procedure to bleed the MC. |
I didn't suck the MC dry, but it did get pretty low...if you have the MC procedure, post it please so that others can utilize if needed. Thanks!
__________________ Keith '77 FJ-40 OME, ARB, SM465, Family cage, 33" Swampers, and lots of rust. '93 FZJ-80 - Flare-less, Factory Lockers, ARB, OME "J" Lift, IPOR Skid Plate, Toyo 315 MT's, Sliders, Side Protection, and Rear Bumper by M&M Fab (http://mandmfab.com/id55.html)...... This is just the begining... '02 Chevy 2500 Duramax to tow the toys http://www.4x4bcds.com/ '92 Toyota Celica GT Convertible - The newest Toy, 113,000 miles and unmolested! |
I'll run a quart or more through tonight and see if that does the trick. If not, on to plan b, though i am not sure what that is as of yet.
I have absolutely nothing to add to this post
__________________ 94 FZJ80 5" OME comp lift, factory lockers, 36" TSL, safari snorkel, family wheeler and DD |
Cause thats how I roll
I had this issue after installing the slee brake lines when I did the lift. Once I knew I had the air out I adjusted the LSPV, my pedal returned to it's normal position and feel. I ran 2 of the big bottles of brake fluid thru mine and it didn't cure the problem. Then I adjusted the LSPV and man what a difference that made.
-Juan __________________ 96 LX450 4" Slee Metaltech Sliders ARB front bumper 35" Toyos trailgear 1.5 spacers Build built TRE w/OEM ends KI6RGS |
MC could be junk. I had a similar problem with my minitruck. It turned out that the MC worked fine for the front, but the rear was toast. Therefore, I was able to pump, but not get the necessary pressure. I also ended up having a junk slave cylinder a few months later.
Just something else to check. Good luck. __________________ "Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek |
#10 |
I did it the other way around. Pump up the brakes, steady pressure on the pedal, then crack open the bleeder(pedal goes to the floor)HOLD IT, then tighten bleeder. Repeat. Am I not recalling correctly or are you guys doing it backwards?
__________________ 97 factory locked green Lexus LX450 Slee ugraded light harness John Deere HIR low beams Painless auxillary fuse box 2-Hella 5" and 2- 7' Checker Auto HID's driving lights on Line-X'ed bumper COPPER STATE CRUISERS #122 |
#11 | |
Is that a sinister grin? Sounds like you have been there/done that?
#12 |
If you do bleed the MC, make sure you use Flare-nut wrench (AKA tube wrench or line wrench) and NOT a box end wrench.
Ask me how I know. ![]() (And if you do booger up the hard lines to the MC, there aren't any more available in the US. I got the last one. )Additionally I had to bleed each point several times. It sometimes takes a while for the air bubbles to collect. If you do a round of bleeding, wait a bit then go through it again. __________________ '97 LX450 - The -mobile'96 LX450 - Mine! ![]() Triple locked, 315 General Grabber AT2, OME Medium, 1" body lift, belly skid plate, grey wire mod. Jefferson State Cruisers (A wholely owned subsiderary of OR/CA TACO) Forums |
#13 |
This has worked well for me.
Try with the engine off Pump the brake pedal slowly and repeatily till there is definite pressure at the pedal, push the brake pedal down while you or someone you trust bleeds the system caliper, you want to slowly open the bleeder while the other person slowly...steadily pushes the pedal to the floor and holds the pedal to the floor while you tighten the bleeder. Repeat this process at all bleeders till brake pedal is firm. You may have to go around the calipers a "number" of times till you have positive results. Make sure you both work together by opening the passenger door and windows in order to listen to each other. My LSPV bleeder is pooched and though I have a brand new spare just in case the above procedure was all I needed. __________________ 93 FZJ80 De-flared, de-bumpered and Aussied DD. HZJ79L 5speed diesel LSD for work, traded for a Brand new HZJ79L... |
#14 |
Where did you get the spare bleeder? I thought the LSPV one is a different size from the caliper ones, and doesn't come individually from the LSPV.
__________________ Adam 96 LC, OME 851/860, BFG AT 285, Metaltech sliders, IPOR skid, Yellowbox, Landtank seat brackets & MAF, ScangaugeII, Slee harnesses with HIRs & Hella 500s, CDL & Pin 7, George's LEDs, Slee-located washer bottle, 'MUD sticker OME CC bushings for sale
#15 |
ThinkTank Waterboy
I've been playing around with a variation on the standard bleeding procedure. I place a piece of clear tubing on the bleeder and hold it in a way that the tubing arcs up from the bleeder then down in top a catch can. The arc up is to get a section of tubing full of fluid to avoid air entering through the bleeder.
Now with someone in the cab, I open the bleeder and have that person push once and hold the pedal to the floor. I then tighten the bleeder and have them release the pedal. I repeat this process until the fluid runs clear. What I have noticed is being able to get the smaller foamy bubbles out easier. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#16 |
Last time I bled my brakes, the
got tired of doing it after about 60 seconds, so I had to figure out a way to do it on my own.My final solution was to use Harbor Freights ONE MAN BRAKE BLEEDER KIT. I attached this to the bleeder screw, then placed the bottle into a larger container. I then opened the bleeder part way--enough that when I pressed on the brakes there was still pressure, so open maybe 25-40% of the way. This kept the system pressurized, while allowing me to catch fluid easily. The smaller bottle worked perfectly as a reservoir, so that when I let off the brakes and it sucked fluid back in, it wouldn't suck in air. The small bottle has a vent hole, which drained into the larger container when the small bottle filled up. The clear lines easily allowed me to see when the bubbles were out. Keeping the system pressurized seemed to clear the air much faster than having it all the way open. The only catch I had was to watch the master cylinder while doing this and make sure it didn't run dry. Just one more way of skinning a cat. __________________ '97 LX450 - The -mobile'96 LX450 - Mine! ![]() Triple locked, 315 General Grabber AT2, OME Medium, 1" body lift, belly skid plate, grey wire mod. Jefferson State Cruisers (A wholely owned subsiderary of OR/CA TACO) Forums |
#17 |
Guy Fawkes Lives!
I use Landtank's procedure b/c I've noticed that no matter what fitting I use on the bleeder nipple, releasing the brake with the bleeder open sucks some air back into the system.
FWIW though, I think you have air in the MC. This happened to me on my last round of bleeding and I would have sworn it didn't get low enough for air in the MC, but it did. I bled the rest of the system to a crazy extent and still such low braking that it was dangerous. I bled the MC and presto! the brakes were back. BTW, you'll want to bleed the rest of the system again after the MC, but it should go pretty fast. __________________ 1996 FZJ80 (original owner) Black & Oak, 105k miles with factory F/R lockers, CDL switch, hand throttle, OME Springs & Shocks, ARB, Warn M12000, Milford Barrier, Dual Optima Blues, extended breathers, OEM dash cupholder, 285/75/16 BFG AT, Landtank seat rails, Slee AC dryer & T-case skid plates, Slee light & aux harnesses, Slee SS brake lines (frame->axle->caliper), V-1 with remote display, Icom IC-7000, Yaesu 8900R, Cobra 75wstx, Larsen NMO-2/70 & NMO-27, 100-series pads |
#18 | |
__________________ 1996 FZJ 80, 1973 FJ 40 |
#19 | |
#20 | |
You must have someone hold the brake pedal to the floor until the bleeder is tightened otherwise air will be sucked into the line on the brake pedals upstroke. Something like sucking or blowing on a drinking straw...if the straw is good and your finger is covering one end nothing can leave or enter whether you suck or blow, on the other hand if the straw is cracked or your finger is off of the end you get air. Mike __________________ 93 FZJ80 De-flared, de-bumpered and Aussied DD. HZJ79L 5speed diesel LSD for work, traded for a Brand new HZJ79L... |
#21 |
Thanks Squash...i caught on to that quickly once i had them pump the brakes.
Anime Episodes | Sexy Lingerie | The eBay Song | Libros más vendidos | Facebook proxy list |
